Question about KitchenAid KUDM24SE Built-in Dishwasher
Kitchenaide KUDM24SE1 dishwasher will not fill with water
Kitchenaide KUDM24SE1 dishwasher, water will not enter machine when it is started. The float moves freely up and down, when water is added manually it will wash and cycle but after it drains prior to the rinse it will still not fill. The water supply is on and not clogged. I have cancelled the wash several times and tried different wash settings with the same results. Any ideas??
  • Anonymous Mar 31, 2009
    what voltage is it supposed to be?
  • Anonymous Mar 24, 2014
    no water in, time does not move on machine even if manually change type of wash cycle
  • 413 Answers
It may be the water inlet valve or the electronic control board. To check, remove the bottom toe panel. The valve will be on the left side. There will be live power, so use extreme CAUTION. Start the DW, 1. if you can hear the valve humming or the valve coil is getting warm, replace the valve. 2. Using a device with wires to check the power at plugs, connect to valve power connection, if power is present, replace valve else replace electronic control board.
Posted on Jun 07, 2008
I have frigidaire dishwasher,starts cycle,can hear water entering dishwasher,checked level of water,does not get to 1",machine starts washing by the sound of motor, but dishes are not clean,water drains...
Depending on your dishwasher, it fills either by a timer or by a water probe or float. I will assume its a timer as a probe or float wouldnt exhibit this behaviour. I would say you have a restriction in your water supply line. Check your valves, any screen filter in the water line for sand/scale/silicate/etc, pressure regulator if applicable. Another posibility is a poor magnet in your fill valve.
Dec 19, 2009 | Frigidaire Dishwashers
No water coming into dishwasher
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. ----- There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 03, 2009 | Kenmore Elite 21086
My JennAir JDB5900AWW won't fill with water. It
here is the solution to your problem
Water-inlet valve
Float switch
Jul 07, 2009 | Dishwashers
Dishwasher does not fill with water when started. Problem began slowly with dishes not rinsing completely. Overfill float appears to work properly. Water fills pipe leading to fill solenoid but does n
I am almost certain that your problem is the fill solenoid.
If it does not work, there will be no water entering your machine.
I would either remove it and test it or just replace it at this point.
Tim
Apr 16, 2009 | Dishwashers
Washer will not start
Water-inlet valve
Float switch
Water-inlet valve
Float switch
Good luck.....
Mar 28, 2009 | Jenn-Air Dishwashers
Dishwasher not filling all the way,
hi,
Water-inlet valve
Float switch
Water-inlet valve
Float switch
good luck.........
Mar 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dish washer not filling with water when put on
There are a few things that can cause this problem, it could be a defective water inlet valve, it's usually located behind the lower kick plate on the left or right hand side of the dishwasher, When the washing cycle is started it sends voltage to the water inlet valve to open which allows water to enter the machine, or it could be a faulty float switch, when water enters the machine the float switch raises up which signals the water inlet valve to shut off, the float switch is located inside the dishwasher at the bottom, you can check the float switch by raising it up and down to see if it's stuck in the up position. Good luck.
Mar 21, 2009 | Dishwashers
Not filling
If the machine is not filling, then it is probably a faulty inlet valve. Check the float switch and the power supply lines at the back first.
See here how to locate the parts.
See also this advice for repairclininc:
" There's no water entering the machine If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Sep 06, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Dishwasher filling correctly?
john, the dishwasher has a timed fill, make sure you are using 3/8 inch line. If you are using 1/4 inch, that would be your problem. The fill should be just below the heating element. If you are using the 3/8 inch line, the next suspect would be the fill valve itself. Make sure nothing is kinked, Catriver.
Jun 17, 2007 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Dishwashers Logo
307 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
