Question about Nikon D40X Digital SLR Camera Digital Camera with 18-55mm Lens
CONSTANT FLASHING CF LAMP NIKON D300
I recently noticed the CF lamp on Nikon D300 is constantly flashing and draining my battery power when the camera is off. I have tried inserting a new compact flash card Lexar Professional udma x300 2g card and have reformatted my existings memory cards (San disk extreme III 2gb & Lexar Professional Udma x300 4g card) with no success. Camera was working fine with these cards up until a couple of days ago. Can you help please?
Gary
    Brigadier General:
  • 6,966 Answers
Am afraid that it is an internal hardware problem. Chances are that the electronic trigger that fires the flash has shorted out and is therefore making the flash work even with the camera off. Since this would involve electronic circuitry and components, use of a DVM and a low wattage soldering iron or even a hot air blower, perhaps your best bet would be to seek the services of a qualified professional. Often even if you can actually open the unit for a look and see of the trigger/flash module, replacement part availability would be a major concern.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 07, 2008
  • Louie  Role
    Louie Role Jun 07, 2008
    Hi again,
    After rereading you post , you could try cleaning the memory contact pins/terminals and see if this helps or correct the issue.
Nikon D90 flashing green light runs down battery even in power off mode.
Possible short to the top cover circuit around and including the on/off switch - spillage, wear of switch.
Apr 06, 2012 | Nikon D90 Digital Camera with 18-105mm...
No LCD display, "CLOCK" flashing
Seems the camera's internal battery (different from the EN-EL3 main battery) has drained. As the manual says, you can recharge the internal battery by leaving a fully-charged main battery in the camera for three days.
If the camera continues to pester you for clock setting, you'll have to send it in for service. (Opening the camera likely voided your warranty, btw.)
Mar 30, 2011 | Nikon D70s Digital Camera
Why is it my memory card indicator light on my Nikon D90 keep flashing when i switch off my camera???? which caused my battery to run out all the time??
The memory card indicator light flashing indicates that data is being written to the memory card. At he bottom of page 29 of the User Manual it states.
DO NOT remove battery or disconnect power source while the lamp is lit. Failure to do so could result in DAMAGE TO THE CARD.
REFER TO PAGE 29 & 39 of the USER Manual for further details.
You may possibly have a fault with the camera and it is this that is causing the battery to drain, this needs to referred to a qualified Nikon Service Centre
Mar 03, 2010 | Nikon DSLR D90 Digital Camera
Picture went out completely flashing red status light 4 flashes pause constant
Most likely the lamp is burnt out (indicator goes to constant red status). Replace lamp (get lamp P/N from User Manual for replacement), clean any dirt around lamp, fan, and rear filter. Do NOT get any fingerprints on new lamp.
Aug 11, 2009 | Mitsubishi WD-62825 62" Rear Projection...
TV switched off and lamp is flashing red
you need to buy a new lamp you can order them on line or order from like a Bestbuy,no way around it
May 12, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Don't know which card Nikon coolpix900
I believe the coolpix 900 takes compact flash (CF) I wouldn't worry about getting a particularly good one though just a standard CF card would be sufficient for testing purposes.
hope this helps.
Drew
Nov 15, 2008 | Nikon D300 Body Only Digital Camera
Sensor Cleaner making noises?? (Nikon D300)
Yes, all D300 makes this noise when the sensor is being cleaned.
Apr 24, 2008 | Nikon D300 Body Only Digital Camera
Nikon SD card for D80 / D200/ D300
You should have no trouble using the SDHC cards. SDHC stands for Secure Digital High Capacity. The images should load directly from camera to computer, without the need for any additional hardware.
Feb 12, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D40X Digital SLR Camera Digital Camera with 18-55mm Lens Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
