Question about Garmin GPS
My garmin nuvi 200w sat nav keeps losing the gps signal. I've done a manual reset and used the webupdater to ensure the software is up to date but still it keeps losing the gps signal
  • 1 more comment
  • dt100 Jun 08, 2008
    Thanks for the suggetions. I use the 200W unit for my job as a dotcom driver for Tesco as it was cheap and if it got stolen I wouldn't be to much out of pocket. Today I learnt that they have fitted a tracker unit to the vans. After fitting the tracker unit I started to have the problem of losing the satellite signal to my sat nav.
    Is this possible?
    I use a 660fm unit in my car and I agree its a lot better unit.
  • Anonymous Mar 19, 2014
    My device keeps losing external power
  • Anonymous Apr 01, 2014
    cannot find gps server
  • 32 Answers
There are a few options for you...
1. Check to see under what kind of conditions the GPS loses it's signal. If there are tall buildings, is a cloudy day etc or even the position of the GPS in the car (does it have a clear sight of view of the sky)... In the latter case, you could change the position of the GPS where it gets a clear view of the sky. For Cloudy days, better have a map ready or preplan the route using mapquest/googlemaps, as nuvi 200 series is especially notorious for these type of situations. For tall building problems, what I do is (c330, not nuvi), just tap the route displayed on the top before the signal gets lost and memorize the next few upcoming turns. Or avoid downtown (where those huge skyscrapers are)
2. If you have enabled WAAS setting in the settings menu (it should be somewhere under "GPS mode", disbale/uncheck it and use the normal GPS mode. WAAS may provide you a more accurate position, but at the expense of some avaialble satellites.
3. Or your GPS may have a genuine problem, then your only recourse is to call Garmin and talk to them. Here's the contact info:
Support North America
(for all Garmin products except Apollo aircraft)
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
Email Product Support: TechSupp@garmin.com
Product Support Phone
1-800-800-1020 (U.S.)
1-888-442-7646 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
Good Luck. Personally I would avoid the 200 series and go with the 3xx, 6xx or even better the 7xx series (if you need all the bells & whistles)
Posted on Jun 08, 2008
Have accidently wiped mapping from garmin sat nav
I can help you fix your Garmin Nuvi 200.
The error message you are receiving about maps is actually a sign of a firmware corruption problem, which just happens from time to time with electronic devices. Updating the firmware of your nuvi will replace the corrupt firmware.
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software. Occasionally a nuvi 200 will also need a Hard Reset (preceded by a favorites backup) to bring it back to 100% operation.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 09, 2010 | Garmin nuvi 200W GPS Receiver
Tip
Garmin Nuvi 265WT Webupdate Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Does your Garmin Nuvi 265WT GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Backup & Restore Nuvi 265WT Favorites here.
Download Nuvi 265WT Manuals here.
Garmin Nuvi 265WT Hard Reset here.
on Apr 19, 2010 | Garmin n?vi 265WT Car GPS Receiver
Tip
Nuvi 265W Webupdate
Garmin Nuvi 265W Webupdate
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 265W GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Download Nuvi 265W Manuals here.
Garmin Nuvi 265W Hard Reset Here.
Garmin Nuvi 265W Favorites Backup here.
on Apr 18, 2010 | Garmin Nuvi 265W GPS Receiver
There is no signal in the sat
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Feb 22, 2010 | Garmin nuvi 200W GPS Receiver
Updates for garmin sat nav
To increase the accuracy of your Garmin Nuvi 205W, I recommend you use Garmin's WebUpdater service to make sure you have the latest software on your device. Software improvements for acquiring satellite lock and location accuracy have been made.
I hope that helps.
Oct 05, 2009 | Garmin nuvi 205W GPS Receiver
Tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Download Nuvi 255W Manuals here.
Garmin Nuvi 255W Hard Reset Here.
Garmin Nuvi 255W Favorites Backup here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
I hope that helps.
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
Garmin Nuvi Hard Reset Here.
Garmin Nuvi 200W Favorites Backup here
on Apr 17, 2010 | Garmin nuvi 200W GPS Receiver
My garmin nuvi has trouble locating satellites and losing signals. What happened? It used to be much more reliable.
I hope that helps.
___________________
Jul 18, 2009 | Garmin nuvi 200W GPS Receiver
Garmin 200w map freezing problems
Not being able to start up and freezing up are signs that the system software or firmware of your Nuvi has become corrupt.
I hope that helps.
Jul 17, 2009 | Garmin nuvi 200W GPS Receiver
My sat nav wont load and start
I hope that helps.
Jul 13, 2009 | Garmin nuvi 200W GPS Receiver
GPS Logo
408 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
