Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool ultimate care 2 water wont stop filling...over flowing everywhere.
Hi! I just bought a used washer. The previous owner said there was no problems with the washer but when I set it up and started it the water woj't stop filling up! It over flows everywhere and the agitator won't come on. I have to put the setting on spin for the water to drain. Please help I have loads and loads of kids clothes to wash! I'm not sure where to find the pressure switch or level control.
  • Tanz Ili
    Tanz Ili Jun 09, 2008
    Thanks for your helpful response. I opened the top control panel and the clear hose was disconnected. I then blew in it to ensure it was clean and air blew inside the machine. I thought it was good but when I connected the hose the problem wasn't solved. What else should I do? The washer still over flows and when I turn the load knob its alittle difficult and makes no clicking sound. I was thinking it might be a burnt out fuse. I would appreciate your help greatly. Mahalo,
    Tanz
  • 868 Answers
Your level switch hose has come loose.first open the display panel to check in back of water level switch,and look for a hose that is not attached to the back of it.
Posted on Jun 07, 2008
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont stop filling with water
You need to replace the fill switch its not sensing or stopping the w ater. It is fairly simple. Remove the plastic molding on the ends. Remove two screws holding down the control panel. The fill switch is over to the left, and has a clear tube attached to it. Remove tube and wires, lift tab keeping it from turning, turn 45 degrees and remove switch. Replace and test in all positions. Good luck whirlpool is a good brand.
Jul 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Fills up with water and wont stop
Bad Preasure valve comes to mind first and formost it acts like a level sensor balanceing the size indicated for fill.
Feb 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water doesnt stop
defective inlet vavle or ( FILL VAVLE ) replace..onthejob
Feb 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water flow into washer will not shut off
It could be the valve or the fill sensor. You can Google the washing macine brand and it will give you a diagram of what parts the washing macine has and does Also try RepairClinic.com. .
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Yes if its filling slow do to a blockage in a screened hose it will .If it never stops filling and doesnt over flow than its syphoning the water and you need to elevate thr drain hose higher than the water level and it will kick into wash. Please rate This !!
Jul 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
207 people viewed this question
Dan Webster
Dan Webster
Sal De
