Question about Refrigerators
Temperature Control not working on LG fridge
The temp control button on the fridge/freezer (2 door) are not working. There is nothing lit up on the fridge side and the freezer only has the 2nd and 3rd lights lit up
  • 3 more comments
  • Anonymous Apr 17, 2009
    Refrig fan is noisey due to ice build up. Put a hairdryer on LOW Heat in the bottom freezer for about 15-20 minutes. This will defrost the ice on the fan and get it going again, but it is only a TEMPORARY FIX. Be careful that the hairdryer doesn't get too hot as it will bubble up the plastic on the bottom of the freezer. We have had one defrost control replaced already and are in need of a second one.
  • Steven Hirsch Aug 08, 2012
    Also this problem happened after we lost power so I am not sure if it could be due to a power surge. Another response with the similar situation (except the 2nd and 3rd lights were on in that post) mentioned it was an error code and the thermal fuse in the freezer should be replaced. Perhaps my situation with the 4, 5, 6 number lights on requries the same fix?
  • Anonymous Mar 16, 2014
    The temperature controls do not work for the frizzer side or fridge side. nothing sounds like it is working, the light work the temp control is lit up but if you push the arrows up or down nothing happens it looks like this -
  • Anonymous Mar 17, 2014
    My miele fridge has a little button inside near the thermostat.Should that button be lit at all times and what temperature should the fridge be set at?
  • Anonymous Mar 25, 2014
    Hi. The panel on fridge door just beeped and froze lit up. I reset the fridge it seems working. Is it known error, any recalls or should I get it checked. Thank You
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
It is an error code. The thermal fuse in the freezer section has gone. It has to be replaced. To get by in the short term, uplug the unit for 15 minutes, then plug it back in. It will run until it hits the defrost again (approx 5 hours) Part location is 401A and part number is 6615JB2005C. It is easy to change once you get the back cover off. Plug in part.
Sgt 48
Posted on Jun 07, 2008
LG gn253sqa electro cool- temp. control lights in fridge keep flashing and fridge not cooling so good, help?
This has happened to me a couple of times.The problem is that when the fridge door is opened too may times the warm air of summer will block the cold outlets in the fridge with ice.The cold air comes direct from the freezer and the chamber connecting to the fridge clogs up with ice.What one has to do is completely empty the fridge and freezer,leave open both doors so the the ice build-up can melt.Then after about at least 4-5 hours (very important to stick by this time-frame as I tried a less time,but it did not work.),close both the freezer and fridge doors and switch it on.After about 1/2 hour replace your goods in the fridge.The down-side of this is that you will need the kindness of a neighbor or two to use their fridge to store your food whilst this fix is underway..
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature Control not working on LG french door fridge
These temp control switches are problematic. Replace it.
murf427
Jul 31, 2012 | LG Refrigerators
My lg fridge lrbn20514bk the thermastat is not working on the top control but for freezer is reading 567
This fridge LRBN20514BK with bottom freezer is a piece of junk. Just had the relay on compressor replaced and now the thermostat isn\'t working. Temperature on fridge reads nothing and freezer temperature reading 5,6,7. Then the freezer coils freeze up and no air blowing to the fridge. Ready to take this POS outside and blow it up. Only 7 years old and never ending issues. I will never buy LG again. EVER! LNG - Life is not good! HELP.....so what needs replacing? Thermostat? And of course I have to have repair man come in due to LG not selling parts to customers. Again I call BS
Feb 03, 2012 | LG LRFD25850 French Door Refrigerator
LG refrigerator freezer temperature adjust does not work
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Nov 13, 2009 | Washing Machines
LG Bottom freezer refrigerator Model LFC21760 does not cool
Sep 28, 2009 | Refrigerators
Refrigerator and freezer temperature control
hi. thanks for te question. since you asked the question. has your fridge settled down and cooling sometimes the fridge will set itself
Sep 24, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Temperature Control
call the number in your service manual. they'll ask you to sent the receipr, the silver sticker on the back of the fridge, and a piece of the outlet cord so they know it's not in use. they'll ship you a new fridge. WOW!
May 16, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
1,981 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
