Question about Toshiba 55H70 55" Rear Projection Television
55h70 Hi, do you know how to enter the service mode on this model?
    Problem Solver:
You need the service manual to navigate through the service functions. I not trying to sell you anything but I know from experience. The manual is not expensive and I will attach the link were I got mine. You can get the entire service manual emailed to you from the following link.
http://servicemanuals.vstore.ca/
Guru Slinteriors helped me with mine and a great source of knowledge.
Posted on Jun 11, 2008
Model W240. How can I enter service mode?
enter service mode Mohammad, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Entering Service Mode HP LaserJets
canonipf Service Mode
Service Manual free download schematics datasheets eeprom bins pcb repair...
Ricoh 6000 service mode
Apr 11, 2016 | Ricoh Office Equipment & Supplies
Tip
Toshiba 55H70 Service Manual Download
Download Toshiba 55H70 Projection Television Service Manual
Models: 50HX70 / 55HX70 / 61HX70 / 55H70 / 61H70
Have you misplaced your Toshiba 55H70 Projection Television Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 55H70 Projection Television Service Guide?
Follow this link
(& click FREE) to download a pdf version of the Toshiba 55H70 Projection Television troubleshooting & repair instructions.
I hope that helps.
_______________________________________________
Toshiba 55H70 Manual Download
on May 10, 2010 | Televison & Video
Tip
Download Toshiba 55H70 Projection Television Manual
Have you misplaced your Toshiba 55H70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 55H70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 55H70 Projection Television instructions.
I hope that helps.
I don't know the model code
Hello
You are a technician and you whats to know the model service code I thinks, and posts this solution.
Use the Remote Commander (RM-Y183, RM-Y184) to perform the circuit adjustments in this section
SETTING THE SERVICE ADJUSTMENT
MODE
1. Standby mode (Power off).
2. Press the following buttons on the remote commander within one
second of each other:
DISPLAY Channel 5 Sound Volume + Power
READING THE MEMORY
1. Enter into service mode.
2. Press 0 on the remote commander.
3. Press ENTER to read memory.
ADJUSTING THE PICTURE
2. Press 2 or 5 on the remote to select the device item.
3. Press 1 or 4 on the remote to select an item.
4. Press 3 or 6 on the remote to change the data.
RESETTING THE DATA
Note: Be careful when using the remote! It will clear and re-initialize
ALL NVM data including defl ection adjustment data if not reset
properly as follows:
5. Press MUTING then ENTER to write into memory.
RESETTING THE DEFLECTION NVM DATA
2. Press 7 , then MENU, and then press ENTER on the remote.
RESETTING THE SYSTEM NVM DATA
2. Press 7 , then 9 , and then press ENTER on the remote.
2. Press 8 and then press ENTER on the remote.
MEMORY WRITE CONFIRMATION
METHOD
1. After adjustment, pull out the plug from the AC outlet, then replace the
plug in the AC outlet again.
2. Turn the power switch ON and set to Service Mode.
3. Call the adjusted items again to confi rm they were adjusted.
Ok.
Nov 30, 2010 | Sony KV-32XBR250 TV
Can't adjust the value of the width in Service mode ' WID '
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 05, 2007 | Toshiba 55H70 55" Rear Projection...
Tip
Follow this link
I hope that helps.
on May 10, 2010 | Toshiba 55H70 55" Rear Projection...
Tip
I hope that helps.
Toshiba 55H70 had convergence problem fixed that now vol.went out
check to make sure that the tv switch on the back panel for surround sound is not in the on position check the customer menu to make sure that the speakers are turned on
Sep 28, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 convergence problem fixed but now vol.is gone
I just posted a question about a convergence problem( juice07 ). I am unable to adjust the red color in the convergence adjustment mode. Did you have a similar problem ?? Please help.
Sep 28, 2006 | Toshiba TP50H50 50" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
