Question about Insignia 37" LCD Flat-Panel HDTV
Hdmi connection i have my lcd hooked up to my ps3 with an hdmi cable. getting only sound. why?
    Problem Solver:
  • 8 Answers
When you first go to turn your PS3 on, instead of just pressing the power button quickly, hold it for 5-6 seconds until it beeps again, then let go. This forces the PS3 to autodetect and will bring it up in the 720P thats native to your monitor. I move my PS3 around between 3 totally different TVs and am constantly having to do this, it works.
Posted on Jun 17, 2008
    Novelist:
  • 170 Answers
If you're getting audio, then your PS3 is sending a signal through your HDMI cable. The problem sounds like your PS3 is sending a 1080P signal while your TV is a 720P Max Rez monitor.
Connect a composite cable from your PS3 to your TV, switch to that input, and change your output resolution to 720P or Auto. It is most likely set to 1080P.
Posted on Jun 09, 2008
    Problem Solver:
  • 8 Answers
Solution #2 is the first step and the easiest. and more than likely the correct one.
  • 103 Answers
The first suggestion is almost right.You need to set the video out to auto.This setting will auto adjust to the maxium resloution of the display.This will prevent problems in the future.The second issue is the set might not be hdcp compliant,which would prevent video to be displayed.
  • 38 Answers
Hi theromanator ,
Please switch on the ps3, go to the menu and change the video out setting to hdmi. this should solve your problem
Please vote for me if this solve your problem
ramesh22
Posted on Jun 08, 2008
Magnavox 42" plasma no picture or sound when hooking up ps3 to hdmi
try to adjust your resolution to the highest level, ps3 is a very high grapics device..
thanks.
Dec 05, 2012 | SNK Televison & Video
Trying to hook up PS3 to Panasonic viera LCD hdtv with HDMI cable and tv is not reading it and has no picture or sound. What may be the problem? Thanks!
hi,
ur ps3's HDMI out is a full hd video (1080p). if u r tv does not support full hd this problem can occur. do one thing. connect the ps3 to any full hd tv and go to its video setup, then down scale its video resolution to 1080i. after that connect the ps3 to ur tv. u will surely get video.
ok
Jan 11, 2011 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
Problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Dec 01, 2008 | Yamaha RX-V461 AV Receiver
PS3 - Sony Reciever HT-SF2300 - Aquas A83 LCD TV
Make sure you have selected the HDMI output option in the PS3 menu, otherwise you will get no picture or sound, connect you standard cable to your tv first which came with PS3 to do this first.
Nov 25, 2008 | Sony Playstation 3 (PS3) Console
PS3 setup to Denon AVR 2807 & Samsung LCD
Azahid
Since you are running the to LCD monitor instead of a LCD TV this is where you run into the issue. because the monitor is not setup to pull out the audio from the HDMI connection. So there is a few ways that you maybe able to to this.
The first one is look around at the different output cables out there the PS3. (I just got one so I do not know the accessories that are out for the PS3) This is becoming a common setup so if Sony does not have cable that will split off the audio then a 3rd party group may. I know they have one like that for the XBOX 360.
Another you can try is if your monitor will except an analog connection you may need to go that way. That is how I have my XBOX 360 that is my room connected. I have a RBG HD to VGA connect the VGA input on the monitor and the audio going to my sound card.
The reason why I suggested going analog is that right with our curent technology that if you are run with the 2 formats at the same time you will get audio/video sync issues. So you need to go all analog or all digital.
I hope this helps. Let me know if you have any other questions on this and/or need me to clarify anything.
Issken
Sep 29, 2008 | Sony Playstation 3 (PS3) Console
Hook up surround sound system to entire system
Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
Jun 01, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
HDMI into sony bravia
plug in hdmi cable turn ps3 off then on wait and a message will apera click yes then another message appers then click yes then it should work if not connect with the red white yellow plug and then change the settings to hdmi and plug the hdmi cable in
Sep 06, 2007 | Sony Playstation 3 (PS3) Console
Insignia 37" LCD Flat-Panel HDTV Logo
271 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
