Question about Gateway 560GE PC Desktop
Need a fix for a loud processor fan! - Gateway 560GE PC Desktop
    Brigadier General:
  • 10,406 Answers
Take a can of compressed-air, and give a "blow-job" to the cooling-fan, to remove all the dust, which is acting as "insulation", causing the computer to run "hotter", and causing the motherboard to spin the fan faster, to try to make the computer run "cooler".
Or, enter BIOS SETUP, and check the fan-speed settings.
If the fan-speed is set to "100% for 100% of the time",
try a lower setting (which will be quieter).
Posted on Oct 23, 2010
SOURCE:
How to fix loud whine from gigabyte ga-f2a55m motherboard
This particular main board doesn't have the video integrated into the mobo, so it's got a video card. Often the video card has a fan. The fan could be causing the noise. Have you tried briefly unplugging the processor fan to see if the noise stops?
Apr 23, 2014 | Gigabyte GA-F2A55M-DS2 Micro ATX AMD...
Noisy computer fan
If its a loud "whirring" noise almost grindy...you need to replace that fan...it's about to fail. if it's a vibration type of noise, you should try tightening the screws first...if it's coming from processor fan, replace it before you fry your processor...
Jul 03, 2012 | Computers & Internet
Will dried thermal paste make the fan run loud on a dell 4700?... when i power on, fan makes loud noise, black screen and wont boot and the power light led is amber (no blinking).. i changed the fan, tried...
You may try to remove the fan, clean it up. Also try to remove the processor heat sink (clean the thermal paste), reseat the processor, put a little thermal paste, that assemble it back. Before you do this, ground your self first(the easier way, hold any metal).
If this can't help,check the capacitor at your MoBo and if you found any unusual look like, it mean you need a new MoBo.
Jun 08, 2012 | Computers & Internet
HP Pavilion a1010n. Compuiter fan keeps going on and off. Even when computer is not being actively used. Comes on with full power and keeps going (loudly) for a minute or two, sometimes longer, then...
The fan triggers on ONLY when the temperature of the PROCESSOR heat sink goes beyond the settings of the thermistor fixed on it. This is to prevent any damage on the processor and so if there is any malfunction of the PC in its OS or the drivers , then it can be reset, Other wise check the ventillation ports of the PC cabin and clean them. A good ventillation must allow the fan to rest but if the fan works and shuts at times it is only because th processor works and heats. Clean the system, teh hard disk and files and defragment the system.
Jul 12, 2011 | HP Pavilion a1010n (PS563AA) PC Desktop
Dell optiplex GX620 loud processor fan noise like a vaccum. I upgraded to windows 7 and also upgraded to 4gb of ram and a new hd video card as well as a 1tb hd. I bought 4 more gbs of ram but windows...
I don't think you can install 8gb of ram into that desktop. If the processor fan is too loud check it for dust or any other obstructions. If there aren't any try replacing the fan - it could be a bearing in the fan.
Mar 06, 2011 | Dell OptiPlex GX620 PC Desktop
The fan on the processor keeps coming on real loud
The fan is supposed to come on to cool the processor but if it is making excessive noise then I would buy a new one before that one give up completely and you damage your processor. they are cheap enough to buy on line, you might need the motherboard make & the processor you are using to get the correct replacement but you can get CPU fans that have universal fittings in which case you would only need to know what processor you have.
Feb 06, 2011 | HP PAVILION P6240F DESKTOP PC (NY550AAABA)
My computer fan speeds up whenever I'm on the
Nothing ... probably ... your fan speeds up when the processor temp goes up ... the more you are doing, the more cooling you need. The processor is calling for more cooling so the fan runs faster.
If this is a concern for you, you may wish to consider adding another fan to your case. In any event, make sure your power supply fan is clean. Use a vacuum or canned air to clean.
Mar 14, 2010 | Dell OptiPlex GX270 PC Desktop
Dell Demension runs great but loud fan noise that takes a long time to shut down. What going wrong?
I had a similar problem with excessive fan noise on my Dell Dimension 5150. The solution was to replace the worn heat sync compound that was between the cpu and the heat sync itself. (£0.99 ebay)
Jul 10, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Slow speed, fan coming on loudly in Dell D800
Yeah the slowdown is the laptop throttling back due to overheating.
When you do processor-intensive work like - streaming videos - the laptop overheats. The fans come on loudly.
When the computer heats up despite the fans, the processor throttles back to relieve the heat.
When you reboot your machine, it stops performing intensive work, giving it a chance to cool down. It's not restarting that fixed the problem it's the fact that the laptop cooled down.
So here's what you do. Get an air duster and blow all the dust and gunk out from your fans. They are most likely clogged with dust and that's what's causing your cooling problems. If there are large dustballs in there, use a tweezers and pull them out. Get as much out as possible.
Dec 06, 2008 | Dell Latitude D800 Notebook
Loud Fan Noise
Usually the fan on graphic card dies first. It can be replaced with another one but I'd suggest you to build in 80 or 100 mm fan to blow directly on your graphic card cooler. Remove the lid and check if perhaps some cable has fallen close/into fan blade. It must be one of those two. I'm 90% certain.
Apr 23, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
