Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi petrol 30cc Trimmer plt 3043 ye
I have pulled the bottom part of the trimmer because only one side of line was sticking out, but now i dont know how th re thread it, or how to put it back on.
Hi! With the red know in one hand, push the spool down with th other to the female threaded shaft comes to the top. Then, hold the red know in the other hand with your index finger on the bolt in the middle, holding it down. Now start threading it onto the female shaft COUNTERCLOCKWISE! Once you get it, it get's easier. Good Luck!~Frank~
Posted on Jun 16, 2008
I have a Ryobi RPT3000 trimmer. Firstly how do I top up engine oil? And then how do I restring it?
The engine on that trimmer will be a 2 stroke 30cc engine not a 4 stroke.
"Two Stroke Oil" is added to the fuel for a 2 stroke fuel mix in accordance with the proportions specified by Ryobi for that engine. The required petrol/oil mix may be printed on the top of the fuel cap. No other oil is used in a 2 stroke engine.
There are a number of videos on Youtube people have uploaded which will show you how to replace the pull cord on a trimmer.
Dec 28, 2015 | Ryobi Garden
I have a partner colibri strimmer. How do I lock the driveshaft to change the line spool head ?
You should have a small hole in the side of the head that a small rod goes in to lock it. Just line the holes up and stick the rod or a nail in there and it should be locked.
Jul 11, 2014 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
Ryobi 26cc gas trimmer. Can't replace line. Used 1 8'' line thru slots in spool. (3'' each side). Don't understand next step. Push down spool and twist? Should spool stay level...
You line up the head with "arrows" by turning the plastic bump knob on extreme bottom. When arrows line up with the head then you insert your line through the slots "OR" you insert the line in one side and it comes out the other side. Then you have to push pressure DOWN ******* the bump head while twisting the bump head clockwise to "pull in" the string until there's only about six inches left remaining on the "shortest" piece hanging out the side. use scissors to make the lines equal in size before staring the trimmer. Hope this helps.
Sep 08, 2017 | Ryobi 30cc 17" String Trimmer Zrry30530...
Ryobi 30cc trimmer won't run. Difficult to start, hard to keep ru
chnge the plug for the best you can get then depending on the mix petrol oil mix u could cahnge that ie if its 50:1 go down to 40:1 or visa versa if that doesnt work bin it and get a sthil or an ehco
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
Jul 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Manual for Ryobi Grass Scorpion Line Trimmer
my ryobi scorpion only has twofuel lines but two on primer can you help
Mar 13, 2009 | Ryobi Garden
Ryobi rlt30ces trimmer
Hi there, takes a bit of working out without a manual, but try this....take bottom half of trimmer line spool off, get piece of spool line approx 60 cm, long and thread through centre holes, ( bit fiddly but ) pull line through until you have equal length on both sides, dont try and wind it up onto the spool, just put ends of line through outside cover holes, then lock spool in place in other half. now simply wind the knob at the end and the line should retract into the spool., sounds complicated but really isnt, best regards and good luck, Philbee
Oct 24, 2008 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
735 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
