Question about Gateway FPD2275W LCD Monitor
Imonitor problem i have a microtek monitor it is about 10 years old. whenever i start it its picture starts fluctuating and keeps doing for 5 or 6 minutes and after that it gets still by itself ,it also doesnt shows colors properly ,all the picture seems darker . so what can be done about it?
Soyo DYLM1988 vertical hold/jittering picture problems when starting up. Clears when warmed up & playing with monitor settings helps.
How old is the screen? if more than 5 years, the circuitry can go bad. I had this with one of mine, it would jitter for about 10 mins before it warmed up. Just get a new one, they are cheap as chips
Sep 27, 2017 | Soyo DYLM1988 Monitor
MICROTEK C997SD MONITOR SHUTS OFF AFTER 5-10 MINUTES
If you turn your monitor on and when its on you go into your computers settings. Where you can fix your monitor and fix the resolution and all that. There should be a thing there where you can put never shut off. You have it on 5 to 10 minutes to shut off. That will keep the monitor from turning off again. I did this with mine it kept shutting off to. Thanks for posting I hope this helps you. I am sorry I couldn't be more detailed. i have been up all night lol.
Dec 12, 2017 | Microtek C997SD (Silver) 19 in. Flat Panel...
Full screen fluctuation in Acer Laptop.
Sound very much like your LCD inverter might be going luckily there pretty cheap and you should be able to find one on Ebay.
An LCD (liquid-crystal display) inverter is a component in laptop computers that supplies the power to provide a backlight to the monitor, enabling the user to view what's on the screen. This component is commonly the culprit when the monitor goes out and can be moderately simple to replace.
Feb 03, 2010 | Dell Inspiron 6400 Notebook
? to turn off key lock?
Enter in main menu, settings, touch protection. This should help you
Sep 14, 2009 | Microtek 997M 19" Flat Panel LCD Monitor
House power fluctuates, UPS and computer die.
Sounds like the internal battery of the UPS needs replacement. Contact APC and ask for a qoute for a replacement battery/service. It'll probably work out a cheaper to buy new.
Make sure you dispose of the old unit properly if you do replace
Jul 07, 2009 | APC Back-UPS CS 500VA UPS System
I have connected my microtek lcd monitor to my dell laptop computer. the monitor is plugged into electric outlet. the green light on the front of the monitor blinks. and i get a report of "no signal" but...
Have you tried pluging in the monitor in to the laptop before even starting the computer or Putting the computer in to "Stand by" then pluging in the monitor and then bringing the laptop out of "Stand by" or yet when you do have the computer on with the monitor pluged in, try "Fn" and a button hat has like two screens on it with a small bar in between them? All these should work.
Jan 04, 2009 | Microtek 997M 19" Flat Panel LCD Monitor
LG Studioworks 700E
It sounds like one of the capacitators inside the monitor is malfunctioning, these little things store a certain amount of necessary power and then discharge it when it is needed.  If it is malfunctioning, it could explain why it takes so long to charge, and why when you hit it, it suddenly comes on.
Jan 09, 2008 | Computers & Internet
LG Studioworks 700E
seems flyback problem ,leave it to the repairman...
Aug 19, 2006 | LG Studioworks 700S 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
35 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
