Question about Intel Motherboard
Restarting problems.... Hi, Hope you can help. My system reboots when i am in a game when i try try enter a game... Reinstalled cards, Latest Drivers, Turned off AA. Opped the fan speed incase of overheating... any ideas? Thx
    Scholar:
  • 119 Answers
You proplem here could be that you game is not compatible to you operating system or otherwise your operating system could be damaged or you memory modules (RAM) are inadequate remamber that when you have installed a graphics card it will hog up some of you RAM that is why you need access RAM to run most games. you other problem could be that you graphics card is not fast enough to support your game. check all these and see if you can come right.
Posted on Jun 07, 2008
  • 868 Answers
Dont increase the fan speed.Your processor isnt working.Replace it.
Installed Nvidia gt210 card. Running XP. Windows runs fine when not using the Nvida drivers, screen displays correctly. Install drivers and screen display is scrambled. Looks like a rainbow. Uninstall...
Hi, you can download the latest driver here at nvidia:
http://www.nvidia.com/object/winxp-280.26-whql-driver.html
Maybe the videocard has a defect.
Try to change the card with a newer one.
Or the driver you have downloaded does not fit your system.
Try also windows update.
Hope this will help you
Aug 21, 2011 | Computers & Internet
Setup dual-boot disks, one loads VGA instead of GeForce 6200
You should enter Bios setup when restarting and check that it says AGP or PCI for video display. You can then go to Start then Run and type in msconfig. Go through the list for the startup menu and make sure that NVIDIA is displayed with a checkmark.
When you installed the new driver, also make sure that you disabled the default VGA driver too. You may have to check that out. If both are running there will be conflict. Any questions, please don't hesitate.
Nov 18, 2007 | XFX GeForce 6200 Graphic Card
I have an HP computer with an intel 2.4 cpu and 1.7gigs of memory with an ati 9200se video card with 128 meg of memory. when playing MOHAA game when there is a lot of action the video gets erratic. I...
you have a good set up...
may be your problem is that your game requires other programs...try to update your microsoft c++ 2008
many online games are requiring for updates for c++..
what is your operating system??
it will be necessary for you to download the right c++ so it will work as it needed..
i hope it will help you...rate this..
Feb 06, 2010 | Computers & Internet
Can't install drivers on Lenovo T 60 after XP Pro reinstall
go to device manager, uninstall network adapter, reboot, windows should find and reload drivers.
Nov 02, 2009 | Lenovo Thinkpad T60 Notebook
Computer restarts on the loading screen.
ITs the problem with the video card and memory, try reseting the memory and install direct X controller and update the video card drivers and then try to install it
Sep 16, 2009 | Computers & Internet
GIGABYTE S SERIES (NVIDIA GEFORCE 6100 CHIPSET) RESTART PROBLEM
This can be any number of problems. After it's rebooted itself go to Start Menu -> Run and type eventvwr. Have a look under the system tab to see if there are any errors (marked red), that may give a clue.
However it could be any componant inside your computer that's failing. Replacing or even just reseating the memory would be a good place to start. Failing that it may be the motherboard or graphics card. You could try updating to the latest drivers - http://www.gigabyte.com.tw/ .
Hope this helps
Nov 12, 2008 | Intel Motherboard
Jumpy 3D graphics
I would re seat the Vid. Card first, and make sure it is in the socket tight, and if that doesn't do it? You probably should try another Video card to eliminate the possibility that the problem isn't with the Video Card in question.
I hope this helps you!
TampaNative
Jan 29, 2008 | Microsoft Windows XP Professional
Matrox g550 display card with winxp pro
try pressing f8 before you see the win xp logo with the scrolling green bar. Select Safe-Mode and press the enter key. This will bring you into safe-mode. If you can boot into safe mode then try going to the device manager and uninstalling the drivers. After that reboot and let windows use the default graphics card drivers. Then go to the manufacturer website and download the latest drivers.
Nov 17, 2007 | Computers & Internet
Reboot problem..
Easiest possible solutions first:
1) download and install the latest drivers for your video card
2) see if there is an update for the game that causes the problem
3) run memtest86 from http://www.memtest86.com/ to check if your RAM is bad
4) swap out the current video card with a known good video card
Nov 09, 2007 | MSI MS-6366 Motherboard
Flickering games red jumpy video
Do you have the latest version of direct x installed? Direct x sometimes can cause problems with games using 3d acceleration, as some versions of direct x are not fully compatible with the video card and/or the video card drivers.
Nov 29, 2006 | XFX GeForce FX 5200, Graphic Card
Intel Motherboard Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
