Question about Weber Q Grill
Cleaning the grill grate
What should use to clean the grill grate without damage?
I was reading the Weber FAQ online, and it said to use a stainless steel brush over a brass brush. It doesn't explain why but here's the link:
http://www.weber.com/bbq/pub/support/gasfaq.aspx
Posted on Jul 21, 2008
    Champion:
  • 254 Answers
The best thing to use to clean the grill grating is a brass brush these may be bought at most hardware stores and even wal mart.
Posted on Jun 10, 2008
I opened my weber grill after couple of months without usage and I'm seeing that it's covers from the inside with blue fungus (see attached image) How should I clean it? If at all
First thing is to turn on all the burners on high and close the lid, let it run for 20 minutes, that will kill any live growth in there. Turn off the burners, open the lid and let it cool you can use a wire brush to knock off any crud. After it's completely cool you can take a scrub brush and some cleaning agent. Once scrubbed down, rinse it out, and turn it on again to dry; 15 minutes should be enough. The reason it looks like it does now is because it wasn't cleaned before storage. I would not want to eat anything from that grill until it has been cleaned.
Jan 24, 2015 | Weber Grilling
Tip
How To Keep Barbecue Grill Grate Clean and Rust Free
<utube src="qFo0unxnSHQ"></utube>This video will show you how to clean and keep your barbecue grill grate clean and rust free.
on Aug 04, 2013 | Grilling
Is it wise to wash the grates with soap and water or does this remove the seasoning and create a need to reseason? Should the grates be washed?
Hi gscollinssr...
Never wash the grill grates with soap and water...your right it will remove the seasoning and have to be reseasoned again..Clean with a wire brush and wipe with a dry paper towel to clean your grates for the next time you cook.
Please take time to rate me
Aug 31, 2011 | Char-Griller Char Griller Pro Deluxe...
Cleaning the grates?
grill is easy to lift, i usually soak grill like that and then whipe off, that is usually sufficient.
if you have some really bdly ingrained bits, then spray it with oven cleaner, leave for few second and then whipe off, then wash as normal. if this is coated (teflon) grill, then do not use this method! soaking only!
hope this will help, if you find advice useful, please leave your comment and vote for me, thanx!
Jun 28, 2010 | Coleman Roadtrip Grill LXE 9949-750
What is the best way to clean the grill?
use a good wire brush on the burners each time you use it before and after cooking. every season take the grill grates and flare reducers out and clean them well with a wire brush and or steel wool and clean out any residue in side the grill. make sure the grease catcher gets cleaned often as needed. blow out the gas manifolds with air in the spring to remove spider webs or insect webs etc. this should keep your grill working well for 10-15 years. replace the grates or flare plates when needed.also lightly clean the burners when you have the grill taken apart with steel woll then blow them out as well to keep all the openings clear. happy grilling.
May 29, 2010 | Weber Genesis E-320 Propane Grill
I purchased new porcelin coated grates. How do I
My grill uses stainless steel cooking grids, so I had to look it up for cleaning porcelain. Here are a few websites that show you how to clean them. Hope this helps.
This one explains it on the 6th item listed titled: How to Clean Grill Grates.
http://www.gasgrillsnow.com/GasGrillHowTo.htm
This one has good overall recommendations for all cooking grid types.
http://grillparts.com/howto/grid.htm
And finally this one can help you as well.
http://www.mhpgrills.com/restor2.html
May 16, 2010 | Weber Genesis Silver A Grill
The grill grates on my Weber Q have rusted and porcelain has worn off in places. How do I get the rust off without doing further damage? My grill is still under warranty.
The weber Q-300 grate not only rust they start to sliver causing a health issue. My grates were rusting in about a year and a half. I called Weber and they sent me to new grates free. They are warrateed for 2 years. I said to the lady what if these grates start to rust, she said if it was within the two years call and they will replace them..
Apr 10, 2010 | Weber Q300 Grill
How do I clean my grill?
Use a grill brush, if you have porcelain grates then use brush for porcelain. If you have cast the wire brush one works great. Don't use wire brush on porcelain it will scrap it off.
Mar 03, 2010 | Weber Genesis Silver C Grill
Clean stainless steel grates with wire brush
wire brush, heat up grill to warm and clean with wire brush. After you get the built up food and grease off remove grates and clean with soap and water to finish the job.
Sep 03, 2009 | Grilling
Looking for replacement parts for GRP99 Next Generation Grill
either replace them now if its too late, or give them a good cleaning, as you should have been doing all along. non-stick grates can be cleaned regularly by soaking in hot soapy water overnight after they cool and giving a good scrub with a stiff plastic bristle brush; others can be cleaned by cleaning with a stiff wire brush while hot. [if this is the method needed, be sure to remove any leftover grit by wiping with an oiled cloth, refolding to clean area on cloth as you go] BE CAREFUL OR YOU'LL LOSE ARM HAIR OR WORSE!!!!
Apr 04, 2008 | George Foreman GGR50B Grill
Weber Q Grill Logo
1,613 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
