I have no sound from my car speakers - Audio Players & Recorders
    President:
  • 3,130 Answers
Is it just a head unit typr receiver or is there am amp connected to it?
Posted on Jun 08, 2008
I have a 2000 oldsmobile alero and I can't get sound out of my rear speakers good speakers and connection just no sound
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
2001 Oldsmobile Alero Car Radio Stereo Audio Wiring ...
www.modifiedlife.com/2001-oldsmobile-alero-car-radio-stereo-audio-wi...
Easy Plug and Play Wiring Adapter. ... 2001 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram ... If you can't find your car audio wire diagram, car stereo wire diagram or car radio ... Right Rear Speaker Positive Wire (+): Dark Blue ... olds alero and I have replace the stock stereo and have found that the sound out put ...
Request a Oldsmobile Car Radio Stereo Wiring Diagram
Jan 21, 2016 | Oldsmobile Cars & Trucks
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
Which are the best speakers for my car - swift VDI?
It depends on your musical tastes, but for quality, I recommend Infinity or JBL. They are worth the money. If you don't want to buy an additional amplifier, get the most expensive speakers that you can afford. That way, they will make your deck's internal amplifier sound the best with its limited power output.
Jul 20, 2014 | Car Audio & Video
Hooked the stereo up and got power to but no sound coming out speakers but i try home speaker it work so what did i do wrong ?
if im understanding correctly what you wrote. you hooked up the headunit to the car and no sound from speakers, then you hooked up a single house speaker up and that speaker works fine. the Ohms on the car speakers might be too high, but most likely sounds like the wires to the speakers are bad.
Nov 21, 2013 | Cars & Trucks
Just removed stock front speakers from 2000 Jeep Grand Cherokee with premium sound. Speakers were working, but my son wanted new ones. Installed Infinity 9632cf speakers and we're barely getting any...
A lot of companies are using 2 ohm speakers for stock speakers. This means they are more efficient (sounds strange that a stock speaker is efficient). The stock amp may not be able to put enough power out for these to sound good. You may end up needing a new system.
Sep 01, 2011 | Infinity 9632CF 6" x 9" Coaxial Car...
How do you install pioneer TS-163p speakers in car?
remove old speakers... then replace with new ones...
depending on the vehicle make and model... this is easy to do.
Oct 06, 2010 | Pioneer TS-163P Coaxial Car Speaker
On sound
no sound? did the old speakrs hve sound? sheck the connctions on the speakers and bhind the radio. also make sure the speaker is nt grounding out on the door where he wires plug into the speaker. take the speaker out and see if it works...if still nothing theres probabily a shorted wire or the output on the radio is bad
Sep 15, 2010 | Pioneer TS-D601P Car Speaker
Blown speaker? Audiobahn AS65C
it sounds like you need to get a new set buddy... sorry :(
Apr 07, 2009 | AudioBahn AS65C Coaxial Car Speaker
Put in new front speaker in car and they worked good for a couple of hours, now there is no sound from the front or back speakers. I unhooked the front speakers and put one back then rear speakers worked...
Hello. Sounds like the amplifier is damaged and or could be a short from a front speaker wire to the car chassie ground. Assuming that the four speakers are driven by the same deck. I would first varify that the amplifier in the deck (radio, CD, etc) is functioning properly if it is being used.
Jan 21, 2009 | Car Audio & Video
24 people viewed this question
 Grubhead
Grubhead
