Question about Jazz DV-179 Digital Camera
Having compatibilty issue for vista running webcam???
When plug camara into puter and try to run webcam.. i get message for
vista have compatibility issues with webcam.. no software found on disd or
Posted on Jun 07, 2008
Me pide que instale el driver y esa camara no traia driver..
Por favor mire si la camara es compatible con su sistema operativo. Una camara puede ser instalada automaticamente en vista y no ser compatible con XP.
Si la camara es compatible mire si los controladores son disponible en el sito de la camera (por ejemplo si la camera es Logitech mire
Alguna camara tiene un cd pequenito escuendido adentro del carton de la caja.
Intente llamar el revendedor si todavia no se soluciona. Si la camera es compatible con su sistema tiene que ser instalada automaticamente, o debe de aver el CD con el software.
Apr 25, 2011 | Computers & Internet
I have this ge easycam ho98064 and i cannot find driver for it for window vista do u know where can i find drivers that work like vista
The drivers can be found here
If the webcam is out of production it is unlikely to have software for Vista - but you can try running it in Compatibility Mode selecting an earlier OS that you know the webcam was happy with.
May 25, 2010 | GE EasyCam Webcam
I hace gigaware pc cam but it doesnt working on my windows vista lap top.Can you help me
Well the gigaware cameras are not made for vista.. but will work if you just play with it.
I would suggest
unplug camera.
restart PC
after the PC has finished booting and is done loading your personal profile
{some computers take 5 min to finish loading all your setting and starting programs}
so give it a few min
plug in camera and walk away
let Vista find the camera on its own... do not force.
It should find it and tell you that it has found it and if it found software for it.
give it 5 min
Hopefully that takes care of your issues..
FYI Not all Vistas can run XP software
only PRO and Ultimate are truly XP compatible
ATCAW Computers
Jun 20, 2009 | Radio Shack VGA PC Camera Webcam
Logitech PRO 9000 installation failure
Click off on the FOUND NEW HARDWARE and continue the installation.
If you have further problems, let me know and I'll assist you to get it going.
Hope this helps. Bud
Feb 01, 2009 | Logitech QuickCam Pro 9000 Web Cam
Veo web cam problem
you can try
have you run the software
and di you make sure it's compatible with vista
Jan 25, 2009 | Veo Connect Webcam
Gigaware pc camara with mic
Try this:
Run it in compatibilty mode.
  • Right click the setup.exe file for the driver and chose properties.
  • Select the Compatibility tab
  • Check the box that says Run this program in compatibility mode and select Windows XP (SP2) from the drop down menu.
  • If you do not have admin rights on the system, then make sure you do not check Run this program as an Administrator at the bottom of the window.
Hope that helps.
May 20, 2008 | Radio Shack VGA PC Camera Webcam
Haveing trouble installing logitech quick cam onto my comuptor thats running windows vista
This problem was caused by a compatibility issue between Windows Vista and Logitech QuickCam Messenger.
Logitech QuickCam Messenger was created by Logitech, Inc..
To search for similar devices that are compatible with this version of Windows, visit the Windows Vista Hardware Compatibility List website online.
However, it’s not totally out of hope for owner of Logitech QuickCam Messenger who has upgraded to Windows Vista. The following hack will use Windows XP driver (a common trick to use non Vista compliant device) to install the webcam in Vista:
  1. Download QuickCam 8.4.8 with driver for WinXP.
  2. Install WinRAR if not already installed yet.
  3. Open the setup installer qc848enu.exe and unpack its contents to a folder. Alternatively, right click on qc848enu.exe and select “Extract to qc848enu\” option.
  4. Insert or plug in the Logitech QuickCam Messenger to a USB port if not already done so.
  5. An “Driver Software Installation” icon in systray (notification area) should appear, which will pop up detailed message if click. It should fail, and “Add Hardware Wizard” dialog window will appear. Choose to install the driver manually by instructing the Wizard to locate and look for the web cam driver inside the Drivers folder under the unpacked folder of the qc848enu.exe setup program. You can use browser button to select the folder.
  6. Windows Vista should grab the XP driver and install it properly.
  7. Download the latest version (10.5.1) of Vista compliant QuickCam software from Logitech to install the software on Vista.
  8. Run the setup (qc1051enu) normally. You may need to skip the detection of webcam near the end of installation process.
Voila, you can now use the Logitech webcam to capture images or use it in conjunction with video chat in IM programs such as Windows Live (MSN) Messenger, AIM Messenger, Yahoo! Messenger, Skype or run Logitech VideoCall.
i hope thist post can solve your problem
Mar 14, 2008 | Logitech Webcam
Logitech QuickCam STX vista compatibility?
Have you updated DirectX?, I'm not sure if Vista has DX9.0 or 9.0c, but you could try and update DirectX before you install the cam software. Also if the cam is usb, did you install the software "before" connecting the cam?, some people aren't aware that usb devices have to have the software installed first, before connecting the device.
Jun 11, 2007 | Logitech QuickCam Communicate STX Personal...
Jazz DV-179 Digital Camera Logo
Top Jazz Cameras Experts
Computer Links
Are you a Jazz Camera Expert? Answer questions, earn points and help others
