Question about Nokia 3230
My phone restart automaticly pls help
Hi
my nokia phone got switched off automaitcally n then did not start gain ....chked with loacal nokia dealer the restared it saying that its reformatted ...buit after that it didnt start ...is thei any way i can get my memory contacts n then reinstal teh software ...v
  • ajitpillai76 Jul 14, 2008
    restarts thrice on rebooting and then switches off.In between restarts,doesnt give enough time to even access the menu.
    Problem Solver:
  • 15 Answers
For the cellphone automatically switched off the problem is the switch,if there is one who look anf fixed that cellphone but he did not fixed try to consult to another cellphone technician maybe it will fixed.
Posted on Jun 18, 2008
Hi i have nokia n72 phone. its only working in offline, if i change the profile its showing insert sim card, so pls help me
Hi, kindly switch off the mobile and restart it, once you restart this will ask u phone is currently offlline mode u want to countniue, that time click no, phone will start.
May 31, 2011 | Nokia N72 Cellular Phone
2730 switch off after nokia
my phone is Nokia 2730,Problem is switch on after nokia tone come to automatically off,pls help me?
May 03, 2011 | Nokia 2730 Cell Phone
My nokia3110c automatically switch off.
Check out this link....many kinds of solutions are provided,one of which should work for u...I suggest that u should start from the bottom of the page.
http://discussions.europe.nokia.com/t5/Hardware-Codes-and-Operator/Nokia-3110c-Automatically-restarting/m-p/186824
Mar 04, 2010 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
I forgot my phone Nokia 2626 security code...how to unlock?
I want Nokia 2626 Master Reset Code,,So pls Brother Kindly give the favour and solve my problam,,i forget my code
Aug 14, 2009 | Nokia 2626 Mobile Phone
Phone restart automatically
enge cp poh pde khit anung unit
Apr 18, 2009 | Nokia 3110 Cellular Phone
Nokia 2630 restarts
hi first u do the factory reseting.. then u face same problem just reinstall ur software in ur nearest nokia care center.. if u have warrenty its free of cost..
Sep 10, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Can't switch on my Nokia 6233
my nokia 6233 mobile cant swich on my friend tell me a mobiles flash software and mobile swich on automaticly. please help me
Jul 09, 2008 | Nokia 6233 Cellular Phone
Software problem
Flash your phone Rom and update it software. if problem still persists then thee problem with the hardware part.
Nov 19, 2007 | Nokia 3230
Regarding Nokia 6600
Remove the memory card then check.if ok.Scan the memory card with appropriate antivirus software. Then format phone using * 3 call button then switch on your mobile
Apr 29, 2007 | Nokia 6600
Nokia 3230 Logo
89 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
