SIR MY MOTHERBOARD IS NO POWERSUPPLY
I BROUGHT MY MOTHERBOARD AFTER ONE YEAR SERVICING PLZE.
    Problem Solver:
  • 29 Answers
I think check ur smps & power cords working or not..
Posted on Jun 07, 2008
Can I do anything?
Bought a new one, your powersupply probaly is dead.... They afe after a year of abuse.
Nov 02, 2014 | ASUS C300MA 13.3"" HD Chromebook Computer,...
Hello, i need solution for P4VM800M7 Motherboard restart repeated. it can't able to access hard disk and other cd-rom drives,please help me,..
Sir you adviced to check your serial cable or Sata cables if you are getting any where near Booting the windows However there could be the problem with powersupply but is very rear. If you are using Serial cables than you should replace them both of harddrive and CD/DVD Rom. the same problem I have faced When I had Pentium 4 but I already knew what could be the problem and it was of serial cables.
May 06, 2011 | Mercury P4VM800M7 Motherboard
Every time i plug the p4 wire in to the motherboard power stop
There is a short somewhere, either with your motherboard or your powersupply. Test your powersupply to another motherboard that has the 4pin 12volt adapter if you have one. Most likely your motherboard is trying to prevent circuit overload to the cpu.
Jan 15, 2011 | Biostar NF61S MICRO AM2 SE...
Not getting switching on.
Make sure that all the power cables required are connected properly to the motherboard, test the powersupply on another motherboard for example or use a powersupply tester.
Check that the power switch is connected on the right pins on the motherboard and that the switch works.
The motherboard should turn on - spin fans even if there is no memory, cpu or video card installed. So something is not connected properly, or either the powersupply or the motherboard is faulty.
Sep 20, 2010 | Intel Motherboard
DEAR SIR IAM USING COMPAQ PRESARIO SG3053IL MODEL PC WITH FOXCONN 945GZ7MC MOTHERBOARD.PAST IT IS WORKING FINE. BUT RECENTLY WHEN I SWICHETED IT ON, I OBSERVED NO DISPLAY IN MONITOR. COMING TO MY...
I don't think we should directly blame it to the Power Supply, but I can't make it very thorough since you didn't mention whether the system can boot up or not even without display or not. Can you hear beeps or fans' sound when you press the Power button on the computer? Have you tried the monitor on another computer? or have you tried another monitor on your computer? or have you check the video cable? Have you checked the Ram? Have you checked the power supply unit (smps)? Have you checked the Power cables? and many more. If you haven't done all these, do one by one and replace the necessary components respectively and keep trying, if nothing's worthy, then it must be the video card on the motherboard which I would recommend installing a new video card (add-on graphics card). It's also possible that there's problem with the Motherboard bios.
In most cases, the Ram is the cause, once you replaced or checked Ram, you'll be able to find out what exactly is the root of the problem.
These are the basic steps of troubleshooting a display problem.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 15, 2010 | Foxconn 945GZ7MC-RS2H Motherboard
Errore codeoxe0000227
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
Could be bad ram, motherboard, cpu, powersupply, videocard.
Jul 06, 2009 | ASUS P5P800-MX Motherboard
Battery replacement
hi there;
hey try to unplug the power cord from the powersupply now open the case and unplug the powersupply to the the motherboard and then press the reset button on the front for 15 seconds and than connect the motherboard powercable and plug in the powercord back in to the powersupply and try to restart the computer. please tell me if this works and ANY thing that happnes ok best regards mike
Jan 28, 2009 | EliteGroup P4VMM2 Motherboard
Ir 220
E010 codes relate to the main motor or 24v supply through the interlock system. Check for binding in the main drive, or loss of drive voltage.
Aug 26, 2008 | Office Equipment & Supplies
No video
after the reboot is your motherboard and other pc parts like cpu fan still working? might be a faulty powersupply
Jun 08, 2008 | ASUS A7V400-MX Motherboard
Motherboard
ya definetely....i will help u out in solving the problem.
first of all open the side cover of the cabinet.....here i am first instructing you how to check the power supply in the system..
as soon as you open the side cover of the cabinet the remove all the wires coming to the motherboard from the powersupply.then there u can see a 20 pin connector coming to the motherboard from the powersupply.in that bunch of 20 wires shot the green colour wire and the black colour wire...and give the power to the powersupply. if its ok and the fan of the powersupply is working then the smps is ok other wise u need to get it repaired by giving it for chiplevel servicing.....
if powersupply is ok then check whether there are any burns on motherboard if so and even if not u need to give the motherboard for chiplevel servicing.....
Dec 29, 2007 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
