Question about Nikon Coolpix L11 Digital Camera
The lens on my camera got bent
I tried using "steady pressure applied to the back of the camera with the lens on a towel on a table to ensure it remains parallel to the camera body" like another user suggested. So far it isn't working. PLEASE PLEASE PLEASE PLEASE help me I'm leaving for vaction tomorrow!
    Scholar:
  • 37 Answers
Hello
there are tiny plastic gears inside and may have chipped or a small piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Posted on Sep 02, 2008
Camera lens does not retract and shows camera error #e45
It appears that the error code is due to your lens being stuck. In many small digital cameras this is caused by a drop or jar to the camera and the lens being knocked off of its tracks. Make sure your camera battery is fully charged. Power the camera off. With the camera is laying flat on its back on a table or other level surface, see if the space or gap around the lens is an even amount. If not, it is probably out of its guide track. Holding one hand cupped, take the camera, face down and lightly strike it into the cupped palm of the other hand. That should dislodge any sand or grit. Then, holding the camera in one hand, grasp the lens gently and apply a light pressure toward the side with the larger gap around the lens. Do not apply a lot of force. Do this gently. If you hear a light "click" the lens should be back in place. Try powering the camera on to test the results. If it still doesn't retract, power it back off and lightly rotate the lens back and forth with you hand. Do not apply a lot of force! Again, if you hear a click, the lens should be back on its tracks. Power it up to test it. If that doesn't do the trick you probably need to take it to a repair shop or replace the camera.
Dec 27, 2014 | Kodak EasyShare LS743 Digital Camera
Fungus of lens
use a clean towel with damn water gentely apply pressure to clean
Jun 08, 2010 | Pentax *IST 35mm SLR Camera
MY LUMIX CAMERAS LENS WON'T CLOSE
Try rapping the camera bottom smartly against the heel of your hand to try to free it. If not, try rapping it less smartly on a harder surface, like a table covered with a bath towel. Do not rap the lens itself.
If this works but only some times, apply graphite lub to the sides of and extended lens at the collapsing joint sections, sparingly. Then get it to collapse and open a few time and wipe off lens with dust cloth.
If still no luck, sell yours to a repairman in an ebay auction, keeping your accessories. Then by a working replacement without accessories cheap.
Dec 15, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Work issues
Jammed or off the track, try rotating the lens if it rotates out, maybe the middle coller part, or take it apart and see if you can see the fault. No other options, sorry. SO many lens problems with this design, too bad.
Jun 11, 2008 | Samsung Digimax S500 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Lens stuck
I just wrote a warning about these "telescoping lens" cameras, You need to get the lens back on track. maybe steady pressure, applied to the back of the camera with the lens on a towel on a table to ensure it remains parallel to the camera body.
May 12, 2008 | Nikon Coolpix L11 Digital Camera
Error 18
The "E18" error code indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 18
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Error 18
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Error 18
Aug 29, 2005 | Canon PowerShot A310 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
