Question about Nikon Coolpix 5700 Digital Camera
Viewing screen coolpix p5000
HI! i am experimenting with the macro setting out in the sun. It is terribly hard to see the image on the viewing screen, and of course, looking through the viewfinder does not show you what the lens sees... love the camers and want to get the most from it  thanks!
    President:
  • 2,712 Answers
1. Do you get the same problem in regular lighting as well? If you do, it could indicate an LCD chip level problem, and if your camera is under warranty, I recommend you get it replaced.
2. You could try using a "viewing hood" to block out the sunlight,as shown in the pic below:
You can purchase that online from HERE. I think it cost about $15-20
3.You could even try anti-reflective coating on the lens, although I do recommend the "hood" from point 2 above.
4. If you do not wish to spend $15-20 on the hood, you can try an inexpensive alternative. Take a piece of cardboard and cut it in such a way that one end fits exactly around the digital viewfinder and gradually tapering in to a narrower viewing area. About 2inches depth should be enough. Tape the edges, and voila! you have a hood. Should warn you that this may be a bit of an inconvenience as you will have to hold the hood in one hand and click with the other. But as long as it solves the issue...;)
The pic below will give you a rough idea on how you should cut the cardboard to give you the "tapering" effect on the board. Well, it could just be a case of trial and error, till you get the correct shape.
Unfortunately, there is no other solution, as your camera does not have any other settings. Hope that helps!
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Posted on Jun 07, 2008
Coolpix p5000 viewfinder does not react to zoom
So from what I read her I think you can't use the viewfinder. It was the reason why I bought a powershot G9, a viewfinder. But on my camera, the viewfinder can't be used anymore, because of a mechanical problem. While zooming, what you see through the viewfinder stays the same. I don't think of giving the camera to a repair shop, because the camera still makes perfect pictures. And yes I would love the view finder to work like it used to be, but I leave it.
If your camera is still in warranty time, please contact a Nikon certified service centre immediately. If you have to pay for it, think twice and start saving for a new camera, if you still can make pictures.
Feb 25, 2014 | Nikon COOLPIX P5000 Digital Camera
Can I replace the LCD screen of my Nikon P5000 by myself?
That depends. If you're an experienced electronics technician you should have no trouble doing it. If you barely know which end of a soldering iron not to touch then I wouldn't recommend it.
If you do decide to do it yourself, you can order the part from here.
Jul 17, 2012 | Nikon COOLPIX P5000 Digital Camera
How can i use nikon coolpix 5000 as a web cam
The web cam is designed for constant live imaging where the digital camera handles a series of shots and short movie durations, not suitable for this type of perpose.
Jun 09, 2012 | Nikon COOLPIX P5000 Digital Camera
Nikon P500 baterry drain
The biggest drain on batteries by this type of camera is because the screen is on all the time.
Somewhere in the menu options should be either a screen saver mode or operation timer that can be set to turn-off after a choice of minutes duration you choose.
Sep 22, 2011 | Nikon COOLPIX P5000 Digital Camera
Where can i print coolpix p500 manual for free
P500:
http://support.nikontech.com/app/answers/detail/a_id/17175
P5000:
http://support.nikonusa.com/app/answers/detail/a_id/14261
Aug 19, 2011 | Nikon COOLPIX P5000 Digital Camera
Blurres LCD image and blurred photos
1 suspect dirt on the lens ensue the lens is cleaned with proper cloth and fluid.
2 suspect auto focus sensor is defective or blocked ensure the little windows on the front are clear and fingers do not cover them while taking pictures.
3 suspect camera is set in macro setting, Macro only has a depth of field of a few centimeters any subject outside this field will be out of focus but his may not be visible on the small viewing screen on the camera but becomes apparent when images are viewed at larger sizes.
change camera setting to landscape or portrait setting.
Nov 13, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Blurred picture with nikon coolpix 995 macro mode
When shooting in macro to get good depth of field you often have to shoot f/22. This does not let much light in. You have to hold the camera and subject tight. Meaning the use of a firm tripod is not optional. In most cases you need a longer exposure so wiggle is very important.
Jan 20, 2018 | Nikon Coolpix 995 3.3 Megapixel 4x...
Focusing problems
You may be beyond (up to close) the focal capability of the lens. Even though there is a macro setting, the lens may not have the capability to focus on an object that close (without adding an external macro lens). The specification on the minimal distance for focus should be listed in the owner's manual.
Mar 04, 2008 | Olympus SP-350 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
