Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
Maytag Ensignia Oversize cap. plus model mav8757aww
This unit has a bad squeal and I found a white flaky dust like substance on the floor and below the drum spindle. Can you help? Thanks.
  • 2 more comments
  • Anonymous Dec 11, 2008
    Same hear with my MayTag. Squealing with white plastic dust underneath.
  • anita627 Jan 07, 2009
    Mine stopped spinning, and has flaky white stuff under it too. Makes a whining noise in spin cycle.
  • Anonymous Mar 14, 2009
    Same dust. The washer makes a squeal during spin cycle. Not every load though.
  • Anonymous Mar 17, 2009
    same here. now it spins unbalanced
Same problem - stopped spinning, white dust - belt and motor r fine. Can anyone diagnose?
Posted on Oct 10, 2010
Maytag oversize capacity plus washer wont stop filling with water even when I turn it off and un plug it
Ah thats usually a sign of a bad water inlet valve not to costly and not to difficult to repair somes a bad water pressure switch will also cause an overfill however when power is off that will stop the overflow so we know its ur inlet valve
Mar 29, 2015 | Maytag Washing Machines
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
My maytag ensignia washer vibrates/shakes as it rinses
you need to level the unit and then lock the jamb-nuts between the leveling legs and the bottom of the units base structure,use a level and check the top,then level the unit as best as possible,per the floor grade,then tighten the jamb nuts to keep them there
Jul 05, 2010 | Maytag Ensignia MAV4758AWW Top Load Washer
Loud squealing noise during spin cycle.
Please keep in mind, I'm attempting to diagnose your unit without being there and with very little information.
From my experience, I would think you have a bad belt. They get stretched over time and start squealing in the spin cycle. If you don't change it, it will make a noise in every cycle until it comes off.
NOTE.
When changing belt. Check and be sure the pulleys have no play on their shafts. They also go bad. It's better to fix it all now than one to have to repair four or five times this year. Good luck!
Please rate solution
Sep 25, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Squealing during agitation...drum seems to be 'sticking' ....
could be several things if it is an intermittent squeak that goes in time with the agitation then you have bad brakes if it is constant then you may have a bad pump or object in the pump
Sep 19, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
I have a Maytag Atlantis MAVT754EWW machine and there is a black soot like substance being left on the floor under the washer. It smells like rubber - do I need to replace the belt and if so, how do I do...
this black soot like substance is the motor carbon brush dust. i would get the motor brushes replaced and clean off all the dust from the pulleys and also replace the belt as it has been slipping on the dust.
Mar 18, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
White 'dandruff like' flakes blowing from front & back of air con
this stuff is mold and mildew that builds up in the blower and evaporator section of your unit the unit needs to be cleaned out i'm not familar with this particular brand so I cant tell you how to pull it apart but since it is a split system this means the freon lines will most likely have to be pulled loose. you may try removing the covers and vacuming the unit as well as you can and possibly blowing it out with compressed air. aside from that I would recomend alling a qualified service comapny. good luck peyton
Jan 30, 2009 | Maytag MBB1956GES Bottom Freezer...
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
583 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
