Question about Fedders A6P09S2A Air Conditioner
Fedders Air conditioner
I have a fedders ductless split air conditioner. Remote works but on the unit itself shows E5. How can I clear that becuase unit is not working?
  • 1 more comment
  • Brute145 Jun 07, 2008
    not doing anything.....remote changes but i cannot get the e5 to cancel. that is my big problem. where is the reset button?
    it is wired into the electrical, can I do something there to reset?
  • fadeelo
    fadeelo Apr 18, 2013
    what is the infared remote, because I AC remote.
    Master:
  • 638 Answers
E5 is comp overload code . if you have infared remote for indoor units point at anyone while pushing all 3 buttons at the same time- 'mode' 'temp up' temp down' this will bring up OO where temp set point is normally displayed. scroll up or down with temp up or down buttons (1st digit only) untill you here the beeping sound change tone, this is the 1st part of the fault code. press mode once to change to 2nd digit, scroll again with up and down listening for change of beep- 2nd part of code ie "E5". press mode again will bring up afunny looking T-test mode. press mode again to exit. THATS VERY ACCURATE SOLUTION.SAVE IT FOR FUTURE.WISH U SUCCESS .REPLY FOR FURTHER ASSISTANCE IF REQUIRED.BYE
Posted on Jun 07, 2008
  • fadeelo
    Thanks hemant, can I know what is the infared remote, is it the A/C remot, if yes I tried to push on 'mode'+'temp up'+'temp down' and I did not get anything.
  • 13,433 Answers
On another model e5 ment that the filter had to be cleaned.
  • Ekse Jun 07, 2008
    after cleaning the filter, if I remember correct, unplug, wait for a minute, then hold down the power button and plug it back in, it should beep, and thats it.
    President:
  • 2,712 Answers
Try a hard reset first.Disconnect the machine for about 30 minutes and reconnect after that to see if the issue is resolved.
  • 3 more comments
  • Swilin Sampson
    Swilin Sampson Jun 07, 2008
    If the hard reset does not work, try to operate the unit in auto mode
    by moving the Auto Control switch to the “A” position under
    the front grille. See if the unit works now. If it does, it seems a problem with the remote or the remote sensor on the unit.
  • Swilin Sampson
    Please also try Ekse's solution of cleaning the air filters, although I doubt a dirty air filter would cause the unit to stop functioning...
  • Swilin Sampson
    Please also go through the troubleshooting guide in the user's manual. You can download one here:
    http://www.fedders.com/IandOResidential/...
    Then, if you still need assistance:
    1. Please contact your installer for warranty service.
    2. If your installer is unable to assist in repair or if you need other assistance, contact CareCo for the name of an authorized servicer.
    You may contact CareCo by email:
    customerservice@fedders.com
    by calling the following toll-free number:
    1-217-347-6562
    or you may write:
    CareCo, Service Department
    415 W. Wabash Ave., P.O. Box 200
    Effingham, IL 62401
  • Swilin Sampson
    @Hemantraj..Thats the method to generate an error code if there is an issue with the unit. Not a resolution for the code itself...
  • Swilin Sampson
    Try switching off the circuit breaker for 10-15 minutes.
Does Fedders AEY08F2B window air conditioner have an oil port to stop squeaking motor.
Most air conditioner units don't have oil ports on motors any longer.
Sep 13, 2014 | Fedders Heating & Cooling
HOW DO I GET MY FEDDERS AIR CONDITIONER BACK TO FARENHEIGHT
Problem with Fedders (A6R12F2A) Air Conditioner
FARENHEIGHT
Nelvie: silverslipper@candw.ky
Aug 20, 2010 | Fedders AED24E7F Wall/Window Air...
Fedder split unit
Your heat strip is burnt out . You will need a tech to come out and replace this heater strip due to the complexity of installation
Dave
Jan 06, 2010 | Fedders C48ACD1VF Split System Air...
We have a Fedders window unit and we do not have an owners manual. When we plug it in it beaps and then blows air for 2sec and then it goes off with the signal E3 showing in the digital box. We need to...
Without the model number, I can't point you to the exact manual for your particular unit. However, here's a link to a web site that has about 38 manuals for various Fedders models. You can download a manual and/or users guide for free and look at the operation and troubleshooting sections to see what you need to do to get your unit working properly.
Just scroll down the page once you get to the web page to locate your particular model number, then click on it.
http://www.retrevo.com/samples/Fedders-Air-Conditioner-manuals.html
Hope you found this helpful and best regards!
Aug 06, 2009 | Fedders Appliance Air Conditioner Wall
Problem with reset switch on fedders split unit
This indicates a fault within the unit. Call a service technician and have the system repaired.
I take the time to help you with your problem, so please rate me.
Thankyou Mat
May 18, 2009 | Fedders C36ACD1VF Split System Air...
Fedders A6P09S2A Air Conditioner Logo
760 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
