Question about Bosch Washing Machines
MY BOSCH WASHING MACHINE ISN'T USING THE WASHING POWDER
  • 833 Answers
Is the powder in a dispenser? If so, the function is a problem. First, try the latch: does it move freely? If not, clean/replace that item.
There may also be a corroded connection or the solenoid actuator is bad. Inspect. Disconnect wires and test for continuity. When running a cycle, see if voltage appears when powder should be dispensed. If yes, solenoid is the problem. If no, wiring or timer.
Posted on Jun 08, 2008
Suds leaking from detergent drawer on brand new Bosch washing machine
Use high efficiency detergent that s more concentrated. It uses MUCH lesser detergent VoLUME than conventional. The detergent has "He" letter on the bottle. And usually with FULl load it uses only about 150+-cc ( my cup is on 3marked level provided by the detergent bottle) Hope this helps! Robert Calgary, AB
Dec 13, 2013 | Bosch Washing Machines
I have a Bosch Exxcel 1200 Express washing machine and notice that the fabric softener is not being flushed into the drum. Otherwise it washes OK. I have scrubbed out the powder tray and emptied the...
I hope you don't mind me saying so but often the softener dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!----------->
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this isn't the problem it could be that the water dispensing is not working correctly. It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 18, 2011 | Bosch Washing Machines
Our washing machine smells at the start of a wash cycle and smells of fish.We have done ample clean cycles using different products and washed using various washing powders and liquids etc at 90+c. is...
posibly not melting glue as there not used in making the machine try putting a blech hot water wash cycle a few times in the machine and if the washer is not being used leve the door open to allow the unit to breath and stop using powder wash detergent use liquid wash detergent
best luck
Nov 10, 2010 | Bosch Washing Machines
Sud message Bosch washing machine
ur using too much soap rinse and spin and use less soapwhen u wash
Feb 19, 2010 | Bosch Washing Machines
I take delivery of a Bosch washing machine on11th Dec but would like to know what detergent is recommended to use please
You can use virtually any brand of detergent, so long as it is recommended for front loading washers.
This is important ,as using the wrong type will cause problems with oversudsing..
You can also use tablets instead of powder.
Hope this answers your query.
Dec 08, 2009 | Bosch Logixx WFT 2806 Front Load...
Ive just brought a re-conditioned bosch classixx washing machine,
boil wash the machine with old towels and powder, 90 degree wash will bring out the bleach in the powder and the old towels will throw the bleach around the tub removing the bacteria that has grown in the tub, the bacteria comes from the washing powder to eat the dirt in clothes and sometimes gets left in the tub and pipes (most people only wash at 40 degrees the bleach wont come out the powder until at least 60 degrees hence the build up and smell). you may have to do this twice to get it smelling good, remove the drawer also and clean off any bacteria with a cloth and spray bleach.
Jul 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Slime buildup in my washing machine
The slime is almost certainly the enzymes in the washing powder that are there to digest the dirt getting left behind.
3 things you can try:
  1. As a one off to help clear out the slime, throw a couple of DISHWASHER tablets into the machine and run it through the hottest cycle it has. This may help get rid of the problem, but it will of course come back.
  2. Reduce the amount of washing powder you are using and keep cutting back until you get to the point where the clothes arent getting clean (This has the advantage of cutting the cost of your powder purchases too!). This should allow the machine to more effectively purge the drum when it rinses.
  3. Finally, change your powder, if for no other reason than a test, go try a pack of NON-BIO washing powder and see if that helps. If it does, either stick with it or experiment with other powders until you find one that helps and you like.
A combination of 2 and 3 above should eventually get you where you need to be.
Mar 01, 2009 | Bosch Washing Machines
Bosch axxis washing machine detergent symbols
There are usually 3 compartments in the drawer, the smallest is for using fabric conditioner, the largest is where you put the powder or detergent in, the middle size one you do not put anything in, as it is where the cold water comes in for rinsing.
Plz rate my solution.
Thanks.
Jan 26, 2009 | Bosch Logixx WFT 2806 Front Load...
Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage. Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
Jun 10, 2007 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
110 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
