Question about IBM Creative Sound Blaster Audigy Sound Card
IBM COMPUTER -- SOUND BLASTER SOUND CARD PROBLEMS
I have an IBM, Windows XP Professional computer. I use this computer for recording purposes only. The problem I am having is this ... When recording I have an unbelievable amount of hiss. It has nothing to do with my audio software program I am using to record. It has nothing to do with my microphone or mixer, I know this because I set up my ever pc and the problem stopped. I have tried everything I can think of including adjusting the levels on my line in, line out and mic.
  • b3nraw1 Nov 29, 2008
    my mic don't work on the new sound blaster sound card
  • 53 Answers
Hiss is generally caused by lack of Mic gain. depending on the type of Mic your using. PC fan's can be the other.
If your PC is quiet, Your problem isn't cables and disabling anything. true, You should be in the right jack (input) for it to be effective. but if your getting signal that point is obvious.
PC recording carries many problems as well as benefits.
When grounding. Every studio I've wired has the console as the grounded component. everything else is lifted, and sheilds are tied back to the console. result... No loops at all.
If your PC is running through a console lift the PC's ground. this will help, not hinder the hiss.
Yes, Cell phones do bleed into any system live or recording.
but won't cause hiss.
I would also reconsider your choice of sound card. There are many to choose from. how ever, if you want quality, unfortunaly you'll have to buy quality. jury rigging as most of these posts seem to indicate will only bring you further frustration.
Buy some good gear first, and stick to the basics.
A good PC recording system does not need to have all it's inputs shut down to work effectivly. That's like saying an otari 90 needs 31 of it's tracks shutdown to record one single track.
If your working on a low budget first thing you should think about IS a good Condenser mic. then look at the sound card your using. you need a good bi directional card to be quiet.
You don't have to shut down inputs on a console to quiet things down. Just your tracks on the software.
You'll be surprised how much of the software does generate noise. ie compressor plugins, effects plugins all drive through the cards amp. thus doubling the noise masking itself as hiss.
If possible Isolate the PC from the area your recording in.
Use a screen or a pop filter on the mic to minimize room abience.another added factor to hiss.
Sounds like alot, I know but if you spend a little you'll get a lot.
and again stick to basics.
Good luck My friend.
44hink
Posted on Jun 12, 2008
    Problem Solver:
  • 4 Answers
Also make sure the speaker wire and the wire that plugs into the computer are not by any other wires because that could also cause interference.
Posted on Jun 10, 2008
    Master:
  • 474 Answers
All that sounds good. Also you may be getting interference from something else that isnt insulated. My wireless was causing all sorts of interference with my ALTEC speakers because they speaker wires arent shielded. My cell phone also causes interference as well.
Good luck.
Posted on Jun 09, 2008
    Problem Solver:
  • 4 Answers
Zarn is close to your solution. If this does not solve your problem than check earth point of your AC input. Your computer may not be getting earthing. Also try changing your speaker as its input cable may be faulty. Chek speakers earthing.
Goodluck
Posted on Jun 08, 2008
    Scholar:
  • 87 Answers
The best way to get rid of the hiss and noise is to do audio capture with a usb sound card. They make them with line inputs and can be grabbed up for less than $10 most of the time. The noise you get on a computer sound card is caused by all of the internals of the computer. There are many different options out there and that is the one that usually fixes it.
    Novelist:
  • 153 Answers
I presume you are going in through the mic socket on the audigy?
If so the most likely cause is a mismatch between the mic and the mic amplifier on the card, they are designed for cheapo condenser mikes that have a fairly high output.
Also make sure you disable any inputs that ar'nt in use to minimize noise.
If you have the Mike plugged into the line in you have it in the wrong socket.
The best way to get a good result is use an external mic amp or mixer and go in through the line in. Again make sure you disable any inputs your not using (in the computer mixer) and turn down any sliders on the external mixer that ar'nt in use to minimize noise.
If you'r still having problems get back to me with a more detailed description of your setup, whats plugged into where etc...
