Question about Minolta bizhub 200 All-In-One Printer
Bizhub Konica Minolta - Error Code C1183
Help for resolving the error code C1183 of muy Konica Minolta C252
  • brian c
    brian c May 11, 2010
    Code C1183 is a finisher / sorter elevator motor failure.
    Check to make sure there aren't ant papers / objects lodged in the finisher.
    Unfortunately, the service manual isn't more specific as to where to look.
    Sergeant:
  • 210 Answers
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
  • 24 Answers
Tray lift motor failure on the finisher. C1183 Finishing option elevator drive
malfunction
See FS-514 Service Manual.
See P.65
Posted on Jun 25, 2009
    Problem Solver:
  • 15 Answers
Sounds like you have a finisher with the optional output tray and the selector is not in the right position. OR you have a bad ground.
Something with your finisher most likely. I wouldnt tear it apart to check wiring unless you started with the obvious.
Posted on Jun 09, 2009
    Problem Solver:
  • 17 Answers
This problem belongs to elevetor motor of your finisher check by power off and on its going to initialize or not if not open eleveter section and reassemble it
Posted on Jul 07, 2009
    New Friend:
C-DCA0
Posted on Jul 25, 2013
    New Friend:
  • 7 Answers
Konica minolta di470 1808 error code
Posted on Jul 03, 2013
    New Friend:
I have a KONICA MINOLTA bizhub 7115, but I do not know the code developer (ATDC - auto adjust), please let me know. thank you
Posted on Mar 04, 2015
Head temprature
Posted on Oct 05, 2011
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Error c2555 in konica minolta c250
I presume that you want to know what this code means rather than just telling us that you have it!! Search online for "error code c2555 Konica Minolta". Try the fourth hit and onwards.
Jul 11, 2015 | Konica Minolta BizHub C252
Error c252
no such code for bizhub c252
Apr 01, 2014 | Konica Minolta bizhub C250 All-In-One...
Error code c252
Main Motor failure to turn, PROBABLE CAUSES:
1. The main motor (M1) has failed.
Replace M1 (p/n 4038 M101 00). If the problem persists replace PWB-M (p/n 4038 0101 05 for bizhub C250 and p/n 4038 H001 01 for bizhub C252
Jan 27, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica minolta C252 error code C9401
my machine konica minolta C252 is giving the code 9401 how should I resolve and what is
Jan 30, 2012 | Konica Minolta bizhub 250 All-In-One Laser...
Hi please can you help me to resolve my problem with a bizhub 35 it's get me a code number c1183
Hi elfethi,
This code c1183 is commonly caused by trays in your finisher which are not fully inserted into it's slot. It indicates an elevator motor Ascent/Descent Failure. You may want to try follow these steps that help you address the concern:
1. Check the output bin trays which are at the far left side of your machine.
2. Make sure that they are properly installed into the holders.
3. Then refresh your system by turning it off and on.
4.After doing these, the error should be gone.
If you're still getting the error after making sure that trays are properly installed then this means that the issue is already with the sensors or elevator motor. You will need to contact a local repair man.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
Error code c5201 on konica minolta c250
call a service tech but if you are brave... here is the problem http://www.copytechnet.com/forums/konica-minolta/21588-c252-mainmotor.html
Mar 11, 2010 | Konica Minolta bizhub C250 All-In-One...
Error Code C-2152 wen i power the machine at begin this messge was apear c-2152
what model bizhub you have, 350 B/W or some other? cant find this code for this machine. sorry
Apr 24, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta bizhub 200 All-In-One Printer Logo
17,872 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
