Question about Hitachi 53FDX01B 53" Rear Projection Television
Broken mirror So I got this TV with the mirror already removed and all the parts in a bag, is the mirror anything special, or can I just use a regular mirror? Beyond that, what are the dimensions?
  • 47 Answers
Call 18006383328 tritronics or 18002744666 andrews and have model number. It is just a mirror and you can measure yourself dimensions or just iorder new one.
Craig www.classtorations.com
Posted on Jun 08, 2008
Mirrior is broken
If the mirror cracked/broke and any part of it fell forward and into the inner screen---Mirror around 150 and screens (sold as a set) around 600.
Major labor may be involved but the entire front frame with the screens can be removed to examine and or replace mirror.
Mirror is very fragile and special in construction--when replacing wear soft white gloves---any fingerprints or even marks from your hair touching the mirror will show in the picture CLEARLY.
QUESTIONS?
May 15, 2012 | Mitsubishi WD-73733 73" HDTV
Broken mirror for panasonic tv model pt47wx54j
A regular mirror will not work correctly---best bet is Google the model number with "mirror" as some sell mirrors and if that fails call Panasonic to see if available, part number, cost and where to order it.
Apr 08, 2012 | Panasonic PT-47X54 47" Rear Projection...
53 inch projection tv mirror broken can i have a regular mirror cut to size and work
A regular mirror will not work as the mirror has special construction; What you can do and our shop has done this is find a used one bigger and have it cut down to size.
If it is Toshiba you can also call ANDREWS ELECTRONICS in LA (they have 800 number) and see if original mirror is available from Toshiba. There are also some sites on the internet and if you google the model number with the word mirror you will find them
Be extra careful if mirror was broken as pieces will be very sharp.
Entire front screen unit will have to be removed to get at it and or replace it.
Let me know if you have questions.
SD TECH
Oct 11, 2011 | Toshiba 53HX71 53" Rear Projection...
Replace passenger mirror
glass and motor availbable separately
Removal
NOTE: Do not remove the mirror assembly when repairing the individual mirror part. Individual mirror parts can be installed without removing the mirror assembly.
  1. Remove the front door trim panel; refer to Section 501-05.
  1. Remove the outside rear view mirror access water shield.
  1. Remove the speaker.
    1. Remove the screws.
    1. Disconnect and remove the speaker.
  1. Disconnect the outside rear view mirror electrical connector.
  1. Remove the outside rear view mirror.
    1. Remove the nuts.
      • Feed the outside rear view mirror wiring through the opening in the front door.
Oct 26, 2010 | 2003 Ford Ranger Regular Cab
How do I replace the right mirror assembly on my 2003 Ford F-150? I know I have to remove the right side door paneling, but I don't know how.
You shouldn't have to remove the panel, just the black plastic cover right behind the mirror, it holds about 3 or 4 bolts, pull them out and hang on to that mirror, it is heavy, It has cables or wires attached to it. If it is just the glass that is broken, you can pop the glass right out and put in a new piece and don't take anything off. You can even get a new mirror at the grocery store parking lot. Check it out, Hope this helps.
Oct 14, 2010 | 2003 Ford F150 Regular Cab
Replace driver side power mirror on 2003 ford crew cab f-150
Muth makes the signal mirrors for repalcing the glass in the mirror head. On the site, they have nice instructions you can use for removing the door panel, and getting the mirror off ( obviously stop at the removing the glass part, and just replace with the mirror head you already have ).
Enter the Make, MY, and model you have, and on the products page are the links to the PDF version of the instructions for download.
www.kwmuth.com
May 19, 2010 | 2003 Ford F150 Regular Cab
2004 Honda accord Sedan - Mirror, actuator and cap replacement
you can buy the whole mirror after market for about 70.00 dollars three bolts changes the mirror assembly its a pain to do it the other way i have changed alot of them if you can just get the mirror glass double stick the
new to the broken one
Dec 22, 2008 | 2004 Honda Accord
Passenger power mirror, how to replace it?
you need to remove the door panel ,to install mirror assy-tere are no special tools(10mm socket,ratchet and #2 phillips screwdriver)3 nuts hold the assy. to the door and the connector is easy to see,there are no special sealers needed(seal is already on mirror assy)good luck!
Nov 14, 2008 | 2002 Mitsubishi Galant
Broken Mirror
you need to see if the lens where the light comes out is scratched..
if it is then the picture will never be right until you replace it..as for a cheap replacement mirror the picture might be watchable if it is a good quality mirror
Aug 01, 2007 | Samsung HL-S6187W 61 in. HDTV
Hitachi 53FDX01B 53" Rear Projection Television Logo
193 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
