Question about U-Line Icemaker
U-Line 95 I have a U-Line 95 in a motorhome that is overflowing water. I suspect the motor but don't know the correct diagnostic procedure. Also, the water inlet valve could be sticking. How do I correctly diagnose this problem. Also, I was told that a "head assembly" was available instead of a complete icemaker assembly but I can't find anything like that. Thanks, Bob
  • rebob Jul 15, 2008
    Thanks for that input ... I've been thinking about that exact thing wondering if I should just take the whole thing out and test it for a leak. The best price for an ice maker assembly I found was just under $200.
  • 286 Answers
The part number is #150 faceplate. This would be the motor and switches. Approx $55.00 Appliance parts depot would have it. Or try all brand parts.
Posted on Jun 03, 2009
Parts are available without buying the entire complete ice maker. Try apdepot.com...that is where we purchase our parts locally however I am sure there are other places.
Posted on Jul 22, 2008
Parts are available without buying the entire ice maker...try apdepot.com.
I found the same problem and we pulled out the ice maker and found it to be the water line assembly which the part is only $5.00
Posted on Jul 18, 2008
I have a BI95 on my boat, same problem, got it diagnosed today, the ice mold is deteriorated and leaking, see if there is any white plastic coating that is coming off. If so, you have to replace the entire ice maker unit. You won't like the cost.
Posted on Jul 15, 2008
I have a water leak in bathroom not from toilet. How can I check the pluming in that area?
Your idea may correct. But majority of cases it is floor/ground seepage....leaks through your tiles or waterproofing layers and so on..To chk...keep on pouring water to the ground of the bathroom, near wetting areas, and close the freshwater line leading to the bathroom taps
May 18, 2016 | 2006 Tahoe Transport
Why does the drip pan overflow?
The pan may have been installed incorrectly but it also is possible that debris may be clogging the outlet periodically.
Jul 16, 2015 | Goodman Manufacturing Goodman ARUF182416...
I have a U-Line ULN B198B-00 and the water won't shut off. It ends up filling the ice bucket and overflowing. Could it be a bad solenoid??
If you can get to the solenoid you could remove the solenoid connector. If it shuts off then I would suspect the ice maker timer. if it doesn't shut off I would suspect the water valve/solenoid.
Aug 16, 2014 | U-Line ULNSS1095 Marine Series 12-lb...
Maytag neptune frontloading washer overflow
If you cannot clear the line, you will need to replace it. Here is the line to order.
Nov 22, 2012 | Washing Machines
GWL 11
50. (00110010) Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the hot valve is faulty. The most likely cause is that the valve harness has not
been connected correctly or the valve is open circuit. See fault 48 for service procedure.
48. (00110000) Hot and Cold Valve Coil Faulty
The Motor Controller module has measured voltages from the valve diagnostic circuit that
indicate both the hot and cold valves are faulty. The most likely cause is that the valve
harnesses have not been connected correctly or the valve is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves or the
pins are not bent backwards.
Secondary Source: Water Valves.
Action: Check the valve coils are not faulty (open circuit).
Tertiary Source: Motor Controller module.
Action: Replace the Motor Controller module.
Feb 28, 2012 | Fisher and Paykel GWL11 Top Load Washer
Washing machine (Kenmore Super Capacity 3.5 front loading) not spinning and getting E43 error code. I suspect it's the door lock malfunctioning but want to make sure before I purchase it. I've done...
Well, you are PROBABLY right. It's probably The door interlock switch ("Wax motor") despite the fact that the diagnostic code E43 claims that its a controller board fault. I've had a few conversations about this code in the past and the phrase "Somewhat unreliable" has come up quite often (as has the phrase "complete ****")
For what it's worth, I believe there are 2 parts available for this switch replacement:
If it's a 0.05A rating, the part number is 99001807.
If it's a 0.12A rating, the part number is 12002535.
I believe they cost about $10 - $15
Please don't take the part numbers or price as guaranteed to be correct, I found them in some old notes I have and I may be talking rubbish.
Jul 27, 2011 | Washing Machines
MH LP tank gauge says 3/4 but suspect it is empty. How do I verify gauge inop?
Poured boiling water over lp tank and then felt the tank. It was noticeably cold at the LP line.
Dec 13, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Calypso fails to remove excess water from washed clothings
There are two separate motors, one for the tub and one for the pump. They are both controlled by the motor controller board. Since you say the water drains, the pump appears to be working but since you say the clothes are wet, the spin probably didn't happen. I would suspect the drive motor or the wiring for that motor. There are procedures on the web for testing the wiring and motor windings. Good luck. There is also a pdf diagnostics/test document available. http://www.affordableappliance.com/Download%20Folder/Calypso%20Washer%20Service%20Manual.pdf
Good Luck!
Aug 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Motor oil leaking into overflow
If you mean the coolant overflow I would check the oil dipstick for water oil. It will appear white/tan. If this is the case I would firmly suspect a head gasket.
Nov 04, 2008 | 2000 Oldsmobile Alero
U-Line Icemaker Logo
383 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Iron
Iron
marlin siecinski
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
