Question about Proview PL913B 19" Flat Panel LCD Monitor
Once the screen saver comes on in about 10 mins, the screen goes white and the odd thing is that the blue light showing that the monitor is on is now yellow/orange showing off. so when the monitor is on and working fine the light is now showing that the monitor is off. it's almost as if the lights switched. yellow/orange is now on and blue is now off. what i do when the screen is white is hit ctrl/alt/delete and sure enough that screen pops up and i hit cancel and then i'm back on just fine..
SOURCE:
SOURCE: Faulty monitor
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Posted on Jul 24, 2007
SOURCE: proview 900 series black flat panel monitor
I had the same exact problem (Blue LED blinking but the monitor doesn't turn on), but I followed the guide that delphiuser posted in this post (http://www.fixya.com/support/t127735-white_screen) and replaced some capacitors in the power supply. (I'm the guest that posted on Nov. 15) The LCD is still working perfectly today. So.. if you have some electronic and soldering experience, you could save the LCD. You do want to be careful of the high voltage capacitor in the LCD (the big one on the power supply) when you have the LCD open though, that one can give you a REALLY nasty shock.
Posted on Nov 18, 2007
computafixa
  • 317 Answers
SOURCE: Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Posted on Feb 21, 2008
bammbammfran
  • 159 Answers
SOURCE: Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Posted on Oct 11, 2008
skotkolr
  • 558 Answers
SOURCE: The green light comes on then turns to yellow.
if you look at the capacitors on the boards you will find several of them that are domed or blown, these are the most likely cause of the problem. you can find replacements for any capacitor online at electronics supply stores, like radio shack but don't try them they don't supply enough different types. you can also find examples of blown capacitors by doing a search for "blown capacitor image" on any web search. unsoldering these bad caps and replacing them with identical values like 220uf (microfarradys) and say 25 v(volts). these caps have a + side and a - side the caps are marked and so is the board. hope this helps.
Posted on Mar 21, 2009
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
The monitor goes blank after a few min, it comes
Are you sure that your computer isn't just going into power saving mode? Not sure what operating system you have but go into the screen savers tab or video properties and find out how your system is set up for power saving It may be starting before your screen saver does so the monitor would just go black.
Dec 18, 2009 | ViewSonic PF775 17" CRT Monitor
LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Dec 18, 2009 | LG Flatron L1750S 17" LCD Monitor
Terminals shutting down after minutes of inactivity goes back to user name screen
check screen saver time, also look at Power on the Screen Saver Tab, it may be set to low time, change it to 20 mins for "TunOff Monitor" and other settings like Hybernate etc
Dec 07, 2009 | LXE VX6 64MB 1 ANT 10 Inch INDR QWR ANSI...
Dell screen (1901FP) won't come out of power saver mode
hold down the Fn and F8 keys, and it worked fine for me. or if your problem is you cannot wake from power saving mode (after your PC goes to sleep, then its probably just the driver for your video card). VISTA has some issues with certain drivers that the PC cannot wake from sleep
Sep 24, 2009 | Dell 1901FPt 19" TFT LCD Flat Panel...
Black screen
Don't let the computer turn the monitor off. Go into control panel and click on power option. don't let the computer turn anything off and disable hibernation if on. go to screen saver and have it come on in about 30 mins.
May 27, 2009 | ViewSonic VX2235wm LCD Monitor
Every 10 mins my monitor goes black and then the picture pops back up
Its the poblem of SCREENSAVER which gets activated every 10 minutes.
In Control Panel, go to Display Settings / Personalise - - - - -> In Screen Saver select NONE.
Your problem will be solved for sure.
Apr 24, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Proview PL913B 19" Flat Panel LCD Monitor Logo
Top Proview Computers & Internet Experts
 Mike M
Mike M
Siul Oyaratgam
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
