Question about Motorola Mobility L6 Cellular Phone
Mms setting had already successful..but..still got some problem
I am maxis user, i can sd mms 2 myself, and also others hotlink user but i couldn't send mms to digi user..my phone show that i had sent successful, but the digi recipient couldn't receive anything..help!!
    Brigadier General:
  • 7,752 Answers
That is an issue with te provider
Posted on Jun 19, 2008
Straighttalk settings for blu phone
try this one
had the problem going through forums trying to find the settings that work for my phone but to no success but I finally figured it out and I'm posting it on here just in case some one else has my same problem.
I had to create two separate APN's one for internet and one for MMS. Settings are as follows:
Internet:
Name: Straight Talk Internet
APN: att.mvno
Proxy: proxy.mvno.tracfone.com
Port: 80
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: Not Set
MMS Proxy: Not Set
MMS Port: Not Set
MCC: 310
MNC: 410
Authentication Type: PAP or CHAP
APN Type: Internet
APN Protocol: IPv4
Bearer: Unspecified
MMS
Name: Straight Talk MMS
APN: att.mvno
Proxy: Not Set
Port: Not Set
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: http://mmsc.cingular.com
MMS Proxy: 66.209.11.33
MMS Port: 80
MCC: 310
MNC: 410
APN Type: Internet+MMS
APN Protocol: IPv4
Bearer: Unspecified
Do not forget to create two separate APN's!!!!!
goodluck
Jun 23, 2014 | Blu Cell Phones
I cant activate my MMS
Title: MMS settings
For Hotlink GPRS Activation
Press *133# to activate your Gprs & MMS
For the setting
1. SMS "GPRS "BRAND" "MODEL" and sent to 22333 example "gprs nokia n70"
2. SMS "MMS "BRAND" "MODEL" and sent to 22333 example "mms nokia n70"
Manual WAP Settings
? On Desk, tab Control Panel -> Internet setup. (or similar)
? Tab New access pt. and tab No, then tab Next and key in the following:
Connection name: Maxis GPRS / Maxis 3G
Data bearer: GPRS
? Tab Next
Network type: IPv4
Auto-retrieve access point: (Unchecked)
Access point: net / unet
? Tab Next and key in the following.
Prompt password at every login: (Unchecked)
Username: maxis
Password: wap
? Tab Next then tab Finish and OK to complete the setup.
? Homepage: http://wap.maxis.com.my/wml/index.wml
? Session Mode: Permanent
? IP adress: 202.075.133.049
? Login Type: Automatic,
? Authentication Type: Normal
MMS Settings
May 12, 2011 | Computers & Internet
I purchased a Motorola KRZR2 from Ebay, and although it works great, it cannot connect to the AT&T web. AT&T told me that since I didn't buy it from them, they will not help me out. What are my...
Your WAP and MMS need to be set up.
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
4. Click Web Sessions
5. Click [New Entry]
Fill in the following fields: (some of the fields may already be setup)
Homepage: http://home
Service Type 1: WAP
Gateway IP 1: 10.250.250.250
Port 1: 9201
Domain 1: <leave this blank>
Service Type 2: WAP
Gateway IP 2: 000.000.000.000
Port 2: 8080
Domain 2: <leave this blank>
DNS 1: 000.000.000.000
DNS 2: 000.000.000.000
Timeout: 5 minutes
CSD No. 1: <leave this blank>
User Name 1: <leave this blank>
Password 1: <leave this blank>
Speed (Bps) 1: 9600
Line Type 1: ISDN
CSD No. 2: <leave this blank>
User Name 2: <leave this blank>
Password 2: <leave this blank>
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name: <leave this blank>
Password: <leave this blank>
Click Done
Click Menu
Select "Set Default"
Then...
