Question about Canon PIXMA MP160 All-In-One InkJet Printer
Cannon pixma mp170
Same problem of paper pulling to the right only and then jamming, tried everything their is nothing stuck in printer, i tried heavier type of paper.
tried all the maintenance advised
  • 34 Answers
Hi!
your rollers that pulls in the papper can be worn ,printer needs a service
i hope thiswill help:)
Posted on Jun 09, 2008
I have a cannon Pixma Mp495. THis morning some paper that was wrinkled went through it when it was printing. THere was not any paper left in the printer. I did pull a sheet out the top that was stuck...
I believe that you tried to turn the printer off, then on. Did you? If so, and the problem persists, I belive that the jam sensor became damaged.
In a last instance, you can turn off the printer and see if you can turn a little (with your fingers) the roller that pulls the paper.
Jul 20, 2011 | Canon PIXMA MP495 InkJet Printer
Hi I have a cannon mp470 and it will not pull paper through to print. It either doesn't catch at all, or it will jam to one side.
Hi
There is something stopping the paper feed process. Try the following
1. Check and make sure nothing is fallen inside the paper tray
2. Remove anything stuck
3. Even if you are not able to see anything stuck tray to use a air blower and blow air in the tray this will remove anything stuck.
Jul 15, 2011 | Canon PIXMA MP470 All-in-One Printer
I am having cannon pixma mp180. it said check printer and give the number5100
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 17, 2010 | Canon PIXMA MP170 All-In-One InkJet...
My cannon mp170 says paper jam and wont print. there is no paper jam at all. i checked myself! help me!
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Feb 16, 2010 | Canon PIXMA MP170 All-In-One InkJet...
My canon pixma MP170 keeps telling me that ther is
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Dec 30, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Canon MP170 Paper Jammed
Jul 29, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Printer keeps saying paper jam..there is no paper jam
You can also try using a rubber eraser as the rollers are going. Just take a pencil and lightly rub along the length of the rollers as they are feeding. This should remove the film that clogs the rollers surface.
Dec 21, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Alarm is flasing
i think you have to open the printer and check for any parts dislocated or broken
Mar 16, 2008 | Canon PIXMA MP170 All-In-One InkJet...
'Paper jam msg' when there's nothing stuck in there...???
Sorry can't help. Maybe you have damaged one of the paper jam sensors?
Try the link below which is the manual
http://alpha03.c-wss.com/inc/ApplServlet?SV=WWUCA900
Dec 29, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
59 people viewed this question
old marine
old marine
