Question about i-mate K-JAM Cellular Phone
Imate not turning on my imate k jam screens says press send to restore factory defaults
  • kairu paul
    kairu paul Jul 05, 2008
    have the same problem. i forgot the touch screen passwd and cannot access the desktop. the keypad shows a timer at 4:30 b4 i can try a paswd again. i have tried hard reset-comm manager+voice +reset key- and it says "press send to restore factory defult,other keys to quit" yet the send key does not respond. what do i do.
I have same problem, K JAM not turning ON
Posted on Jun 27, 2008
Unlocked my imate
Posted on Jun 08, 2008
I need help on restoring my compaq armada e500
Hi Welcome to FixYa!
You could try these steps on restoring your laptop into its factory defaults.
1)Turn off your computer if it is on. Wait for the system to shut down completely. Once it is off, press the "Power" button to turn it back on. Press the "F10" button at the top of the keyboard repeatedly as soon as you see the screen turn on. This will let you enter the setup menu.
2)Use the arrow keys to move between the various menu tabs at the top of the screen. Press the "Right" button until the "File" tab is highlighted, then press the "Enter" button to enter this menu. Here you can make changes to the settings of your computer, or in this instance, restore factory default settings.
3)Use the "Up" and "Down" arrow buttons to move to the "Restore Defaults" option, then press enter. You will see a screen asking "Are You Sure You Wish to Restore System Defaults?" Press the "Y" button to continue. The system will begin restoring your default settings. Do not press a button until a screen says "System Defaults Restored."
4)Use the arrow keys to move down to the "Save Changes and Exit" option and press "Enter." The system will save your changes and automatically reboot your computer. You do not need to press "F10" this time as the computer will start Windows normally. You will see the factory settings have been restored once the system loads.
Hope this could help!
  • Jul 07, 2011 | Compaq Armada E500 Notebook
    I have a samsung u450, I am trying to reset my phone back to its factory settings. How do I go about doing that?
    WARNING: Restoring the handset will permenently Delete All Data, including Contacts
    Note: All locked pictures, videos, ringtones, music, sounds and downloaded content will be permenently deleted when restoring the handset to the default settings.
    To restore the handset to the factory default settings follow the steps below:
    1. While in standby mode, press OK for Menu
    2. Select Settings & Tools (9)
    3. Select Phone Settings (6)
    4. Select Security (9)
    5. Enter the lock code, default password is the last 4 digits of cell phone number, unless it has been changed, then press OK
    6. Select Restore Phone (5)
    7. Highlight Yes, using the navigation keys
    8. Press OK to confirm resetting the handset
    9. Press OK at the re-program the phone screen
    10. Enter the lock code again, default password is the last 4 digits of cell phone number, unless it has been changed
    11. Press OK to confirm restoring the handset to the factory default settings
    Note: Press *228 and SEND after the power cycle to re-program the phone
    Hope this was helpful?
    Jan 23, 2011 | Samsung SCH-U450 Cell Phone
    My Imate couldnt accass the network.Contacts/Calander options couldnt work. No features regarding the network couldnt work. Tried replace the SIM..but no result..please suggest a solution...
    To perform a full reset
    A full device reset clears memory, deletes all data and restores the Pocket PC Phone to its default settings. Programs installed at the factory remain, erasing all data that you have created and programs you have installed. Press and hold the power button, and then use the stylus to press the soft reset button at the same time. Be sure you have backed up all your data in a SD card or on your PC before performing a full reset.
    Mar 09, 2010 | i-mate JAM Pocket PC
    How i can format or restore factory setting to imate jam
    hard reset : keep pressed volume - , on/off button and reset button( from the bottom side of the device) for a few seconds
    Jun 19, 2009 | i-mate JAM Pocket PC
    Why is the red light is always on?
    hi thanks for using fixya!!
    You know what, I had the same problem with my Imate Jama 101, what I did, I click the master clear so that it will return to its default. Please try that just go to program and then you may find the Master Clear, just click it to restore factory defaults. If the problem still coming, you need to send your unit to service tech to check thoroughly the software, maybe it needs some updates and to correct the error.
    Hope it helps, good luck! if you need further, let me know.
    Pls. don't forget to rate my solution positively! thanks!
    Jan 30, 2009 | Computers & Internet
    How do I hard reset my i-mate k-jam do it faster
    To perform a hard reset
    1.
    Press and hold the Comm Manager button and Voice Command
    button on the device.
    2. Keep the two buttons pressed, and at the same time, use the
    stylus to lightly press and hold the RESET button.
    Dec 22, 2008 | i-mate K-JAM Cellular Phone
    Cant press send to restore factory default
    u need to hard reset ur device for factory default ...go to start >> setting >> system >> clear storage....then ur phone will format to default factory setting and also ur all data will be lost...make sure that u take backup of ur data..if u need..
    Nov 26, 2008 | i-mate K-jam Smartphone
    Broken cord screen and buttons not working
    my phone has the same problem.
    After I threw it against the wall...haha
    but its liek cracked on the back near the joint,
    I think a wire tore.
    Apr 26, 2008 | i-mate K-JAM Cellular Phone
    Format phone memroy
    i have imate k jam when i turned on in screen says press the send button to set default factory setting
    Mar 15, 2008 | Cell Phones
    Imate jam boot problem
    i've the same problem my imate jam boots up till imate blue screen than it automatically turn off ... plz experts help me out ... I am in big trouble
    Feb 15, 2008 | i-mate K-jam Smartphone
    i-mate K-JAM Cellular Phone Logo
    109 people viewed this question
    Top i-mate Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Jax Planet
    Jax Planet
    Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
