Question about Baumatic Washing Machines
Washing machine not working
Baumatic bfwe1420w washing machine not working. It's displaying E22 on the display
  • 1294 Answers
SOURCE: Frigidaire washing machine model LTF2940E
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully.
Posted on Nov 30, 2007
SOURCE: Baumatic washing machine instructions
the twelve programs are explained on the detergeant drawer.if not i will post them for you.
to use the dryer turn the middle knob clockwise to the amount of time you desire upto 140 minutes then select the temperature on the far left knob and then depress the half load button your dryer should now work.
Posted on Jan 02, 2008
SOURCE: ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
Posted on Jul 11, 2008
SOURCE: hotpoint washing machine aquarius super silent wf620
Dear stacey
Had a similar error message
turned out I hadnt turned the water taps on
check this and if not the problem could be the water sensor in the drum
G
Posted on Jun 27, 2009
Krazytech
  • 725 Answers
SOURCE: washing machine whirlpool awm8123/1 stopped and FH on display
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR If the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. Press PAUSE/CANCEL twice to clear the display.
check the fill hose screens or you my have to repalce water valve make sure water is turned on....
Posted on Sep 19, 2009
Machine stops during the spin, especially with heavier loads.
Maybe you overload your washing machine. Minimize your washing machine usage to avoid stopping during the spin.
Aug 23, 2015 | Baumatic Washing Machines
E22 errors
Good morning Diane Snow, thank you for your inquiry!
I see that your Frigidaire washer is displaying "E22" error code. Typically an "E22" error code means water is not pumping out fast enough. I would suggest checking the hoses for any restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would recommend having a professional come out and properly diagnosis your washer. I hope this information has been helpful. -Matt
Oct 06, 2014 | Frigidaire Washing Machines
E22 error code
Hello Fulvia, I understand that the washer is displaying error code E22. First, check the drain hose for any restrictions or kinks. If you have check the hose and it appears to be clear and free, then potentially the underlying issue may be the main control board or pump. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky. I hope this information helps to some degree!
Aug 03, 2013 | Frigidaire Washing Machines
Washing machine SF-110LJ sign Fd on display
My washing machine Model SF-110LJ does not working and show Fd on
display. Please assist.
Nov 30, 2012 | LG Hitachi Washing Machine Lint Filter...
I have no instructions on how to installa baumatic bwr 1206 wasing machine
Hope this helps :)
http://talkappliance.co.uk/downloads/?sa=view;down=103
Apr 23, 2012 | Baumatic BTWM4 Front Load Washer
After wash cycle in complete, the door stay locked, and displays the code e22
Hi.
E22 is usually a control board failure. The drain pump must also be tested.
The manual says:
Triac sensing circuit for the pump faulty.Possible fault = Electronic board faulty.
Control board and pump must be tested.
Regards.
Ginko
Sep 13, 2011 | Zanussi IZ12 Front Load Washer
Baumatic MEGA WDSS washing machine
go onto manualtree.com type baumatic megawdss washing machine, if this does not bring anything up scroll down until you see it in the listings. type in the code it asks for (this will be supplied underneath, its just to stop cumputers auto logging) and then download then manual. good luck
Jul 02, 2008 | Baumatic MEGAWDSS Front Load Washer /...
Jan 11, 2007 | Baumatic BTWM4 Front Load Washer
Washing Machines Logo
52 people viewed this question
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
