Question about Cisco Catalyst 2926 (WS-C2926) Networking Switch
Catalyst ws-c2926 password recovery problem
I have troubles recovering the password on a cisco catalyst WS-C2926. I am following the Cisco procedure step by step and still can not make it. After loading the image (just before pressing "Enter" ) it asks me for a username and trying to connect to a TACACS server. Then I can get to the console but it is asking me for the privilige mode pass. Please Help!!!
P.S. I managed to recover the password using the same procedure on a Cisco Catalyst WS-C2900
  • 1 more comment
  • Steve Rand
    Steve Rand May 11, 2010
    So you've done the above mentioned step, set the config register back to normal, rebooted... then it still wants an enable secret? It would be whatever you set it to when you booted without the config. (as the password recovery procedure goes)
  • Vakhtang Assatrian May 11, 2010
    If it is not getting to fresh config then it means only 1 thing - you are not properly applying the following command: "rename flash:config.text flash:config.old" to rename the configuration file.
  • Emma Lee Feb 20, 2014
    agreed to steve, you can make it.
    Problem Solver:
  • 16 Answers
  1. Attach a terminal or PC with terminal emulation to the console port of the switch. Use the following terminal settings:
    9600 baud rate
    No parity
    8 data bits
    No stop bit
  2. Unplug the power cable.
  3. Hold down the mode button while reconnecting the power cord to the switch. You can release the mode button a second or two after the LED above port 1x is no longer illuminated.
    The following instructions appear:
    The system has been interrupted prior to initializing the flash file system.
    The following commands will initialize the flash file system, and finish loading
    the operating system software:
    flash_init
    load_helper
    boot
  4. Type flash_init.
  5. Type load_helper.
  6. Type dir flash:. The switch file system is displayed:
    Directory of flash:
    2 -rwx 843947 Mar 01 1993 00:02:18 C2900XL-h-mz-112.8-SA
    4 drwx 3776 Mar 01 1993 01:23:24 html
    66 -rwx 130 Jan 01 1970 00:01:19 env_vars
    68 -rwx 1296 Mar 01 1993 06:55:51 config.text
    1728000 bytes total (456704 bytes free)
  7. Type rename flash:config.text flash:config.old to rename the configuration file. This file contains the password definition.
  8. Type boot to boot the system.
  9. Enter N at the prompt to start the Setup program, Continue with the configuration dialog? [yes/no] : N
  10. At the switch prompt type en to turn on enable mode.
  11. Type rename flash:config.old flash:config.text to rename the configuration file with its original name.
  12. Copy the configuration file into memory: Switch# copy flash:config.text system:running-config
    Source filename [config.text]? (press Return)
    Destination filename [running-config]? (press Return)
    The configuration file is now reloaded.
  13. Change the password: switch#configure terminal
    switch(config)#enable password Cisco
    switch#control/Z
  14. Write the running configuration to the configuration file:
    switch(config)#write memory
Posted on Feb 09, 2009
What is the difference between WS-C2960X-24TS-L and WS-C2960X-24TS-LL?
The main difference between WS-C2960X-24TS-L and WS-C2960X-24TS-LL as below:
WS-C2960X-24TS-L 4 SFP Uplink, WS-C2960X-24TS-LL 2 SFP Uplink.
WS-C2960X-24TS-L supports FlexStack-Plus stacking while WS-C2960X-24TS-L does not.
WS-C2960X-24TS-L with LAN Base feature set, WS-C2960X-24TS-LL with Lan Lite feature set.
I hope it can help you.
WS C2960X 24TS
Mar 05, 2015 | Cisco Computers & Internet
Do I need to buy a software license for WS-C2960S-48FPS-L?
No. WS C2960S 48FPS uses the Universal image, but no license is required. The feature is bound to the hardware model type and cannot be changed. For convenience, a single software image is used for all Cisco Catalyst 2960-S Series Switches, regardless of whether they are a LAN Base or LAN Lite model.
Jan 20, 2015 | Cisco Catalyst 2960 Ethernet Switch ...
The power devices that Cisco Catalyst 2960 Series Support?
The Cisco Catalyst 2960-48PST-L can support 48 PoE ports with total PoE power output capacity at 370W. Taking advantage of Cisco Catalyst Intelligent Power Management, the Cisco Catalyst 2960-48PST-L configuration can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between.
The Cisco Catalyst 2960-24PC-L can support 24 simultaneous full-powered PoE devices at 15.4W for maximum powered-device support.
The Cisco Catalyst 2960-24LT-L can support eight PoE devices at 15.4W
Cisco Catalyst 2960 Switches for the details
Aug 15, 2014 | Computers & Internet
Cisco 3750 web config
Yes, know more about the Cisco 3750, just visit: http://www.3anetwork.com/cisco-catalyst-3750-switches-price_c41
Dec 26, 2013 | Computers & Internet
Cisco WS-C2960-24-S switch port not working
Can you tell more details, there's various possibilities to cause the switch not work...
You can check your switch from these way:
1 check your cenect cord
2 check the power supply
3 check your network environment
For the Cisco switches, if you have any problems you can feel free to send email to our technicist:
support@3anetwork.com
Cisco Price Cisco Switch Price Cisco Router Price Buy Cisco Switches...
Dec 14, 2012 | Cisco Catalyst 2960 24 10/100 (8 PoE)...
Password Recovery for Cisco Catalyst 4506
Please see Cisco's page at http://www.cisco.com/en/US/products/hw/routers/ps5199/products_password_recovery09186a0080093e12.shtml
for step by step details and more in depth instruction.
1. Reboot
2. Press the "break" button on your keyboard within 60 seconds of the power-up to put the router into ROMMON mode.
3. confreg 0x2142
4. reset
5. type, "no" when prompted to enter the initial configuration dialog.
6. enable
7. copy startup-config running-config
8. conf t
9. enable secret <password>
11. config-register 0x2102
12. reboot again
Jan 20, 2010 | Cisco Catalyst 4506-E Cat4500 E-series...
Problem with module WS-X4548-GB-RJ45V in Catalyst 4506
use software advisor in Cisco website to verify it.just follow the process.
console to it and show diag and see whether it detectable or not.
hope this help.
Dec 02, 2006 | Cisco WS-X4548-GB-RJ45V= Expansion Module
Cisco Catalyst 2926 (WS-C2926) Networking Switch Logo
611 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