Best of luck
After I intall windows xp professional no sound driver detect how to fx the problem?
Go to your sound card manufacturers website and download the driver for windows XP OS. Install the driver and see if that helps.
Feb 01, 2011 | Gateway Sound Blaster CT4870 Sound Card
I just installed windows xp professional on my computer now i aint gettin no sound out of it
Download Sound drivers from IBM.com and install then try.
I hope that this has been very helpful for you
Dec 01, 2009 | IBM (01K2154) Sound Card
ERROR LAODING OPERATING system
Please boot in safe mode and uninstall the driver.
To boot inn safe mode:
- Start your computer
- Press F8 ( Just before it start booting into windows)
- Select safe mode
Apr 19, 2009 | Microsoft Windows XP Professional
Sound Blaster SB0100 drivers wanted. Any ideas?
for anything past xp you have to use software called the kx project which is for 30 and 64 bit vista and windows 7 drivers will work every time creative does not have posting past xp drivers the cards to old but its an oldie but a goody hope that helps
Jan 29, 2009 | Creative Labs SB0100 Sound Card
Sound blaster live 5.1 problems
u check whether your sound blaster is compatible with xp or not?
Jan 15, 2009 | Compaq / Creative Labs Soundblaster Live...
Sound card on legacy drivers
Hi
You Have Mother Board Drivers cd. Plz insert IN cd rom Drive your MBD cd go to Audio Driver's select Windows XP folder Next go to Setup.exe click Dubul from setup complete Install That Drivers reboot your system after that sound as com in your sys
ok if any probalm see www.soundrivers.com ok by
Apr 17, 2008 | Creative Labs Sound Blaster Live! 5.1...
Soundcard
This Sound Blaster X-Fi Vista Installation CD is intended to support X-Fi products bought before a Vista installation CD was available in the box.
It supports the following models:
  • SB X-Fi Xtreme Music (SB0460)
  • SB X-Fi Xtreme Gamer (SB0730/SB073A)
  • SB X-Fi Xtreme Gamer - Fatal1ty Professional Series (SB046A)
  • SB X-Fi Fatal1ty FPS (SB0466/SB0256)
  • SB X-Fi Platinum (SB0460/SB0251)
  • SB X-Fi Platinum Fatal1ty Champion Series (SB046A/SB0256)
  • SB X-Fi Elite Pro (SB0550/SB0510, SB055A/SB0510) This CD does not support the Sound Blaster X-Fi Xtreme Audio range (SB0790/SB0792).
This Sound Blaster X-Fi Vista Installation CD includes a full suite of drivers and applications:
  • X-Fi Mode Consoles (Gaming/Entertainment/Audio Creation)
  • Creative Mode Switcher
  • Creative Audio Console
  • THX Console
  • Creative MediaSource 5
  • Creative Smart Recorder 2
  • Creative WaveStudio
  • SoundFont Bank Manager
  • Creative 3DMIDI Player
  • Creative Diagnostics
  • Creative Entertainment Center
For more information on how to obtain a copy of Sound Blaster X-Fi Vista Installation CD, please refer to our regional sites at www.europe.creative.com or us.creative.com.
Windows XP applications do not work with Windows Vista. When launched, it will display a message "The audio device supported by this application is not detected. The application will exit" even though your Sound Blaster card is working properly.
If you have installed any Windows XP applications for your Sound Blaster X-Fi card, it is recommended that you uninstall these (Windows XP) applications before installing the Sound Blaster X-Fi Vista Installation CD. To uninstall, go to Control Panel, and select Programs and Features, and then choose the applications that you need to uninstall.
Nov 18, 2007 | Biostar P4TPT - Motherboard
Sound card driver for ibm desktop
If you restart the computer, it should detect and install them automatically. If not, try this. Click start, right-click my computer, then click properties. Click hardware, then device manager. Under Sound, find your sound card, right click it, then update driver. Follow the steps.
Aug 07, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
233 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
