My mobile is getting swithched off repeatedly after putting memory card(1GB) in..problem started suddenly overnight.but without memory card the mobile is functioning properly..pls help.........
Although n70 accepts a maximum of 2gb card,it is not advisable to put 2gb card in n70 series as the mobile would lag. you can avoid the lagging by creating separate folders for different files.. it works well on 1gb card without lagging.
my mobile is new i can do this because my memory card is new and my memory card is 1gb so you buy the new memory card then u can fix your problem other wise it,s can,t work. There is no problem in mp3 software the problem is your memory card
try to insert your m2 memory card to other card reader device and check if it can be recognized. then scan for possible virus infection or reformat your m2 memory card.
if still no change, clean the contact pin from your m2 card. use metal folish liquid solutions to clean the copper contact pin of m2 card.
i) try to put memory card in any mobile if it working in it is fine, if not your memory is having some password put on it or attached, try to remove the password and then work with it ........
you can remove password by keeping the memory card only in that mobile where you kept the password(only in that mobile through which u kept the password...)
Hi, Try to put the memory card into the card reader of any system. If nothing comes, your memory card has some problem and is better to get it replaced.
hi this is Aravind , i'm having 1 GB micro sd memory card for my mobile nokia 6233 ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not openinng its asking for password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card without losing the data in memory card ... plz help me out ........
i have microsd card 1gb card of kingston. it is locked & i want to unlock my memory card without losing my data. so pls send me tips for unlock the meemory card
i forgot my password...pls help me unlocked it without losing my files n data... i forgot the password of my micro sd memory card 1 gb , i don't bother about data, how to open , pl explain.
