Question about IBM ThinkPad T20 2647 Notebook
Dead PC When trying to start the laptop the light to the extreme left of the start button is illuminated only when the button is depressed. Have removed and replaced memory,h/drive etc as suggested on IBM websit to no avail.Have tried h/drive and cmos battery in an identical mschine and both work fine. No fan sound. Please advise?
  • 65 Answers
Simple, either your power supply has went out or worse, you have a short in the motherboard, time to buy a new pc.
Posted on Jun 07, 2008
Every time I turn it on, it displays nothing, just a black screen.But the power indicator is on and there are some white lights flashing next on the Caps lock button and above the scroll button..
Dead (ish) Laptop.
Press the power button momentarily to check if it is hibernating or in stand by. If this doesn't work;
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine and the laptop still won't start, then you may have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Feb 04, 2011 | Computers & Internet
Acer laptop will not boot up
Dead (ish) Laptop.
Hope this helps.
Feb 04, 2011 | Acer Aspire 5610-4648 Notebook
Power button blinking, no display light.
Dead/ish Laptop.
If the adaptor is fine and the laptop still won't start, then you have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Nov 16, 2010 | Acer Computers & Internet
My change oil light will not reset , I have tried depressing the gas pedal and I also have tried the reset button what else can I try
this car should be the pump the gas pedal reset procedure - i will explain it just in case you are unfamilier. turn key to on postion (do not start). wait for change oil light to illuminate. fully depress the gas pedal to the floor 3 times in less then 5 seconds. wait another ten seconds, then start the car. the light should be out. good luck!
May 01, 2010 | 2003 Pontiac Grand Am
Have a Eee PC 701 SD. I can turn on the laptop but once it's on nothing is displaying on the screen. I tried every button possible but nothing works.
Its possible that the LED light that illuminates the screen is dead. If you look very closely can you make out any information on the screen or is it absolutely black? If you can see text or Windows, then its likely the backlight.
If you cant, try plugging an external monitor in to see if it is even booting. Also look at the HDD light (bottom right of the keyboard) to see if it flickers on and off while starting. If there are no lights, then you may have a dead unit... Get er fixed.
May 15, 2009 | ASUS Eee PC 701 Notebook
My VGN-C290 will not power-up. PC dead.
Try removing the battery and unplugging machine. There may be a reset button (look on bottom of computer). Reset. Plug in and try again.
Apr 24, 2009 | Sony Computers & Internet
Dim light on my sony vaio.
heres the solution! if ur fn + F5 key doesn't work...
1. go to start
2. go to control panel
3. click "power options" has a pic of a battery
4. click "change plan settings" under "balanced"
5. change "adjust display brightness"
May 23, 2008 | Computers & Internet
Toshiba LS25-S119 Start Up Problem
you,ve got 1 of several problems here.
1:- A Virus may have locked off the hard-drive.
2:- The RAM is faulty.
3:- The CPU is faulty.
Ensure the battery is left on to charge fully, and retry to boot the System.
Mike @ compurepair.
May 12, 2008 | Computers & Internet
1 Light away from dead?
Remove the battery and plug in the transformer. Then try to power up. Sometimes a faulty battery prevents a laptop from booting. (Such was the case for me).
May 04, 2008 | Acer Aspire 5610-4648 Notebook
Dead Dell D600
You can get the correct adapter on E-Bay for about $20.00. Just search for adapter D600.
Oct 20, 2007 | Dell Latitude D600 Notebook
IBM ThinkPad T20 2647 Notebook Logo
65 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
