Question about Garmin eTrex GPS Receiver
Compass deos not point north
I ask my etrex to go to a marked position but it does not send me in the correct direction,it seems the compass facility is not correct even if I rotate the pointed won't turn
cheers Brian Mack
  • Brian McConnell Jun 09, 2008
    it doesn't have a calibration facility,but thanks anyway
    cheers B.Mack
Yes, there is a calibration option under *System*.
Posted on Jun 29, 2008
Do a calibration. press the menu button while on the compass screen and select calibrate.
Posted on Jun 09, 2008
How would a bar magnet orient itself relative to this planet’s magnetic field?
The magnetic field around the earth runs through the center of the earth and has the positive end at the arctic pole and the positive end at the antarctic pole
magnets have north and south poles ( positive and negative) that means that they align themselves with the negative end pointing north and the positive end pointing south
that is right --but any compass you have the N is pointed on the negative end and that is the direction where the north is
May 03, 2017 | Televison & Video
When compass is used the second hand points west instead of north
Are you wearing a ring on your finger that may be magnetic?
That could throw a compass off.
Jan 30, 2014 | Casio GA-1000-1ADR
I just bought the Casio SGW500H-2B Mens Twin Sensor 100M Digital Sports Watch Compass Thermometer. My problem is the digital readout in compass mode reads fine but the needle/ second hand points to east...
To fix this, hold down the A button for 4 seconds. this allows you to recalibrate the home position of the second hand. My secondo hand was posting exactly 90 degrees west in compass mode, and this home position recalibration fixed it 100 percent.
Sep 11, 2013 | Casio Watches
2006 Expedition overhead compass reads "N" when heading "E". Wonder how to reset it so it indicates the direction accurately.
Yes. Wish I could tell you which button for sure, but to reprogram the Compass you hold one of the buttons and drive in a circle one or two times to reacquire your position.
Apr 08, 2013 | 2006 Ford Expedition XLT
How does a compass always point to due north?
"Due North," by definition, is the direction towards the earth's north pole; or, visually at night, towards Polaris, the north star. Therefore, compasses generally do NOT point towards due North but, rather, point towards "magnetic north," as the other responder described, which is a variably located at some distance from True North, depending upon where the north-locating compass is situated on our planet. In most circumstances magnetic North is close enough so that people are willing to accept it as North in general terms. However, depending on your location, and upon seasonal changes caused by Earth's wobbling rotation (called precession) true North can be many degrees off from magnetic (from your compass's) North. In those cases true North must be determined using declination charts, which will tell you how many degrees to add or subtract on you compass in order to determine true North by the Magnetic North your compass is pointing to. For example, if magnetic North is 10 degrees west of true North at your compass's location (that is, your compass is actually pointing 10 degrees to the "left" of North), then you would correct by considering the +10-degree bearing point on your compass dial as True North--and, likewise, add 10 degrees to any bearing line you happen to determine using your compass. You have one other way of finding True North, which is celestially, by sighting towards the Pole star, aka Polaris, aka the North Star...that is, providing that the sky is UNcloudy and unsunny enough for the star to be visible. Of course, that only works for those located in the morthern hemisphere. Those south of the equator have a "south pole" star but it is not as accurate as Polaris in the northern hemisphere.
Jul 09, 2012 | Camping, Backpacking & Hiking
How do I calibrate my compass in the eTrex Venture HC. The book says to go to the tje menue and then press calibration. My GPS does not give me this option.
I will be happy to help you with this. Unfortunnately, the Etrex Venture does not have an Electronic Compass, therefore you cannot calibrate it. What this means is that this unit will show the correct direction of travel as long as you are moving. The unit takes satellite reading every 1 seconds and compares it's location with the last location. This way it can read the direction of travel. It will not give correct readings unless you are moving.
I hope this helps.
Dec 31, 2009 | Garmin eTrex Venture HC GPS Receiver
How do I use an orienteering compass to measure inclination?
Declanation (not inclanation) is different depending where you are located in the world. You can look up charts (magnetic lateral lines) on the net and they will tell you where your compass is pointing to, Magnetic north compared to TRUE north... Topographical maps will tell you how much to offset your compass to accomodate for declination...In degrees. I am no expert but I hope this steers you in the right direction. P.S. A compass always points to magnetic north not true north. Also I am not responsible for you getting lost ! lol
Oct 09, 2009 | Compass 337 "rothco" Orienteering
Compass is no longer pointing North
I had the same issue. I found that if you re-calibrate the compass the same way you did the first time, then it will act properly. I've had to do this a couple of times and it works.
Jun 12, 2009 | Timex Expedition E Compass Watch Titanium...
Garmin etrex
This is a problem with the garmen, however, sometimes if you can remove the battery, and leave it out for one hour, then replace it while facing north outside, it usually re adjusts itself. also sometimes if you can reset the unit that will also sometimes bring it around. if that doesn't do it, I suggest contacting garman tech support, it may have to be sent in to have the software updated or it can be a defective unit, if it has been dropped., or gotten wet.
Jun 07, 2008 | Garmin eTrex GPS Receiver
Compass pointing in opposite direction
Do you have your unit set for north up or track up? This might cause this problem.
Apr 03, 2008 | Garmin eTrex Legend GPS Receiver
Garmin eTrex GPS Receiver Logo
189 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
