Question about Acer TravelMate 512DX Notebook
ACER Travelmate 512DX totally blocked
Switching on the computer, the top left corner of the screen shows an icon (of a red monitor with a key) requiring a password of max 7 digits.
After 3 attempts the computer is completely blockede and you need to restart it depressing the ON/OFF pushbutton; neither is possible to access the BIOS because the F2 button, nor any other combination of commands, doesn't work.
No one set any protection key.
Since the last 4 years the compouter wasn't connected to internet and was rarely used by my sons for school exercises.
    Sergeant:
  • 458 Answers
Some computer companies have an ATMEL chip on their laptop motherboards. I have found this on an IBM Laptop. The IBM Atmel chip has to be cleared on these. They have the same problem that you have. I have also seen a Toshiba do this.
I did not see anywhere on the internet where you should have the same problem Just wanted to pass that along to you for future reference.
You can try the following for your problem. Sounds like someone at some time had to have messed around and put a BIOS password in. To clear this you will have to find the CMOS battery to clear the password. This will have to come out for a couple of minutes and then turn the system on. This should fix your problem. The CMOS battery looks like a big watch battery. There might be a switch or button near the battery that can also do this,
The reason that I told you the first problem that I had; was that I did what I told you to do to solve this same problem. A customer had bought a IBM laptop and it had a BIOS password in it. I took the battery out of it to clear the password. IBM even told me that I could do this. When I did this, I found out that there was another password in it that was not there before. Some laptops can have many types of passwords in them. The hard drive, or bios can be passworded. When the hard drive is passworded, the hard drive password will always be in it. The original system is the only one that can take the password out of the hard drive unless the new laptop is capable of taking it out or changing it. This could be your problem. The hard drive could be passworded.
I might seem crazy to you, but I wanted to explain all of this to you so you could see everything that could go wrong. I hope that taking the CMOS battery out will solve your problem. If it does not you will have to cross the connections where it is installed when it is booting up.
Please let me know if this works. It can help me help others with the same problem in the future.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future. If you need more help, feel free to keep asking, but keep the original information so I can see it.
Posted on Jun 07, 2008
    Scholar:
  • 119 Answers
Obviously someone did go into your bios setup and enabled the administrator password otherwise it would not ask for one. Now there are only two ways around this problem. 1 you will have to find yourself an experienced technician who is clued up with bios systems and motherboards, because what he needs to do is reset or in some circles they call it, flash you bios and thus this will reset the password and you machine will no longer ask for it inless you set it up again. this it a fairly simple procedure but it has to be done the right way otherwise you might cause other problems. 2 you could just replace you motherboard and problem solved (expensive).
How do I adjust the screen brightness on my acer travelmate 2400
  1. Hold down the Fn key located at bottom left of your keyboard next to the Ctrl key.
  2. Adjust the screen brightness using the up and down arrow keys located near the bottom right corner of the keyboard.
Nov 14, 2012 | Acer TravelMate 2400 Series Laptop Charger...
Cannot open my laptop,acer aspire 4720 zo1 series
Totally No Display? Is the laptop running? Do you hear fans running, disk drive spinning and lights? If it seems like the laptop completed the boot process except the screen is black, try this:
Shine a flashlight on the dark screen to see ifyou barely see the icons on the desktop. If so, then the LCD Inverter isbad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on
Apr 19, 2012 | Computers & Internet
Hello i cant reach wifi conection on Acer travelmate 4500,its show: ,,The hardware radio switch its off.,,
the error is shown because the hardware was switched off manually. Try switching it on again by holding down the function key and pressing the corresponding function key with the wifi icon on it.
Mar 27, 2011 | Acer TravelMate 2300 Notebook
@@My laptop is locked, it has a red laptop icon top left of the screen with a key next to it. I can't enter the setup.
have you tried a password? if you put in a password x3 incorrectly it should come back with a code.
Jan 18, 2011 | Acer TravelMate 735TLV Notebook
Acer travelmate 5510 and the screen needs to be lighter - people say to me how dark it is! Don`t know which of the buttons to push.
Press Fn key next to CTRL key and use the left and right arrows to make screen dimmer and brighter whole still holding the Fn key down. :)
Jul 08, 2010 | Acer AL1715 17" LCD Monitor
TravelMate 3270-6569 (LX.TH706.051) PC Notebook: My acer travelmate 3270 is connected to a sony dat...
Try holding down the Function key (Fn), then pressing F5. Wait a few seconds. On most laptop, each press of the F5 key will toggle between laptop display only, projector only and Dual (same image on both - my favorite).
You'll probably see a little Monitor-shaped icon on the F5 key. It's possible it's another function key - on Dells it's usually F8.
Aug 02, 2017 | Acer TravelMate 3270-6569 Notebook
Hp laptop is has docking station connected to acer monitor. The acer monitor has the desktop background but does not show desktop icons. How do I get the icons to show on acer monitor
you will probably find that you have set the screens to run side by side, do a check by clicking the identify monitors, icons will be normaly on the left screen, check the dispay settings and you probably want to set the monitors so they both are showing the same screen at the same time.
good luck.
Jun 30, 2009 | Acer AL2016W 20" LCD Monitor
Keyboard removal on a TravelMate 512DX PC Notebook
The battery could not be fished out afer removing the memory expansion door?
Jan 19, 2009 | Acer TravelMate 512DX Notebook
Acer TravelMate 512DX Notebook Logo
147 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
