Question about GE WHRE5260E Top Load Washer
The clothes smell if left in the washer wet overnight
If the clothes stay in the washer overnight, they smell bad in the morning. What can I do to get rid of the smell? Do I take it apart or use some chemicals to clean it?
    Guru:
  • 1,342 Answers
Wet clothes should not be left in the washer over night as mold will develop and cause a moldy odor. You could run the load through a rinse cycle with fabric softener or baking soda to get rid of the odors.
Posted on Jun 07, 2008
Not heating
If you can hear the dryer start and operate but at end of cycle your clothes are wet then it is likely (assuming the heater is turning on) that the fluff collection on the condensor unit is blocking its operation.
Refer manual at this site and follow instructions on page 20.
http://www.eirvik.is/gogn/L/t233c.pdf
Apr 19, 2014 | Miele Novotronic T230C Electric Dryer
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
My washer smells horrible. The clothes after being washed smell horrible. I have left the door open. I have run bleach thru there 2 or 3 times in a row...didn't help. Have also run baking soda thru...
Despite washers remain with some residual water in the pump and wet components it should no be so critical as you are indicating especially if you cleaned it as you stated. You are not describing the smell but try to isolate the source, like the washer drainage point (odors coming from sewage), behind the washer, and inside or under the washer where the mechanical components are. It wouldn't be surprising to find a dead rat, lizard or pests in there. Sometimes even wet laundry falling behind the appliances stinks strongly. Be safe moving and reaching on difficult places. Good luck.
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
After completing a load of clothing, the laundry sometimes has a moldy smell. If it doesn't smell right away, it smells after wearing the clothing and sweat a bit. This is not a body smell - this is a...
It sounds like your leaving the clothes in the washer long after the cycle is finished. Once your clothes smell from the washer they will smell moldy dry.
Aug 19, 2010 | Dryers
Clothes smell bad if not removed right away they have to be washed again like a mildew smell
You have probably left some clothes inside overnight and need to clean your washer.
There are some tablets you can buy at most home improvement and discount department stores that will do the job, but you can also run a load through with white clothes, hot water, and a bit of extra bleach. You could also run a load with just bleach and soap.
Don't go overboard with the bleach, a little goes a long way. If you double the amount you might normally use that will be plenty. No more than a half cup.
But also keep in mind that if you leave clothes in overnight, there will be a smell when you take them out. Wet fabric in the dark is one of the best places around for mildew to grow.
Sep 01, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My expensive lg washer makes my cloths smell
Water is staying in the drum because it does not have the ability to pump put all the water. The only fix to this is after every cycle, take the little drain hose located near the bottom of the unit where you have to remove the cover, and take out the plug and drain into a small trash can. You will get about 4 cups water out of the machine. If this water is left overnight, it starts to mildew and will be washed over your next load. It's a design flaw, but this is the only solution. And one other suggestion, after you are finished washing clothes for the day and after you've drained out the remaining water, leave the door open overnight for the moisture in the unit to dry out.
Jul 16, 2009 | LG WM-2277HW Front Load Washer
Moldy smell in washer after using it.
add about 4 cups of bleach to the washer run through the hottest wash cycle possible. allow to air dry overnight. then add 4 cups plain white vinegar and run through hottest cycles again. to ensure this doesn't happen again remove all wet item as soon as possible. any clothing items that smell musty can also be run through a vinegar wash using about 1/2 cup in the softener compartmen.
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
BELT LOOSE ON FRIGIDAIRE WASHER HOW TO TIGHTEN
you can't really tighten a belt, I suggest that you change it, although it is extremely hard to replace a a new belt yourself. Have you checked the carbon brushes in the motor do not need changing, this could also generate a burning smell and leave you clothes wet if they are worn.
Nov 15, 2008 | Frigidaire CWS3600AS Top Load Washer
Clothes stay wet
Click on 'smell', tags above, there are a lot of solutions here, to this common problem. You'll find one or two to solve your prob surely.
Jun 08, 2008 | Frigidaire GLTF2940ES Front Load Washer
GE WHRE5260E Top Load Washer Logo
351 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
