Question about Vga (CAT5-9000I) (EXTCAT59000I)
VGA cable to RCA pins assignment
Good day, I'd like to make a VGA cable to RCA for my Laptop to my analog TV since my laptop has no S-Video slot...do you know/have a diagram for that on what pins need to be connected to RCA?
thanks alot.
Fernan
  • pjragencies Jan 30, 2009
    i like to know how to connect the laptop to single rca cable . any one can send the pin diagram to my mail id rameshpuravi@hotmail.com
  • Anonymous May 06, 2009
    Aku juga mau converter dari vga ke rca, tapi aku belum tau pin mana aja yang di gabung..... tolong bantuannya yaa... lagi cari2 di internet tapi belum dapat.... kalo ada infonya kirim ke email : miftachulazis@gmail.com
  • 3 Answers
Are you trying to go to a connection like this:
http://www.showmecables.com/viewItem.asp?idProduct=2597
If you are trying to go to composite video (yellow only), you'll need to convert the signal using a PC to TV Converter
Posted on Jun 07, 2008
What do I need to connect a laptop toshiba Satellite L675D-S7052 to a high definition tv
Assuming what you are trying to do is make your HDTV a giant monitor, your HDTV will need analog video input capability --either a standard d-type VGA connector or RGB composite RCA plugs. The laptop has a d-type VGA output. You will need a cable that has matching end for your laptop and TV....either VGA-to-VGA (d-type) or VGA-to-composite. This will handle the vcideo. You will also need a min stereo-to-mini-stereo cable to connect the audio from the headphone output of the laptop to the HDTV.
Sep 06, 2014 | Toshiba Computers & Internet
Cable to connect laptop to TV
VGA from the laptop to whatever the TV takes.
Mar 19, 2014 | Computers & Internet
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
How do I connect my Laptop Acer 5735 to my TV Sony KDL-40NX700, what kind of connection cables do I require?
If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
Sep 10, 2011 | Acer Aspire 5735 Notebook
I have a laptop and a tv. I would like to hook my laptop up to the tv. The tv does not have a slot for a VGA CABLE and my laptop does not have a slot for an RCA CABLE. What can I do to connect the two?
You need an Video out, adapter cable, for your model Laptop, IF yours indeed does have the ability to TV out, the "output" is "Composite Video" and goes into the Composite Video "IN" on the TV. Audio is taken from Line Out in laptop & goes to AV audio in, via a Phono Jack to RCA converter plug. Also it must have correct drivers and be enabled and have desktop extended to the TV either Cloned or Spanned.
Usually one connects up to the TV, powers TV on & then Turn your laptop on.
You may have a Yellow RCA socket on the back/side of your laptop, otherwise you have to get a converter cable.
Feb 07, 2010 | Compaq Presario Notebook
I have a Dell computer that runs Windows Vista and I want to hook it up to use my TV as a monitor to watch a webcast. Please advise.
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
NEED MOre HELP check this link for video :
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Jan 20, 2010 | Computers & Internet
What cable do I need to connect latitude D600 to a hdtv ?
*S-Video
Nov 22, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 2200 to Phillips 47 " TV
check this out http://answers.google.com/answers/threadview/id/762913.html *A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable. you will need a seperate audio cable unless you are going to use your laptop's speakers
Feb 04, 2009 | Toshiba Tecra M1 Notebook
How do i hook up a T5230 E Machine with no RCA port to A Emerson 32in Hd Tv with no vga port?
  • http://www.eforcity.com/pothvgasvrc1.html?gad=CNGV0_4CEgjzLnO-zCySDRiJp-j9AyDV7too
  • VGA to S-Video / RCA Adaptor
  • NOTE: Your VGA card must support TV out directly through VGA port function. Please consult with your VGA card's user manual for more information.
  • Cable adapter allows video output from your PC/laptop to any TV with S-Video or RCA video input.
  • Connectivity:
    • Connector HDDB15 15-pin (M x 1)
    • Connector S-Video mini din 4-pin (F x 1)
    • Connector RCA Composite (F x 1)
You can find several like this from 5 to 10 dollars , just search the phrase "VGA to RCA cable"
yell if you need any more help and thanks for using fixya. ------please rate-------
Oct 22, 2008 | Computers & Internet
B130 to TV
You could try a VGA to RCA/Composite cable, but I doubt that would work.. Unfortunately, you laptop does not have a tv or s-video out, so the only other way to do it is with a TVTuner box, like this one:
http://www.kworldcomputer.com/product/analog/012/TVBOX1440.htm
might be able to find something similar at a local PC/electronics store..
Runs for about $70 CAN
Mar 28, 2008 | Dell Inspiron B130 Notebook
Computers & Internet Logo
5,188 people viewed this question
Top Vga Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
John Hong
John Hong
Are you a Vga Computer and Internet Expert? Answer questions, earn points and help others
