Question about Danby DDR600R Silhouette Dehumidifier
Water tank still gets full when connected to floor drain
I connected a garden host to the outlet and the other end to the floor drain but water still getting collected in the water tank and it gets full just like the drain is not connected. I can see water sipping out from the outlet to the floor drain but water also drop into the water tank.
  • 828 Answers
Check the fitting where you connect the drain hose to. It may have a plastic seal that must be cleared out in order to use the hose drain. The plastic seal can be easily punched out.
Posted on Jun 08, 2008
There is no seal on the host and water is dripping out into the drain but still water is being collected in the tank.
Posted on Jun 09, 2008
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
I am thinking of buying the ADER50LP. Can a drain it directly to a floor drain, by-passing the bucket? If so, does it have an external spigot or will I need a hose? Are ADEW50LP and ADER50 LP identical?
You will need to use a drain hose that is no longer than 5 feet. Using a hose relies entirely on gravity. So, the hose must slope downward with no kinks. A short 5' section of Garden Hose works well. The female coupling end attaches to the dehumidifier. It's a very effective way, not to having to stop and drain the tank time it's full.
The ADEW50LP, is a low Temperature Unit, which designed for basement applications.
The ADER50LP, is a standard unit. Used for all applications, other than a basement.
Both have the external drain feature and the same water extraction capacity.
Hope this helped you. Please let me know.
Jun 21, 2011 | GE Ader50ln Dehumidifier
Hello, I need a dehumidifier of 50pint or more that stop when the humidity level is reach and will restart when is too high. I look for a lot of brand and model and I cannot find one thanks for your...
The fifty pint capacity might be a challenge ... think about this ... 6 + gallon tank @ 7+ pounds per gallon ... 42 pounds of water to drag from the dehumidifier to the drain? Who is going to do that?
All dehumidifiers run at some % of humidity (via Humistat), (like you are asking about) i.e. come on at some % above the setting and go off when the setting is reached. I suggest you find one that has a standard one or two gallon tank that also features a hose connection in the tank. Run the hose from the tank to the floor drain in your basement or a drain near what ever room you are trying to dry out. When you connect the hose --- you will have to put a hole into the fitting on the tank for water to flow. The idea of the tank is that the machine will run on the setting until the tank fills up ... at which time the tank full switch will not allow the machine to run again until you dump the water (and you want to drag a 6+ gallon tank, 42+ pounds, around?) . If there is a hose attached, the tank never fills up.
Some dehumidifiers feature a pump to which will pump the water to a near-by drain. You may be able to rig such a setup yourself using a small pump like a fish pond pump or similar.
You may want to consider using two dehumidifiers (with or without hoses) rather than one BIG machine. I run two machines from a major USA retailer (one in each end of the basement) and they run into the near by sump and the system works fine @ my house.Thanks for your
Thanks for your question @ FixYa.com
Jun 05, 2011 | Dehumidifiers
/my dehumidifier has a hose attachment on the back. how does that work?
The hose attachment is used in place of the water collection bucket, to drain the water directly into a floor drain or a sump pump holding tank. A garden hose is connected to the "hose attachment" and run to the floor drain or sump pump holding tank. However, it will not drain UP, only DOWN.
Hope this helped.
Mar 20, 2011 | Amana Dehumidifiers
How do I connect the hose? lost manual
If you asking about the drain hose. There's what looks like a hose hookup on the back of the unit, down near the floor. It's probably plastic and is threaded to accept a garden hose. You may have to carefully knock out the opening of the plastic connector, to allow the water to drain into the connected hose. The hose then should go to a floor drain or sump pump. Keep in mind, the water will not drain up.
Feb 08, 2011 | LG LHD65EBL Dehumidifier
I have the hose hooked up to the back but it keeps filling the tank and shuts off when it's full ,how do you just use the hose to drain
I believe you have to put a plug to drain that drains into the tank ,then it can only drain out the hose.
Jul 14, 2009 | Maytag M7DH65B2A Dehumidifier
Water from LG 30 pt dehumidifier drains into reservoir instead of running through garden hose into floor drain like it is supposed to. Have checked...no obstructions to garden hose. Very frustrating...must...
(assumming you are not an idiot, like the other solver suggested) you may very well have it connected to the right spot, many of these units, are not balanced well, (or are balnaced all to well, depending on how you look at it) The imbalance, basically makes the water drip to the front, instead of the back. Try to put something under just the front of the machine, to tilt it back, ever so slightly. Good luck
Jun 19, 2009 | LG DH30 GoldStar Dehumidifier
Danby continuous water flow will not work on a dehumidifier it still fills the bucket
Please try the following:
1) Remove the bucket.
2) You will notice a round outlet/spout where the water drips from into the bucket.
3) Remove the plug from the backside of the unit (you will now see a hole to the bucket area).
4) Feed a hose through the hole from the back and attach the end of the hose to the round outlet/spout.
5) Place the other end of the hose on a floor drain outlet.
6) Put the bucket back into the unit.
When the unit is turned on, the water will now flow through the hose instead (into the floor drain). When you want to use the bucket again to capture the water, you will need to remove the hose.
I hope that helps.
Apr 25, 2009 | Danby DDR601 Dehumidifier
Problem with draining water through hose
I bought one of the FDL70S1 Frigidaire dehumidifiers today for my shop, and found that the $5 hose I bought to drain it through the floor wouldn't tighten down completely, allowing the hose to twist and wobble, a sure indication that it was not water tight. Simply adding a second washer, as described in another answer here, allowed me to tighten the hose sufficiently to produce a tight fit with no play between the hose and the dehumidifier. It hasn't leaked. I know it is a threads-per-inch issue, and I am stumped as to why Frigidaire would supply these units with a different thread pitch than the standard GHT (garden hose thread) 3/4" - 11.5 tpi. The threads on the unit appear to be 3/4 NPS - 14 tpi. Go figure!
Jun 03, 2008 | Frigidaire FDL25P1 Dehumidifier
Danby DDR600R Silhouette Dehumidifier Logo
661 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
Colin Stickland
Colin Stickland
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
