Question about Zanussi 24 in. DE6965 Built-in Dishwasher
Iberna dishwaher IDI 10 80
New machine , ran first program ok, was moved and laid on its side, now error code (strong light & normal light lit, long inlet time, water pressure?). water in sump, drain pump running , paddles not rotating,
    President:
  • 2,712 Answers
Try a hard reset first..Unplug the machine from power source, wait about 10 minutes, and try again..The other thing you can do is to check the water inlet valve and tubing for any kinks, etc..
If the issue still occurs, better call the point of sale or the manufacturer, as your machine is still under warranty. I wouldn't recommend opening it up to conduct any repairs as it will void the warranty.
Posted on Jun 07, 2008
  • Swilin Sampson
    Swilin Sampson Jun 07, 2008
    If my solutions helped you in any way, kindly take a moment to "Accept" this solution. Thanks in advance,
    IrishDruid
GW712 will not agitate or spin, 1st and 7th lights lit, beeping every second.
Your Error code is 130
130. (10000010) Phase 1 to 6 Single Rotor Position Sensor Error
The Motor Controller has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness
between the Rotor Position Sensor and the Motor Controller, or a faulty Rotor
Position Sensor.
Primary Source: Wiring.
Action:
1) Check for corrosion on the edge connector of the Rotor Position Sensor and
the Motor Controller module connector.
2) Check the contacts on the rotor positional sensor end of the hall harness to
see if any have been damaged. (Each set of contacts in the socket has two
wipers. If the distance between these wipers varies between different
contacts, replace the rotor positional sensor harness).
Secondary Source: Rotor Position Sensor.
Action:
Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Controller module.
Action:
Replace Motor Controller module.
Apr 24, 2014 | Fisher and Paykel Washing Machines
Seal has holes
e13 is excessive drain time, normally down to blockages in the pump filter. this is at the front right hand side normally behind a flap and should unscrew counter clockwise.
Apr 10, 2014 | Bosch Nexxt 300 Series WFMC2201UC
Clean light keeps blinking; dishwaher won't turn on
Hello Brian, welcome to FixYa.
Based on your post I understand your dishwasher is a Kenmore and the clean light is flashing and it won't start, correct ?
If so, this is usually an error code indicating there was a problem in the heating process the last cycle it ran, however if you could provide the complete model number I could speak specifically to whether it applies to your machine and potentially what to do about it.
Thank you for choosing FixYa and I look forward to your reply.
Regards,
Macmarkus :)
Oct 12, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
We sold a freezer, it was working at the time. The person got it home and plugged it in immediately and left it running for 8 hrs, before contacting us to say that it wasn't cooling. We suggested they...
if they moved it on it's side they damaged the compressor,the machine shouldn't be laid on it's side.if they let it sit for a few days it might have recovered.if it wasn't laid on it's side a wire could have been knocked off somewhere,hard to say without being there to look at it.
Apr 09, 2011 | Amana 19.7 cu. ft. / 558 liter Upright...
Lg LD2060SH has no error codes but cannot set program or start wash. when power is switched on Green lights come on then green light only on normal wash. Cannot be moved with control knob and does not...
First check water inflow to the machine. If there is no water machine may not start.
To ascertain further, pour water into the wash chamber manually to the require level and run the machine. If it works check the water inlet.
May 20, 2010 | Dishwashers
I am also having the 6A00 error code. When I open
OK here the codes
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Washer is not tumbling after water fill.
You may have a corrupted ccu or relay. Does the machine drain and is there an error code? It starts ok and then does not continue and the pressure switch is ok? You may want to remove the swith and lightly blow into it and check for continuity and then ohms. Any small measure and I would replace it. Also if the ccu says it is ok and it is not then I would question the ccus ability to function normally.
Aug 18, 2008 | GE WBVH6240F Front Load Washer
Meaded light on and paper will not feed
I agree with Green Saints, if its only media light it is your top cover open. However this sounds like your carrage is not running. You firstly need to check the belt. Look at the belt, is it not shredded or visually perished and letting off a lot of pinkish pieces and dust. If the belt is ok then with machine off, move the head to the center and (if you presumably dont have the correct oil) use a drop of sewing machine oil on either side of the head, move the head left and right slowly to smear the oil the entire length of the rod.It should then be ok
Dave
Jun 08, 2008 | HP DesignJet 430 InkJet Printer
Error 160
Error 160 is the error code that corresponds to the fact that a new controller board has been installed, but not yet programmed to your model of appliance. Companies now tend to use a standard board for multiple models, and upon installation it needs to be "programmed" to tell the board which model it is. This is a simple step, but usually involves pushing a couple of buttons at the same time, then selecting your model number from a pre-programmed set of options. The instructions should come with the new board, or the company can provide if you can get them on the phone.
Oct 14, 2007 | Bosch HES 232 / HES 236 Electric Kitchen...
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
564 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
