Question about Vivitar Cameras
When the sun is shining it is inposible to see the subject on the screene
    President:
  • 2,712 Answers
1. Do you get the same problem in regular lighting as well? If you do, it could indicate an LCD chip level problem, and if your camera is under warranty, I recommend you get it replaced.
2. You could try using a "viewing hood" to block out the sunlight,as shown in the pic below:
You can purchase that online from HERE. I think it cost about $15-20
3.You could even try anti-reflective coating on the lens, although I do recommend the "hood" from point 2 above.
4. If you do not wish to spend $15-20 on the hood, you can try an inexpensive alternative. Take a piece of cardboard and cut it in such a way that one end fits exactly around the digital viewfinder and gradually tapering in to a narrower viewing area. About 2inches depth should be enough. Tape the edges, and voila! you have a hood. Should warn you that this may be a bit of an inconvenience as you will have to hold the hood in one hand and click with the other. But as long as it solves the issue...;)
The pic below will give you a rough idea on how you should cut the cardboard to give you the "tapering" effect on the board. Well, it could just be a case of trial and error, till you get the correct shape.
Unfortunately, there is no other solution, as your camera does not have any other settings. Hope that helps!
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Posted on Jun 07, 2008
Getting rid of sun spots on my face
1) You needed a hat
2) You needed to apply sun screen every couple of hours.
3) Not all sun screens are equal.
4) The primary way to avoid sun damage is to stay out of the sun light. One day, people will walk around under umbrellas because of that.
5) Putting aside all the fraudulent claims of skin lighteners (might as well try lemon juice), beauty therapists can subject you to several treatments of a laser like device. It will sting your wallet more than your face. But you have to keep out of the sunlight following treatment or you are wasting your time. If you think you will be able to wander around for half an hour directly exposed to the sun, you are dead wrong. It will undo any therapy. Other than this method and some self-discipline, you would have to resort to makeup, something like Thin Lizzy.
Sun damage is such an issue in Australia that they have a slogan: Slip, slap, slop referring to preparation to go out in the sun. Hope you are wearing sun glasses.
Jan 02, 2018 | Sun Computers & Internet
I am getting bit day and night but I cant see anything. I need someone to let me know what this is.
Day is when the sun is shining, and all details are clear. Night is when the sun is not shining, and it is harder to make out details.
Jan 15, 2017 | Optics
Why can't I see lcd screen properly in the sun
When I can not see LCD screen when sun shines on it I use viewfinder , I think it tells you in the user Instruction manual if sun is so bright you can not see LCD use viewfinder .
May 16, 2014 | Konica Minolta DiMAGE Cameras
My pictures have lines through them
If your images have lines through them and you were shooting I full sun and facing the sun with your subject in front then this is known as back lighting and you need to change your angle at which you shoot your pictures try putting the sun over one of your shoulders so that your subjects are lit by the sun. If suddenly all of your pictures are showing a blue line in the same place then it could be a little more serious. It might be that your screen on your camera is going or gone bad and needs to be replaced from the manufacturer or it could be the sensor/processor of the camera has gone bad in which case the camera will unfortunately make a rather expensive paper weight. These are my best informed thoughts and I currently work at a camera shop. If you purchased the camera within the last year then it may still be under warranty. If not contact Kodak or the store where you purchased it and proceed from there.
Sep 21, 2011 | Kodak EasyShare Z885 Digital Camera
Hi, I can't just configure my HTC HD2 T8585's screen brightness. It is hard to see the numbers under sun shine! please help!
You asked a good question! There is no problem with your mobile phone.All Higher model mobile as this problem if you cover your mobile phone from your hand and make your hand shadow to fall on the screen of your mobile then you can see the numbers under sun shine.You can check this var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
Jun 10, 2011 | HTC Touch HD Smartphone
How can I stop the sun shining into myt.v. in the conservatory?
1) try moving the furniture around so that the screen has its back to where the sun comes in
2) fit blinds or pin a sheet up on the windows to stop the light coming in.
3) create a make shift sun block, out of a piece of card which you could tape to the side of the screen
Good Luck! Thumps Up Please!
May 06, 2011 | Toshiba Televison & Video
My screen is VERY dark...I can shine a light onto it and I can see it...how do I repair it?
On your laptop there is an Fn (function) key and another button showing the image of sun. Keep Fn pressed and then click the "sun" button to increase the brightness of your screen.
Regards,
nicolasiac
May 07, 2010 | Toshiba Satellite M55-S141 Notebook
LAP TOP SHINE
look where you fuction keys are is ther a symbol like a sun with up/down arrows on it.if so press up arrow to brighten or use Fn and the up arrow key together.
Jun 30, 2009 | Acer Aspire 5100 Notebook
Can,t see screen in day light due to glare
No, there is not a replacement screen avaliable that will be any different than the one that you currently have.
Try and turn the brightness up a little bit, or all the way  if you have too. That should help with the glare in the sun. If it is mounted in your car, try and mount it in a place that the sun will not be shining on it so directly.
Apr 13, 2009 | Tomtom GO GPS Receiver
Cameras Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
