Question about Matsonic MS9127C Motherboard
Does not boot to floppy/cdrom/ or hdd
I loaded the fail safe default settings and when it boots, it gets to listing all the devices but does not continue to boot to floppy/cdrom/ or hdd. it stops right there and goes no further.
Any ideas?
  • Roman Sulejewski Jun 07, 2008
    I just mounted the board tonight because the old board developed leaky capacitors and fried a 2nd power supply.
    All cables and pin connectors connected correctly according to the manual and fully seated.
    Thanks for trying.
    BTW. I even used the jumper to clear the bios and start fresh, still no luck.
  • 99 Answers
Have you booted into BIOS to see if your drives are recognized there?
Posted on Jun 07, 2008
  • 4 Answers
If u want help msg me
Please check in the bios that is first bootable device is hdd
  • 638 Answers
Check ur hdd and cd rom cables , r they okay or may be even loosen from the board.feel frree for further assistance.bye
Normal POST, system hangs after PCI device listing.
Bios updates are intrinsically dangerous and not guaranteed. If something goes wrong during the operation or it does not work you often wind up with junk. If you have a spare hard drive you might try loading that to see if it takes. If so then the issue is with the OS on your first drive. If the install does not work then it may be a bios issue and .......... Good luck!
Mar 23, 2017 | VIA Computers & Internet
Operating system not found
Ensure your BIOS settings are allowing the HDD to be a boot device, preferably in first position in this case. (possibly F12 available for quick boot device setting) otherwise F1 on power up.
Try booting with CDROM pulled. Also remove HDD, inspect & brush pins with an old toothbrush and some IPA or WD40.
Failing that, get a copy of Linux Puppy ver 4 onwards on CD (free download & burn at a UK library) and boot your laptop (set at F12 for CDROM). If you can browse your HDD it may have a boot sector problem - you will need a copy of PART244.exe or FDISK on a CDROM to check further.
Nov 06, 2012 | IBM Lenovo ThinkPad A30 ThinkPad A31...
Trying to reformat and load my computer for a fresh start. When I reboot to load Windows the screen goes to a small box saying "input not supported". How do I fix this???
visit my site
it has all details on how to reset to facotry setting.....format and reinstall Win etc
you may have to make changes to BIOS to boot from CDROM a 1st Boot device....
press F1, F2, Del, Esc, F12 key other one that brings up the BIOS screen there look for Boot seq....disable HDD and floppy, enable CD ROM drive and make that 1st boot need to change it back to HDD the1st boot device later after loading Win....
once you boot from CDROM then follow inst from my site to format HD....and install XP
all the best
pls feedback and comment on how u did
Nov 07, 2010 | Acer AL1916W 19" LCD Monitor
Can only get to BIOS, system will not boot to CD Rom. Unable to upload settings.
can u c the boot sequence in the BIOS....
if yes make to boot it from CDROM insted of Floppy/HDD
keep this boot seq. in BIOS
1 boot from CDROM
2 boot from Flopy
3 boot from HDD
Dec 17, 2009 | Acer Aspire 6930-6771 Laptop
Installed service pack 3 now stuck in boot loop
did u change the boot sequence in BIOS....
if u made any changes there u need to set it back to boot from hardisk....
i suggest u keep this boot seq...
1st boot CDROM
2nd boot Floppy drive
3rd boot HDD
u can make to boot directly from HDD as 1st boot
but remember to make changes to BIOS everytime you want to boot from CDROM
Dec 14, 2009 | HP Pavilion a1010n (PS563AA) PC Desktop
Bios settings?
these settings are related for boot up troubleshooting....system need startup point that is called boot up point.. Now there is sequence for search for boot up device that contain boot up point These device consist of floppy drive, hard drive, cd rom, usb drive and try to set your boot device priority with hard drive as first device....this will solve your boot up reply back
Oct 02, 2009 | Computers & Internet
Dell Optiplex GX50 won't load windows OS
Which cdrom is it? Is it a windows XP cd? This is an older PC? Does it have a floppy disk drive? Try downloading from Barts a bootable floppy disk, set boot order to floppy in BIOS, change to cdrom drive letter after booting to floppy (D:?)
got to I386 folder and set up from there.
More info would be helpful.
Jul 09, 2009 | Dell Optiplex GX50 Intel Desktop PC -...
Can not change Bios Boot Device
remoove battery n start
press f8 n safe mode
shut down n restart
press/dell/f2/f10/f12 key
then u will go to bios setup
if changes is not saved then change cmos battery
Jun 14, 2008 | Toshiba Portege R100 Notebook
Media test failure
Do you have the PXE error?
The media failure is in the boot sequence, on the toshiba press F12 on boot to change boot priority, select cd/dvd or hard drive, or to preclude from happening, press F2 on boot enter BIOS, select Boot options make sure to set priority as cd/dvd, then hard drive, then network or disable network boot. network booting causes media failure.
Mar 20, 2008 | Computers & Internet
Boot sequence problem
try booting to DOS screen only by inserting a boot-able floppy disc (I use Win ME disc at this point although my system is also Win XP). Then select "boot with CD-ROM driver". It will detect your CDROM drive and assign a letter. Now insert the CD and boot from there. I have done this sequence many times with no problems.
Jul 13, 2007 | Compaq Armada E500 Notebook
Matsonic MS9127C Motherboard Logo
125 people viewed this question
Top Matsonic Computers & Internet Experts
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
