Question about Carrier 38CKC042 Air Conditioner
Carrier 38YRA 042 Fan Motor Problem?
I have Carrier 38YRA042 and the fan does not circulate. I can hear the power come on and something is trying to work but no rotation. The fan motor just gets hot. Is it the fan motor and can replace this myself?
  • Greg MD Jun 07, 2008
    The fan moves freely and does not stick. Could it still be the motor?
    Genius:
  • 2,785 Answers
Plz check if there is anything obstructing the fan movement.if not then the motor is the culprit.
It will be better if you leave it for professional
Posted on Jun 07, 2008
    Master:
  • 638 Answers
YES IT IS THE FAN MOTOR N CAPACITOR THATS TROUBLING.B4 REPLACING IT JUST TRY SOME OILING N SERVICING TO CLEAR THE JAM IN THE FAN IF ANY.IF CLEANING DOES NOT HELP THEN REPLACE THE MOTOR .ITS NORMALLY EASY TO REPLACE.BUT TAKE CARE ITS REMOVED FROM ELECTRIC SOCKET N DO IT CAREFULLY.WISH U SUCCESS.
If my solutions helped you in any way, kindly take a moment to "Accept" this solution. Thanks in advance
  • hemant somaiya
    hemant somaiya Jun 07, 2008
    yes it will be motor for sure . let me know for further assistance
  • hemant somaiya
    President:
  • 2,712 Answers
Every air conditioner is equipped with at least two motors, the compressor and the fan motor. It is possible for the fan motor to be defective and the compressor to be running. If this is the case the unit will appear to be running and may even sound "normal" but no air is blowing out the front or back of the unit. If, after removing the cover of the unit you discover the fan blade is very stiff and difficult to rotate, the fan motor should be replaced. If the fan blade turns freely the circuit powering the fan motor will require electrical troubleshooting. It will be necessary to have a qualified technician locate the cause of the problem, which may be either a problem with the capacitor, the selector switch or the motor itself.
  • Swilin Sampson
    Swilin Sampson Jun 07, 2008
    If you have no prior experience, I'd say it is better you contact a professional repairman. It may cost a bit extra, but will be worth it in the long run..
    Brigadier General:
  • 6,966 Answers
Other then the fan motor itself, another possibility (most likely) is the starting capacitor. This often looks like a canister with two terminal on one ends. The purpose of the capacitor is to provide the initial push to kick start the fan motor.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jun 07, 2008
    Hi again,
    Yes, it could still be the motor, however, more often than not (unless motor is burned) it would be the capacitor.
38CKC060 Carrier. Outdoor unit-fan does not spin, noise and very hot inside the cage!
It sounds like your fan motor is burnt up. If the noise you are hearing is coming from the motor itself, then it's going to have to be replaced. One way to check this also is to turn the unit off and try to turn the fan blades by hand, if you cant get to it, then use something skinny and long enough to drop through the opening on top. If there is any resistance, than its difinitly a bad motor. If the noise you are hearing is coming from the compressor, then your fan motor still might have a chance and only needs a capacitor which is a round or oval part inside the units electrical compartment. Depending on how mechanically inclined you are, it is possible to fix these yourself. Just a warning though, if your fan hasn't been running and the compressor has, it can or could burn up the compressor also. This is another reason why it can be hot inside the cage. Your compressor will go into internal lockout if it gets to hot and will not come back on until it cools, but it can only handle so much. Hope this points you in the right direction and good luck!
Aug 04, 2010 | Carrier 38CKC060 Air Conditioner
The freezer motor starts whenever I close the freezer door. It is loud and sounds like something is hitting a fan.
The evaporator fan motor inside your fridge is constantly trying to keep the temperature you have set it to. when the fan is on it circulates the cold air from your freezer in to your fridge. if you hear a banging noise it is cause by the fan hitting a build up of ice. this can be caused by a clogged drain pan or tube, not allowing water build up to be drained, or you could also have a defrost heater issue in which case you would have a large build up of ice near your fan. you can access the fan motor by removing the two panels at the back of the freezer, once removed you will be able to see whether or not there is a ice build up.hope this helps you
Thanks.
Oct 11, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Carrier AC fan not working right
it sounds like the capacitor is shot there is usually a duel capacitor one side is for the compressor and the other side is for the condensor fan motor if it is bad the motor will over heat and turn off on internal overload
Aug 25, 2009 | Heating & Cooling
AC fan stopped
Sounds just like a seized bearing on the fan motor. They can be repaired but it's usually less to purchase a new motor. Now all you have to do is figure out how to get the motor out. To get you started, you need to partially disassemble the top portion of the condenser cabinet. This will give you access to the fan motor assembly. Which model do you have? That information will be on the nameplate which is on the side where the electrical enters the cabinet. That reminds me, always pull disconnect and trip breaker before starting.
Jun 19, 2009 | Carrier 38CKC060 Air Conditioner
Ac for 5th wheel doesnt work
Do you hear the compressor clicking or trying to run?Or just hear the fan motor?
Jun 02, 2009 | Coleman Mach III Air Conditioner
Fan not working
the humm could be the contactor check the breaker for the out side unit or see that you have power at the unit dan
Jul 17, 2008 | Carrier 38CKC036 Air Conditioner
Compressor not doing much
I am assuming that you are talking about a central ac unit. On a central air unit the outside fan must be running whenever the compressor is. If it's not the compressor will shut off from overheating withing minutes. First you need to shut off the unit for several hours and let it cool completely down. Then turn it on briefly to see if the compressor starts and see if the fan tries to start.( I am assuming the compressor starts and runs.) If the fan won't start try testing the capacitors. There are usually two one for the fan one for the compressor. Sometimes there will be one combo one. Mark the wires and remove the capacitor. Get it tested and if bad replace it. This will probably do the job. If not test for current at the fan motor. Also test to see if it turns freely. The motor may need to be replaced. This will run about $50. The capacitor should always be replaced when the motor is changed anyway.
Jul 09, 2008 | Carrier 38BRC060 Air Conditioner
Caerrier weather maker 8000
Your cooling coil may be frozen. Turn the fan on and the cooling to off so air will circulate to defrost the coil. After air circulation is re-established in about 90 minutes turn the cooling back on. Operate the system with the fan on when in the cooling mode should eliminate the freezing problem.
May 26, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 38CKC042 Air Conditioner Logo
444 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
