Question about Logitech WingMan Force 3D Joystick
Instable work of potentiometers
Pitch control ist extremly asymmetric and jitters a lot. Can I open the device to clean the potentiometers? I removed the drills, but I cannot open the device. Ruedi Heimlicher
Can do. You must first remove the handle; 4 screws, 2 near to the base, 2 upper in the handle. Lift the little tab beneath the handle, and it snaps open. Disconnect the cable from circuit board. Then remove the grey plate around the stick with throttle-scale and 5 allen key screws on it (fake ones, can't remove them!): I simply lifted it, quite hard, with a flat head screwdriver. Raw force seems to be the best option here, no damage done. Then the top cover will lift off.
The grey plate was pretty annoying. More so when you think about that it's there just for good looks - imho failing there - and, what's more important, the effort could have been used to make the mechanics better and at least somewhat accurate. Oh well..
Posted on Aug 14, 2008
How do i clean balance slider and pots?
Sliders are easy where-as pots are not. SLIDERS - provided you insert the "tuner/control cleaner w-lube" extension nozzle past the plastic dust/dirt shield, a few "spurts" of spray, removing nozzle extension and then move control back-n-forth will clean the control. POTS - you MUST shoot tuner/control cleaner in the small slot adjacent to the electrical connections (inside the unit). Removing knobs and spraying the control shaft never works as the shaft-body seal is an extremely tight tolerance. Check here for a view of the pot..
Mar 31, 2015 | Audio Players & Recorders
My right side speakers have stopped working fully. When I set it to only right side, i have sound, but it is extremely low no matter how loud I turn it up. It also doesn't matter if it is set to just...
Could be worn volume-control (potentiometer), dust/oxidizing on wiper-track of same control.
Buy contact-cleaner spray,such as Servisol, McKenic, Kontakt or similar.
If linear slider-type volume, attach tubular nozzle/guide thingy to spray head, squirt cleaner into slot while zooming back & forth (stereo OFF).
This scrubs the contacted surface while cleaning.
If rotary type, remove stereo, open cover, locate volume control, squirt into control while dialling up and down.
Allow a few minutes to evaporate (quick dry spray is best).
Oct 11, 2017 | 2008 Hyundai Elantra
Hitachi ACE follow me red filter light is always on
the red light turns on automatically after 120 hrs of running to remind us for cleaning the filters. once you cleaned the filters and inserted back , then just keep ac in stand by mode, open the remote panel and press the button on extreme right bottom of the remote ( see carefully in the remote, there is very light image of the filter is made along with the button). red light will go off. no need to press the reset button.... enjoy
Apr 03, 2012 | Hitachi Heating & Cooling
CDJ 1000MK2. CDJ pitch control is out of calibration. The pitch plays at zero when the slider is at what should be the slowest setting. How do i reset zero to the middle of the slider.
There is a fine adjust on the pitch control circuit board, however if it is staying at Zero at the extremes then it's time for a new pitch control :(
Jun 25, 2011 | Pioneer CDJ-1000 CD Player
Pot speed and throttle speed beep code is happening. how to get it going again.?
This is a very typical error code when the throttle potentiometer is out of neutral at start up. This is caused by wear or hitting or bending the throttle lever.
In my experience the best way to adjust the throttle pot is to clean it. I usually replace both the throttle potentiometer and speed potentiometer when they fail, cause an error beep, or they have dead spots. You can carefully remove these components by removing the covers and following the service procedures in the service manual. Very carefully take them apart to clean the wiper on the potentiometer with electronic spray contact cleaner (this is not in the service manual; use extreme care and do it delicately).
You can adjust the spring tension on the throttle potentiometer with careful bending.
You can first try to zero out the throttle pot by hand (even it out) and start the scooter to clear the error code. With your left hand adjust the lever left or right and with your right hand turn the scooter on. By trial and error you may be able to get this to work.
In both circumstances you will wind up replacing both components anyway and the fixes I have described are only temporary. Hope this helps.
Jan 01, 2011 | Pride Health & Beauty
I have a technics sl-b2 that hasn't been used in a while. It was my fathers, looks in good shape. I put a new belt on. I'm having trouble with the pitch adj. It seems to not be able to maintain the same...
Switches and other controls that permit the user to adjust the speed on the turntable often become erratic due to oxidation of the metal contacts contained therein. Dust and smoke add to the problem. Cleaning the controls with quality electronics-type contact cleaners usually gives years of happy service. The job is best left to someone familiar with the complete assembly since other finite adjustment potentiometers are often employed and located on the internal circuit board.
Aug 06, 2010 | Technics Audio Players & Recorders
When using my pitch controll the spped does not
the pitch control slide potentiometer needs to be replaced. This is a common failure on the sl-1200 series.
Apr 22, 2010 | Technics SL-1210M5G Turntable
Logitech Wingman Extreme 3D may need cleaning? overly sensitive on mac with X-Plane 9. Gets jitters or sometimes will not recenter. At times seems to work ok. Is it easily cleanable? Is this the...
NO...if you start takin those screws out youll hate it...the SPRINGS ARGGG THERE EVERYWHERE....I have that one and altho im very hard on it it has troubs at time....recalabrate it and see if it helps.
Apr 26, 2009 | Logitech Wingman Extreme 3D Pro Twist...
Stiff Pitch Adjustment
What did you open up? The top of what? If you could be specific, I can direct you.
If your pitch is stiff, try spraying some contact cleaner or similar - DO NOT USE WD40. Use an electrical contact cleaning solution, such as CAIG DEOXIT or CAIG FADERLUBE both work very well, and are good for electronic contacts.
If this does not work, then maybe the pitch control knob/shaft is slightly bent? Any physical damage?
Other than that, there isn't a whole lot you can do, unless you replace the pitch control - Technics Pitch Control.
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 14, 2009 | Technics SL-1210M5G Turntable
Logitech WingMan Force 3D Joystick Logo
890 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