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
Homepage: http://mmsc.mobile.attwireless.net
Gateway IP: 10.250.250.55
Port 1: 8080
Domain 1: blank
Service Type 1: HTTP
Port 2: 0
Domain 2: blank
Service Type 2 WAP
Time out: 5 Minutes
CSD no 1: Blank
Username: 1: blank
Password 1: blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: blank
User Name 2: blank
Password 2 blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name:blank
Password:blank
Press the left soft key 4 times to return to the main menu.
Scroll to and select Messages.
Press Menu.
Scroll to and select Inbox Setup.
Scroll to and select MMS Message Setup.
Scroll to and select Server Info.
Scroll to "AT&T MMS", then press Menu.
Scroll to and select Edit.
Validate the following settings:
Service Name: AT&T MMS
Server Name: http://mmsc.mobile.attwireless.net
Web Session Name: AT&T MMS
Jan 14, 2010 | Motorola Mobility KRZR K1 Cellular Phone
WHAT DO I DO IF A CUSTOMER CAN ACCESS THE WEB BUT CANNOT SEND OR RECEIVE MMS ON HIS KRZR PHONE?
Check the MMS settings...
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
Port 1: 8080
Domain 1: blank
Port 2: 0
Domain 2: blank
Service Type 2 WAP
Time out: 5 Minutes
CSD no 1: Blank
Username: 1: blank
Password 1: blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: blank
User Name 2: blank
Password 2 blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name:blank
Password:blank
Press Menu.
Oct 14, 2009 | Motorola Mobility KRZR K1 Cellular Phone
No internet connection it is a unlock phone from t mobile to att
Hai, Go into Web Sessions and change the Internet and MMS settings to those appropriate for AT&T. If the T-Mobile settings are locked, create new settings and make them the the default. Each carrier has its own setting but those settings are the same for any phone on that carrier's network.
Browser Settings (in web sessions): ---------------------------------------------------------------------------------------------------- Name: Cingular Wireless Internet
Homepage: http://device:home or http://device.home Service Type 1: WAP Gateway IP 1: 66.209.11.61 Port 1: 9201 Domain 1:  Service Type 2: WAP Gateway IP 2: 000.000.000.000 Port 2: 9201 Domain 2:  DNS 1: 000.000.000.000 DNS 2: 000.000.000.000 Timeout: 15 minutes CDS No. 1:  User Name 1:  Password 1:  Speed (Bps) 1: 9600 Line Type 1: Modem CDS No. 2:  User Name 2:  Password 2:  Speed (Bps) 2: 9600 Line Type 2:  GPRS APN: wap.cingular User Name: WAP@CINGULARGPRS.COM Password: CINGULAR1 ------------------------------------------------------------------------------------- MMS Settings (in web sessions):
Homepage: http://mmsc.cingular.com Service Type: WAP Gateway IP 1: 66.209.11.61 Port 1: 9201 Domain 1:  Service Type 2: WAP Gateway IP 2: 000.000.000.000 Port 2: 9201 Domain 2:  DNS 1: 000.000.000.000 DNS 2: 000.000.000.000 Timeout: 15 minutes CDS No. 1:  User Name 1:  Password 1:  Speed (Bps) 1: 9600 Line Type 1: Modem CDS No. 2:  User Name 2:  Password 2:  Speed (Bps) 2: 9600 Line Type 2:  GPRS APN: wap.cingular User Name: WAP@CINGULARGPRS.COM Password: CINGULAR1 ------------------------------------------------------------------------------------------------ MMS Settings (in Message Center>>>Message Setup>>>MMS Message Setup): Hide fields: Cc.Bcc.Priority Autosignature: Download: Automatic Filter: Expire After: 5 days Reply Type: MMS Size Limit: None Server Info: Cingular MMS>>>Select Server Info>>>Current Server>>>New: Service Name: Cingular MMS
Server Name: http://mmsc.cingular.com Web Session Name: Cingular MMS.
Some settings may not have to be entered for all phones because they are set at the default for those models. You can leave the User Name and Password fields blank.
