Question about GPS
My Garmin nuvi 760 does not find any MP3 files on the SD Card Drive. It finds them fine if I put them on the unit itself but nothing on the SD card.
    Brigadier General:
  • 6,966 Answers
Was the SD Card formatted using the built-in format function of the Garmin nuvi 760? If, not pls try, if yes, pls try another card or the same card to another device that can make use of such type of memory card.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 07, 2008
NUVI 760 2010 MAP UPDATE ERROR CODE 2
The easiest solution is to put an sd card (8gb or less) into the sd slot. Have Garmin Express install to the sd card.
You can also do a hard reset and try to install to the device itself. A hard reset restores the files to factory default, so it may free up enough space.
May 09, 2017 | Garmin Nuvi 760 Car GPS Receiver
Garmin nuvi 760, don't seem to be able to load music onto it
I have a 660, and it works fine from the sd card. Make sure the files are .mp3 and that you toggle the source from the mp3 player screen. Can you see the files in browse mode ?
May 08, 2009 | Garmin Nuvi 660 GPS Receiver
Unocking Garmin SD maps
it is in the box it came with, on the back of the instruction book.
If you did not buy it 'new in the box', you will have to refer to the 'activation' code sent to you email.
The Garmin Nuvi 760 does not require SD card maps if you are using it in the US, btw...
-d
Feb 15, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Jan 26, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
I have a garmin nuvi 760, and I am trying to put mp3 files on it through an SD memory card. I have re-formatted the card 5 times, and my gps still isn't reading it. How can i fix this?
Garmin states.... The most common reason the GPS would not recognize the the audio files is the file format. The GPS will not read any file format other than the mp3 format, such as itunes (mp4) format, wave files, Windows media player files etc.... If the files will not read from from the internal memory of the GPS, the file format is the most likely cause......
Dec 23, 2008 | GPS
Loading mp3 files to garmin nuvi 350
The device is not recognizing the file name. The Garmin GPS will only recognize MP3 files. Ipod (MP4) and other media files will not play. Converting the files to the MP3 format will correct the problem.
Jul 25, 2008 | Garmin Nuvi 350 Car GPS Receiver
Audiobooks on a Garmin Nuvi 650 GPS
I just read on the Garmin website that only regular MP3 files will work -- not books or music purchased through iTunes.
Dec 29, 2007 | Garmin Nuvi 660 GPS Receiver
Deleted MP3 files still play on my Nuvi 660.
Go to the GARMIN M3U file , open it and do what you want .Transfer, delete , copy and so so....
Dec 23, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
134 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
