Question about Panasonic PV-DF2700 27 in. TV/VCR/DVD Combo
When turned on only gets a straight line of color in middle of screen
When i turn on the tv and it is a dvd and vcr combo i get excellent sound but only get a straight line of color in center of screen going all the way across horizontally
  • Anonymous Dec 30, 2008
    i have aninsignia 32" tv 3yrs old and I'm having same problem. there is straight white line with some color in middle of tv.
  • 58 Answers
Also on these sets, the vertical I.C. gets cold solder joints.
resolder them before replacing the I.C.
guy9
Posted on Jun 10, 2008
  • 20 Answers
You must change the capacitors around the IC before replacement. usually 100uf is the biggest failure, It may have also burned a 1 ohm or so resistor
Posted on Jun 08, 2008
    President:
  • 3,130 Answers
You lost your vertical sweep. most likely the vertical output IC or a power supply source is the problem.
Can't record tv shows
Output of combo to input of TV, and you need the cable / antenna attached to the combo to record what you want to see.
Jan 11, 2010 | Philips DVDR3545V/37
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Sound only
Means the TV is foobar. How do you connect it? TV Aerial, cable, RCA, SCART, S-Video, Composite, HDMA. Checked your cables, made sure they are all snug? Made sure your source (eg DVD player) is OK?
Dec 27, 2008 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
TRYING TO HOOK UP OLD RCA COMBO (DVD/VCR) TO MY NEW TV. USING THE RED/WHITE/YELLOW CABLES ALONG WITH PUTTING MY CABLE SIGNAL DIRECT INTO THE DVD/VCR PLAYER AND THEN CONNECTING THE OUT LINE TO THE NEW...
ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
Oct 16, 2008 | RCA Televison & Video
Straight line
You need to replace the vertical output transistor. part are available online at www.digikey.com
Aug 24, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Dec 18, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Panasonic PV-DF2700 27 in. TV/VCR/DVD Combo Logo
253 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