Aug 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Can't receive picture message
Wap
Homepage: http://device.home
Service type: WAP
Port 1: 9201
Domain 1:
Service type 2: WAP
Gateway IP 2:
Port 2:0
Domain 2:
DNS 1:
DNS 2:
Timeout: 10min
CSD No 1: cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif+14152441012cb_transparent_r.gif
User name: 1: WAP@CINGULAR.COM
Passwrd 1: CINGULAR1
Speed: 1: 9600
Line Type: ISDN
CSD No 2:
User name:
Passwrd 2:
Speed: 9600
Line Type 2: ISDN
Passwrd: CINGULAR1
MMS
Service type: WAP
Port 1: 9201
Domain 1:
Service type 2: WAP
Gateway IP 2:
Port 2:0
Domain 2:
DNS 1:
DNS 2:
Timeout: 10min
CSD No 1:
User name: 1:
Passwrd 1:
Speed: 1: 9600
change these settings in your phone under gprs and mms
May 24, 2009 | Cell Phones
I9 wap/gprs & mms settings for O2
First you have to make 2 data accounts,
1 for wap,
1 for mms.
Press service,
Data account,
GPRS, ok,
Pick any one of the settings because you are going to change it,
Press edit.
account name edit to O2 WAP GPRS,
APN to payandgo.o2.co.uk,
user name to payandgo,
password is password,
authentication type normal,
after each one if done is the option press it. this is the setting for wap internet.
You have to do the same again to make a new data account for the mms. the settings for this is
account name O2MMS,
APN payandgo.o2.co.uk,
user name payandgo all others same as before.
Now you have 2 new data accounts you need to set up wap.
press service, wap, settings, edit profile, sim 1 or 2 which ever you are using,
select the O2 WAP GPRS account that was made earlier,
press ok. press edit profile,
rename profile is ok it is O2 WAP GPRS,
edit home page to http//wap.o2.co.uk,
set data account to O2 WAP GPRS,
connection type wap, IP address 193,113,200,195
user name payandgo,
press back and activate profile.
you should be able to get on to o2 homepage now.
To get mms
press text, mms, mms settings, server profile, sim which ever you are using 1 or 2 ,
select the O2 MMS made earlier, edit profile, rename profile is 0k should be O2 MMS, home page is http//mmsc.mms.o2.co.uk:8002,
data account is the O2 MMS you made before,
MMS IP address 193,113,200,195
user name payandgo,
select back when all settings are entered and select activate profile. this should be it.
This works OK for me.
Mar 23, 2009 | Dual Electronics CECT P168 Cellular Phone
RCA DRC8300N DVD Recorder / VCR Combo manual
Gary. The DRC8335 User Manual is no longer available on Thompson's official support site. But fortunately a few of us downloaded it a year or more ago before it was pulled!
I tried uploading the manual to Fixya several times including just a short while ago. It seemed to upload successfully, but after performing a Fixya search it's still nowhere to be found, just like many others I've uploaded in the past.
But don't worry! You can download it NOW from my personal User and Service Manual archive on OwnerIQ using the hotlink below.
OwnerIQ encrypts all filenames within our personal folders for security purposes which ends-up making them rather unreadable. For this reason, please rename it back to my original filename appearing in blue in the hotlink just below when the download completes
Respectfully, Mike Adams
mikeadams110@yahoo.com
RCA DRC8335 User Manual (PDF 1.92mb) <---click here to begin immediate download
Nov 07, 2008 | RCA DRC8300N DVD Recorder/VCR
Iphone Q380A
how to activate GPRS and MMS
Sep 04, 2008 | Apple iPhone Smartphone
I dont know how to set up my phones MMS and GPRS.
YakYak, Go onto your network providers website register on there, and there should be a option once you have signed up, confirmed your email address etc... You should Be able to set it up for MMS & GPRS, hope this works and good luck.
Ben
Oct 12, 2007 | Motorola Mobility L6 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
81 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
