Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
Usb control Universal Serial Bus controllers not working
  • Anonymous Jun 12, 2008
    Hard drive is no longer recognised by the computer
  • Anonymous Dec 09, 2008
    A 'Found New Hardware ' notification appears whenever i use this particular flash disk. And when I try to automatically install it, it cant work out.
    Other flash disks are perfect here.
It still show unknown which i juess is unknown to which drivers are used for unknown
usb
Posted on Jun 08, 2008
Ethernet controller and Universal Serial Bus (USB) Controller - The drivers for this device are not installed. (Code 28) What do I need this for, what can't I do or what goes wrong by not having these...
An Ethernet controller is a computer processing device used to handle network communications, and Universal Serial Bus (USB)
It can be used to connect keyboards, mice, game controllers, printers, scanners, digital cameras, and removable media drives, just to name, so i think you need booth device...install the 2 device? nothing it is goon to happen to your computer..
Sep 15, 2013 | Microsoft Windows 7 Home Premium Operating...
My usb controller for windows 7 just stoped working
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
hope it helps
Oct 29, 2012 | Compaq Presario CQ-61 Laptop Universal AC...
How to solve code 43 in may flask drive
error 43 is a usb universal serial bus controller problem
click start control panel administrive tools ,computer management ,device manager scroll down
universal serial bus controllers you should see a yellow question / exclamation mark? ! or a red X
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
for windows 7 you might try
First, please disconnect all USB devices. Then, go through the following steps:
1. Press "Ctrl + Esc" to open the "Start" menu.
2. Type "devmgmt.msc" in the Search bar and press "Enter". Click "Continue" if necessary.
3. In Device Manger, press Tab and use "Up" and "Down" to move the highlight to "Universal Serial Bus Controllers".
4. Press "Right" and expand it.
5. Press "Down" to move to the first item and press "Delete" to remove it.
6. Repeat the step 5 and uninstall all items under "Universal Serial Bus Controllers".
Then, restart your computer and Windows 7 will reinstall all controllers automatically.
hope this helps
Oct 16, 2012 | Kingston Electronics - Others
Can't read micro usb drive
hope this helps
Oct 14, 2012 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
TS4GJF300 USB not recognised error 43 occurs
universal serial bus controllers you should see a yellow question mark?
hope this helps
Aug 28, 2012 | Transcend TS4GJF300 4GB JetFlash 300...
Usb port not recoginzed
w7
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
if you can see your usb but its not working
hope this helps
Aug 02, 2012 | Kingston Data Traveler 100 G2 4GB USB 2.0...
Hey i have a verbatim 1tb hdd and it worked fine up to the point that windows did not recognise it anymore stating error type 43.
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
also you might try
hope this helps
Mar 11, 2011 | Computers & Internet
My usb port do not work. It did not recognize any devise.
hello
Use Device Manager to disable and re-enable all the USB controllers. This lets the controllers recover the USB port from its unresponsive condition. The USB controllers represent the USB ports in Device Manager. If you are not comfortable with advanced troubleshooting, try the steps in the "Workaround" section.
To disable and re-enable the USB controllers, follow these steps: Click Start, and then click Run.
Note If you are running Windows Vista, click Start, and then use the Start Search box. Type devmgmt.msc, and then click OK. Device Manager opens. Expand Universal Serial Bus controllers.
Note You might have to scroll down the list to find this item. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled. Check the USB device to see whether it is working.
hope this helps
Jan 27, 2011 | HP Pavilion dv7-1240us Notebook
Usb not detected. Device manager says that the hubs are working fine.
Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Restart the computer, and then reinstall the USB controllers. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Jun 17, 2010 | Computers & Internet
Will not work in usb 2.0 but will work in usb 1.0
Connect the Player to the USB 2.0 port on the Comptuer then open the Device Manager and expand the "universal serial bus controllers" category.
Under the serial bus controller category, check if there is any exclamation mark visible. If there is any then right click on it and select Uninstall. Restart the Computer after uninstalling the device with exclamation mark. Restarting the Computer with the player connected will make the Computer recognize the connected player.
Furthermore, check whether there is any universal serial host controllers prefixed with "Enhanced".
If there is no Enhanced universal serial host controller listed under the "serial bus controller" category then it's required to install the USB 2.0 driver.
In this case, uninstall all the devices listed under the universal serial controllers category then restart the Computer to reload them automatically.
Sep 17, 2009 | Audio Players & Recorders
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
47 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
