Question about RCA P52955 52" Rear Projection Television
Low intenstity on green lamp
Red and blue lamps fine green on but very low intensity what could cause
  • RCA Master
  • 8,617 Answers
Sounds like the Green CRT need to be replaced. Thats fairly common with your model with that symptom. If you need a link to where you might be able to get a replacemeny let me know.
Posted on Jun 07, 2008
What causes the picture to have a green tint
there are 3 color cathode in your TV red,green,blue cathode.The red and blue cathode might not working in your set that is why you have a green screen. Open the back cover of your TV you can immediately see the 3 cathode lamp at the back. Clean the lamp first using a clean clothe. Power up you tv and see whether the 3 lamps are lit. If lamps do not light up,check the circuit board where this lamp is connected re-solder all the components in this lamp. There is also an individual screen adjustment for the lamps it is located at the front panel and labeled RGB screen...try this first and let me know how it goes..
Apr 16, 2011 | Zenith E44W46LCD 44" Rear Projection...
Hi I have a Sanyo PLC-XP18 projector and it has recently developed a problem. I was watching a film the other night and the projector just cut out. Now when i try and turn the projector on the the fans...
READY light is green when the projector is ready to be switched on
LAMP is dim when the projector is ON, but goes bright when it reverts to STANDBY.
Check that the lamp cover is fully down and the cover switch is activated
Feb 28, 2011 | Sanyo PLC XP18 Multimedia Projector
Dodge charger fuse box , where the fog lights relay goes ?Thanks
Cavity/ Fuse /Circuits
1/ 20 Amp Yellow/ Left High Beam Headlight
2/ 20 Amp Yellow/ Right High Beam Headlight
3/ 15 Amp Dk. Blue/ Adjustable Pedal
4/ 20 Amp Yellow/ Horn
5/ 25 Amp Clear/ Headlamp Washer - If Equipped
6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
7/ 20 Amp Yellow/ Fog Lamp
8/ 15 Amp Dk. Blue/ Park Lamp
9/ 15 Amp Dk. Blue/ Non ABS Brakes
10/ 5 Amp Orange/ Starter
11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
12/ - -
13/ - -
14/ 25 Amp Clear/ Powertrain Control Module
15/ 20 Amp Yellow/ Injectors, Ignition Coils
16/ 15 Amp Dk. Blue/ Powertrain Control Module
17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
18/ 30 Amp Pink/ Windshield Wiper/Washer
19/ 50 Amp Red/ Radiator Fan
20/ 20 Amp Lt. Blue/ Starter
21/ 50 Amp Red/ ABS Pump Motor
22/ 40 Amp Green/ Radiator Fan High/Low
23/ 50 Amp Red/ High Intensity Lighting
24/ - -
25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
26/ 20 Amp Lt. Blue/ Transmission
27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
if this helps please rate 4 thumbs up.
Jan 21, 2011 | 2007 Dodge Charger SRT8 Sedan
PT50LC14 Color problem with color too much yellow and green no white or blues can not correct is this the lamp again im on why does it seem that I end up replacing the lamp every year (on number 3 now)....
ok,,your problem is not on the lamp itself.,the problem is on your screen controller.the controller is connected on the plyback you can adjust the screen intensity of the red,green,blue cathode..on your screen adjustment.
May 17, 2010 | Panasonic PT-50LC14 50" Rear Projection...
1989 Mercury Tracer Sta. Wgn.
your owner manaul has it. your fuse cover should have chart too.
here is 96 tracer. You also have main fuses under hood.
INTERIOR FUSE JUNCTION PANEL REFERENCE CHART Fuse Fuse Rating Color Protected Components (REAR WIPER) 10A Red Rear wiper and washer motors, heater and A/C relays, daytime running lamps control (Canada), climate control assembly panel illumination HAZARD 15A Blue Front and rear turn signal lamps, turn signal indicator lamp, indicator flasher ROOM 10A (1.9L)
15A (1.8L) Red
Blue Dome and map lamps, safety belt warning chime, ignition key illumination, luggage compartment lamp, vanity mirror lamp, radio chassis (memory), power door lock relay, shift interlock system, powertrain control module (PCM), radio amplifier (memory) ENGINE 15A Blue Fan control (FC) relays, PCM relay RADIO 15A Blue Radio chassis, radio amplifier, remote control mirror, instrument panel illumination (DOOR LOCK) 30A Light Green Power door lock actuators BELT 30A Light Green Passive restraint control module, passive restraint motors (POWER WINDOW) 30A Light Green Window regulator electric drives METER 15A Blue Instrument cluster, backup lamps, rear lamps, speed control system, shift interlock system, safety belt warning chime, passive restraint control module, hazard flasher, PCM (1.8L Canada) WIPER 20A Yellow Windshield wiper motor and windshield washer pump STOP 20A Yellow Stoplamp, horn (1.9L only), rear hi-mount lamp TAIL 15A Blue Parking lamps, cornering lamps, rear lamps, license lamps, compartment lamp, instrument panel illumination (SUN ROOF) 15A Blue Sliding roof panel motor ABS 10A Red Anti-lock brake system (ABS) (1.8L only) (DEFOG) 20A Yellow Rear window defroster HEATER 30A
circuit breaker — A/C blower motor HO2S
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 10A (1.9L)
20A (1.8L) Red
Yellow Heated oxygen sensor (HO2S) CIGAR
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 20A Yellow Cigar lighter knob and element CIGAR 20A Yellow Cigar lighter OBD II 10A Red Data link connector #2 BLOWER 30A Light Green Blower motor relay HORN 20A Yellow Horn (1.8L only)
Aug 10, 2008 | 1989 Mercury Tracer
51 magnavox projection tv-color mixing wrong
The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
Nov 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
RCA P52955 52" Rear Projection Television Logo
43 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
