Question about Tomtom ONE GPS Receiver
No sound on tom tom one
Can go into sound settings and adjust.
But no sound
  • redtiburon Jun 09, 2008
    Yes i have the same problem. I own a tomtom one 3rd edition and the sound just crapped out on me. I went into change preferences to test the voices and that does not work. I also went to check on the volume level and it is at 75% so i don't know what happened. I pressed the reset button and nothing. I went to the website and downloaded the new updates and still nothing. Any idea on how to fix this??
  • 3 Answers
Hello,<br />you should replace the speaker. I did it on mine (One V3) and now it works fine. You can get speakers at lagrotteauxtresors.fr<br />May be your tomtom will speak again to you!<br />Have a nice day.
Posted on Aug 20, 2010
    Novelist:
  • 158 Answers
Quite common. Faulty speaker ( rob one from an old scrapper laptop theres million of them about now ) . OR ....... on some tomtoms there is an external speaker socket. This socket has an inbuilt switch that switches the internal speaker off when an external speaker is plugged in. Often the contacts on the socket wear a little or get slightly bent and stay OPEN when you unplug the external speaker resulting in NO SOUND . ..... BUT often ( not always ) you still get the tomtom drums on but no sound after that ... a good indication of this probable fault ! You need to open up the tomtom and inspect / clean / bend a little the contacts on this socket. be careful . You need special tools to open a tomtom so dont be silly thinking you can do it without the right tools. GOOD LUCK
Posted on Jun 12, 2008
WITSON DOUBLE-DIN DVD GPS NO AUDIO
This sounds like a setting found in the OPTIONS or SETTINGS portion of your MENU. As the "Safe Driving" banner implies, the voice has been muted. I use a TOM-TOM system which has voice adjusting capabilities. Most likely someone found the voice annoying and shut it down or someone did not want you to be distracted by the voice feature.
This is a little thing to fix and if you can not reprogram it, a BMW Dealer may do a Courtesy fix to build a Relationship with you.
I hope my solution is helpful.
Aug 05, 2012 | BMW Cars & Trucks
If i hit the ride bell, the tom 3 sound will come out also if i hit the crash bell, the tom 1 sound will come out also any idea how to fix it? many thanks
Is the 9ch snake cable correctly connected? TOM 3 should be plugged into the 4th input and TOM 1 should be plugged into the 2nd input. (1- SNARE, 2 -TOM, 3 -TOM, 4-TOM, 5-RIDE, 6-CRASH.........)
Jul 22, 2011 | Yamaha Dtxpress Iv Special Electronic Drum...
How do I change the time on my tom tom
The clock on your navigation device is automatically synchronised with the satellite clocks. You can also set the clock manually, for example when the device is indoors and unable to receive a satellite signal. The default setting is to automatically adjust the clock for the current time zone.
How to change clock settings To select the time format and to set the time, follow these steps:
Open the Main menu and tap Settings.
In the Settings menu, tap Set clock.
Select how the time should be displayed, then tap Next.
When you do not have a satellite signal, you are asked if you want to set the time manually.
Note: Since you need to be outside for your navigation device to receive a satellite signal, you might want to immediately set the time manually. The device will then set the time automatically when you next take the device outside.
Tap Yes to set the time manually or tap No to set your device to update the time automatically using GPS satellites.
Hope this was helpful. Thank you for using fixya.
Jan 26, 2011 | Tomtom GPS
How do I fix low volume on tom tom one
call tom tom.. and meow at them. then tell them the problem while meowing at them in-between what your saying.
if the sound is non adjustable that might ****.
Aug 25, 2009 | Tomtom ONE 3rd Edition GPS
Alarm for speed cameras or red light camers on my tom tom one
1 Change Preference
2 Warn When Near POI
3 Choose Your Red Light Camera POI
4. Set how many yards from it you want to be warned.
5.Choose Sound
Done
Good Luck
Dec 04, 2008 | Tomtom ONE 3rd Edition GPS
My Tom Tom is not talking anymore
Check the sound settings in preferrences to see if you have accidently shut the sounds off.
Jul 13, 2008 | Tomtom One XL GPS Receiver
How to adjust the time on my tom tom one
If you haven't had the unit long, you may want to reset the factory settings. It will bring the unit back to the way it was when purchased. You will have to change any setting you have adjusted, including the time.
Feb 03, 2008 | Tomtom ONE GPS Receiver
Casio Illuminator w-94h
Hold down the "Adjust" button (top left) for three seconds. It won't adjust unless you hold the button down.
Press "Mode" (bottom left) to change what you're adjusting, seconds, hour, minute.
Press the top right and bottom right buttons to adjust the number up and down.
Press "Adjust" again when you're done setting the watch.
To change date, alarm, alternate time, etc, press "Mode" to get to those functions before hitting "Adjust."
I hope that helps.
Jan 17, 2008 | Casio W94HF-3AV Wrist Watch
Tomtom ONE GPS Receiver Logo
812 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
