Question about Intel Motherboard
Startup problem my board can not switch on from the mainboard switch
  • 119 Answers
Either the power supply is dead, the mother boad is dead or the power switch has been plugged onto the wrong jack on the motherboard.
Posted on Jun 07, 2008
The green LED light on the board is lighted. When I push on/off button the CPU fan moves for 1/2 a second .I tried a different power supply, but that did not work. I replaced the CPU fan, but that did not...
Hello here is the homepage:
Any abnormal beeps at startup ???
The problem could be a ram module failing, or the graphic card if installed on the mainboard.
Or a short circuit somewhere.
Look also here:
Try starting with only 1 stick of Ram, the monitor and the keyboard connected, no other USBs to be connected.
Look also for bad caps on the mainboard:
If they look like this, the mainboard is dead.
It does not pay, to let them be changed.
Good luck
Jan 28, 2013 | Intel DG31PR Motherboard
How to check a G41MXE motherboard
Hello the mainboard home page is here:
Try to download a manual and check the mainboard up
for any loose connections i mean the front panel wire
so the mainboard can start.
The power switch cable or ON/OFF must be placed correctly.
If no luck the board is dead.
The front panel connector look like this:
Good luck
Nov 02, 2012 | Foxconn G41MXE Motherboard
Intel desktop board d845wn front panel powder led, power switch, hdd led, reset switch connection problem.
Hi, here you can read info and download drivers
for your mainboard:
The pin layout look like this:
Connect: 1 and 3, 2 and 4, 5 and 7,6 and 8.
The 9 number is not in use.
Its also printed in on the mainboard with very small letters.
Sep 20, 2011 | Intel Desktop Board D845WN Motherboard
I replace my power supply for my E520 and its dose not turn on. It is a new replacement power supply for this model. I check alll the connections. It haas aa blinking amber light all time.
I would double check the connections to the main board. Some power supplies have two power connectors to the mother board, a 20 pin connector and a 4 pin connector. Sometimes the four pin connector is in a different location from the 20 pin on the board. Make sure both connectors a plugged in.
Make sure the connector for the power switch is plugged into the board. Dell's usually have all the wires for the front pane in one connector.
You should also unplug everything from the board except the power supply and front panel. There could be a hard device causing the board to hang up.
I have had power supplies die and short the main board. I hope that isn't the case here.
Jul 02, 2011 | Dell DimensionTM E520 PC Desktop
My MSI computer won't startup. It has an
It appears that you have only checked the power supply and the on/off button. There are many reasons a computer won't start.
These are only two. Have you "stripped down" the system? This means removing everything but the CPU, Memory, and video card. If it starts with only these things attached, then you can rule out the mainboard, memory, and video.
Next remove the memory. If it starts but you get memory error beeps, then it could be one of the memory modules.
After all that, you can then figure it's the mainboard or the CPU.
As for circuit diagram, I would think these would be very hard to find.
Jun 18, 2011 | MSI Computers & Internet
The screen is black. Lights come on but no startup and black screen.
Can be related to failure of the LCD display ,the power to the display or the failure of the mother board.
Since the indication confirms that the mainboard is not booting up and also there is no indication , this might requrie a closer look within the main board to confirm the status of the sections involved with a trace of voltage from the power supply to the fucntioning of the processor, the memory and drives.
Mar 14, 2011 | HP Pavilion dv6933cl Notebook
My mainboard startup, ive check the power supply and ram and there's no problem
If your board starts up and there's no problem, then this is a good thing!
Feel free to re-post here if you have a problem though.
Specify what processor/video card/ram you are using (make, model, speed, etc) and someone will be able to help you.
Feb 24, 2011 | ECS 945GZT-M (V1.0) Motherboard
Iam having a pcchips m861g mainboard,and the problem ihav now is my mainboard isnot recognising the sata hard drives,its recognising the ide hard drives.i checked my satahard drive in another mainboard and...
Its settings in the bios. Press DEL or F2 at startup and look for something like drive configuration in there and set SATA to enable. Most boards have this turned off by default. Cheers from Scott
Jan 20, 2010 | PC Chips M861G Motherboard
Difficult to boot. I must try 5-10 times or press the mainboard.
When rebooting or shutting down, hold the power button for at least five seconds.
Aug 31, 2009 | HP Compaq nx8220 Notebook
I have an Intel D945GCZ mainboard At startup I
This is a diagnostic beep code which is designed to tell you something is amiss with your system. The code patterns of short and long beeps are not fully standardized, so it depends on who manufactured the BIOS for your motherboard. Generally three long beeps indicates an issue with the base memory - the first 64K. Try putting your RAM sticks in one at a time and powering up the system. Make certain they are oriented correctly (note the notch) and firmly seated in the socket.
Mar 04, 2009 | Intel D945GCZLR LGA775 1066MHz FSB DDR2...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
