Question about Pioneer DEH-P6800MP CD Player
Cuttinng out hi there, my pioneer head unit cuts sound when i close the boot or hit a bump, just wondering wat the problem might be
    President:
  • 624 Answers
Does it cut out when you are listening to the tuner as well as the cd player? If so, you have a bad connection somewhere. Sometimes the solder joints inside the radio can be cracked and will cut out when you hit bumps. May be a wire that is a little loose. Check all the wiring.
If it only cuts out when you are listening to the CD player, you may need the lens cleaned or the laser replaced. Sometimes the cd player cuts out because the unit has too much wiggle room and it bounces a little when you hit a bump causing the cd to skip or cut out. and there is always the dirty CD. Try cleaning the CD's with windex and a soft cloth like a bath towel. It works great for me and is cheap. Fingerprints can and will cause a cd player to skip.
Posted on Jun 17, 2008
Radio Cuts Off Over Bumps
Hi Scot, try checking the ground on your radio to be loose or corroded. Have nice day.
Feb 01, 2012 | Harley Davidson FLHTCUI Electra Glide...
My Kenwood KDC-325 would frequently cut in and out, the sound would go off randomly while driving, and I would have to go over a bump in the road or a pot-hole and the sound would come back on. Recently it...
High chance that the fault was not came from the wiring but in the unit itself. This kind of symptoms is an indication that there is a bad solder joints (cracked, dried, cold solder) in the sound output circuitry. This circuitry is responsible for producing sound and feeds to your speakers. Since the unit is totally muted(no sound), this circuitry is disable due to said reasons. The only way to back it from normal operation, it needs to take apart and re-solder the joints in this circuitry. You need an assistance of a qualified technician to do this job.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jun 17, 2011 | Kenwood KDC-325 CD Player
Does this head unit play mp3 cds?
Hi there smallz
This unit from Pioneer will play discs you have burned... CDR format, but not MP3. .
Thanks for using FixYa. Dont forget to hit me up some thumbs for checking that out for you. Cheers
regards robotek
Apr 18, 2010 | Pioneer DEH-1800 CD Player
Deck turns off when i hit a bump in my car
A couple things...but the deck must come out to check. (assuming this is a 12v N.American car) If you cannot remove or you dont know how - take it to a car stero shop. Electrical fires are nasty!
  1. Make sure there are no open wires and connections are tight and taped (badly crimped connectors will hide loose connections)
  2. Make sure the deck is supported in the back-it should not wiggle around.
  3. There should be a wire firmly connected to the chassis of the car and the back chassis of the deck - Please do not drill into the deck - use an existing bolt !
Nov 07, 2009 | Pioneer DEH-1100 CD Player
I own a Pioneer DEH-9650 and want to connect Apple ipod touch.
Hi I was wondering were can i buy any one of these head units, i really want the Pioneer Deh-p9650. but i cant not find one place were i can buy it. i usto have the 8400mp like 6 or 7 years ago but i sold it and now i want a nother 1... i would really like to buy the Pioneer Deh-p9650mp so if any one can point me in the right direction i would be more then greatful.
thanks
DEH-P9650MP ??
Sep 14, 2009 | Car Audio & Video
Disconection the sound
This will be a protection feature of the head unit. If you are not using an amplifier, when the power required by the speakers exceeds the power output of the head unit, it will cut out until the volume level is reduced.
If the head unit turns completely off, you may consider adding an amplifier to the sound system.
Jun 16, 2009 | Pioneer Car Audio & Video
My pioneer head unit cuts the audio signal to my speakers
3 things make sure all the speakers in the car have tape to avoid grounding the speakers
next make sure all wires in back of unit are taped
if all that is taped good its the amp over loading use a larger ground wire to fix this
hope this helped
Feb 25, 2009 | Pioneer DEH-P4000UB CD Player
Pioneer DEH 3700 ground problems/system noise
Very common with pioneers. their is a ground loop fuse-located inside the head unit, that has to be repaired at the factory. Or, the best way-just like you said, is to ground the rca's, solder a thin wire to each rca, easiest and cheapest way. I had it happen to me with a 4800.
Mar 23, 2008 | Pioneer DEH-3700MP CD Player
Pioneer DEH-P6800MP CD Player Logo
174 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
